Smoke not working
Tank repairs
Ok, I have a bunch of bad smoke unit laying around, most problematic component I have found from heng long.
1. Can you hear the pump motor run?
2. inspect wire connections to element, look ok?
3. open smoke unit and carefully remove cotton ball, is it flooded? Sopping wet? If so dry out box, get new cotton ball, put 1-2 drops in, and reassemble.
4. I use a spare piece of tube to fill smoke unit from inside vehicle. i pull off one side of exhaust connect long filler tube. This allows you to blow (only) 1-2 drops into the chamber..
if everything looks right good you should produce smoke!
Hiya Grumpy!
Saw you are from Largo Fl. Me, Venice Fl.
Ken Schweitzer here, retired any Ranger and dad to 19 1/16 RC tanks.. new to hobby but very busy running “tank” events for our Military Heritage Museum in Punta Gorda.
Any tank ops going on in our area? Is Bay Area Blitz still active.
hope to meet and it the tank trail soon!
