CS-TK26 main Board
  • SoCalBobS
    I posted our question on the FB Hong Kong RC Tank Group. Hopefully they'll know.
  • Zippersnapper
    Thank God it has servo reversing.
    Tank: The transmitter on this setup is layed out a tad different then the Henglong. The Machine gun fire for example has its own dedicated buttons. With that said, its a stong possibilty that the advanced settings could not be accessed because the fuction key is no longer the "2 button" cannon fire operation. The cannon fire is a 1 button press now and like Bob, Im hesistant about trying to bind the receiver to the Henglong 7.0 Trans, as I'm fearful of bricking the damn thing. I'll let someone else experiment with that.
  • SoCalBobS
    Originally posted by tank_me
    The way the HL binds is by holding the tank start button on the transmitter and then power up the receiver. I wonder if this is similar to that? Is there a button to start up the tank on the TK26 transmitter or does it just run through the starting sounds once the RX is powered on after the TX?
    CS has two buttons, one for start & one to stop, instead of one on the HL.
  • tank_me
  • Zippersnapper
    Originally posted by Vaseline
    I should have one in a few days. Was wondering if we can use multiple MFU's with one TX, Bob wasn't sure about the binding of this unit yet?
    I'm looking forward to playing with it and will add my input to this set up. So far it looks pretty good Sound is amazing
    As Bob mentioned, Im sure multiple receivers would/should bind with a single Trans. I cant find the bind instructions anywhere but will admit I havnt gone in search of either. As far as binding with a 6-7.1 transmitter, I'm not goimg to try until the binding process has been verifed with this unit..
  • Zippersnapper
    Lol....
  • SoCalBobS
    I’m sure multiple Rx’s can be bound, it’s just that the directions aren’t in the manual. Ken, we know it’s you in the video because of the vape smoke!
  • Vaseline
  • Zippersnapper
    Yea Bob, I think we have a winner...
  • SoCalBobS
    Not yet. The instructions don't mention binding. The start/stop control is just different enough (separate start and stop buttons) that I don't feel confident that if I did bind the receiver to a HL Tx that I could get it back bound to the CS Tx. I tried to bind HL 6.0 and 7.0 receivers to it but wasn't successful. Doesn't mean it won't just that I don't know how. Yet.
    Update: Info on DKLMRC says not.
  • Rubicon99
    I'm guessing the case is used for r/c drones, maybe that's why there's a screen, inactive here. The sticks are shorter than HL, so it's really for thumb control, not thumb and finger pinch. The gimbals seem pretty tight, throws are pretty short. It's not heavier, if anything lighter since it's mostly plastic. I'll know more when I start playing with it.
    Click image for larger version  Name:	IMG_3204.jpg Views:	0 Size:	250.4 KB ID:	367559
    If it works out, the receivers are nearly half the price of an HL 7.1, and it has servo recoil and elevation. The instruction sheet says it's good for 4 to 12.6 volts. Guess that's why the big heat sinks.
    Can you test to see if it will bind with a 6 or 7 series TX?
  • RichJohnson
    Double facepalm…. Head shaking…
  • SoCalBobS
    I took the time to hook it up to my robo-tank. Seems to work fine. The shorter sticks may make fine control touchier, but not really noticeable.
    (I know someone who will freak at what I did to a Sherman body.) 😁
  • SoCalBobS
    Do the sticks feel more “hobby grade” in there movement? Does the TX feel heavier and more solid?
  • Rubicon99
    Got mine today. Won’t have time for it until next week. But there are two antenna wires on the transmitter and a longer antenna on the receiver. Range should be good. I placed the receiver next to a 6.1 for size comparison. The heat sink vanes sit higher.
    the screen is cosmetic only.
  • BcuriousR
    I broke down and ordered one too. Says it'll be here by the end of February. I'll be curious to know if it binds to a HL transmitter.
  • SoCalBobS
  • tank_me
    For me a unit like this would be perfect for an APC like the M59 or the M75 which uses the Bulldog hull.
  • Zippersnapper
    A video clip by DKLM RC showcasing the sound capabilities.
    Damn Bob...that sounds great...
  • ccarley
    Those sound options sound pretty good to my ears... that is making me interested!
    Clay
