Heng/Long Rc Abrams left side wheels Jumping and making clicking noises when reversing
  • Totaldoom21
    • Jan 2023
    • 14
    Hello, I purchased this tank off of motion rc a few months ago and haven't had any troubles with it up to now, yesterday when I took it out to play with it I heard a very noticeable clicking sound when reversing as well as being able to see two wheels (one more than the other) jumping and clicking. I've tried to tighten the screws attaching the wheels to the suspension as well as moving them around to see if it could be the wheel itself but the problem persists. Recently due to home renovations I've been driving it over rougher terrain and obstacles so I don't really know if that could have broken anything. Any help would be greatly appreciated.
  • tank_me
    • Feb 2022
    • 1182
    Why does it look like there are two road wheels missing? The clicking could be the track jumping sprocket teeth. Sometimes that is caused by a loose track.
    • Abyssus
      • Apr 2022
      • 38
      • Canada
      Cause I think there are lol
      • Totaldoom21
        • Jan 2023
        • 14
        I had removed them to see if the problem would go away but it didn't change
        • Totaldoom21
          • Jan 2023
          • 14
          What do you mean by this? How could I check if the track is loose and how can I tighten it?
          • Vaseline
            • 290
            Another thing to check to see if any pins are moving out and hitting the side of the tank
            • Hellcat 7
              • Aug 2020
              • 115
              • T/S
              Check the rear sprocket and make sure the tracks are aligned in the teeth. Good luck!
              • megawatt40
                • Dec 2022
                • 50
                The track tension needs to be adjusted,bought my son one this Christmas and when he took it outside he drove it like a mad man down patio steps etc…..
                • ccarley
                  • Jun 2022
                  • 158
                  • Rohnert Park, CA
                  I have to agree with everything said here. These tanks do need maintenance from time to time!
                  Clay
                  • Totaldoom21
                    • Jan 2023
                    • 14
                    Fixed! Thank you so much to everyone who responded! :)
                    • cmdrcody
                      "Grumpy"
                      • Dec 2022
                      • 228
                      • Largo, FL USA
                      What did you finally find out as to what was wrong?
                      • Totaldoom21
                        • Jan 2023
                        • 14
                        I removed the track and cleaned out some leaves and grass that got lodged in the slip ring on the drive sprocket and tightened the track, that seems to have fixed it and the tank drives much better.
                        • cmdrcody
                          "Grumpy"
                          • Dec 2022
                          • 228
                          • Largo, FL USA
                          Yeah, the tank tracks are not always self cleaning especially when running through that type of foliage.
