Sherman M4A3 (76) Yvonne
  • Rebellion13
    • Jan 2023
    • 21
    I first started with painting the bogies. This is a 3 step process that I have experimented with. I first primered, followed by a Rustoleum textured paint and then Tamita TS-28 OD. I plan on installing a Kim Olsen board but for now I will be using a V3 with the GAA Ford V8 sound card. This will be a slow build though.
    Cheers
    Wade
  • Rebellion13
    • Jan 2023
    • 21
    4:1 Gears arrived
    • Rebellion13
      • Jan 2023
      • 21
      Boy is it a pain to install the bogies with limited space and I couldn't find my short screwdriver
      • Rebellion13
        • Jan 2023
        • 21
        Don't know why it posted the pic twice
        • Rebellion13
          • Jan 2023
          • 21
          Ok I will repost the pic of the lower hull with the bogies installed
          • Rebellion13
            • Jan 2023
            • 21
            Upper hull with Mr. Surfacer applied
            • Rebellion13
              • Jan 2023
              • 21
              The rear deck has what appears to be flat bar stock, I am going to use red glazing putty to give it the effect of weld beads like the 1:1
              • Rebellion13
                • Jan 2023
                • 21
                The grill is kind of finished
                • Rebellion13
                  • Jan 2023
                  • 21
                  Little update, installed gear box and tracks. Next is repaint and detailing of upper hull. Click image for larger version
Name:	Front Tracks.jpg
ID:	371644Click image for larger version
Name:	Side Tracks.jpg
                  • Rebellion13
                    • Jan 2023
                    • 21
                    Decided on addressing the tools. I used a combination of Balsa, Bass, and wooden skewers. Click image for larger version
Name:	Hacked Tools.jpg
Name:	Finished Tools.jpg
                    • 761st
                      • May 2022
                      • 392
                      Great work!
                      • Rebellion13
                        • Jan 2023
                        • 21
                        Originally posted by 761st
                        Great work!
                        Thank You
                        Going to try and get some more work done on the turret, I was not happy with how it turned out using auto body filler, most of it looked ok but there were a few spots where I redid it and it looked worse then it did before. So will have to rework it.
                        Cheers
                        Wade
                        • 761st
                          • May 2022
                          • 392
                          Wade. That's usually my conclusion after a spray. Beauty is, you can always re-spray.
                          • tank_me
                            • Feb 2022
                            • 1182
                            Originally posted by Rebellion13
                            Thank You
                            Cheers
                            Wade
                            Luckily they are tanks and now show cars... :) Tank parts aren't really well finished so some roughness and inconsistencies are expected.
                            Derek
                            • Rebellion13
                              • Jan 2023
                              • 21
                              [QUOTE=tank_me;n372833]
                              Derek[/QUOTE
                              The issue I had was I added "patches" to it, you could see the pattern of the cover up, and when I tried to lightly sand the area it just made the surface smooth and looked out of place. So I removed those areas and redid the putty and thinned it out near the edges. Just need to repaint and call it a day.
                              Cheers
                              Wade
