HL King Tiger TK 7.0 to TK 7.1
  • clxsty
    War Thunder Addict
    • Mar 2023
    • 14
    • Washington US
    I am a beginner at this but is it possible for me to upgrade my HL King Tiger's TK 7.0 Control board to 7.1? The only difference between 7.0 and 7.1 is the wire connectors, right? I can just cut the end off and put a Dupont end on it for CN 14, 15, and 16.
  • SoCalBobS
    • 2754
    • Southern California
    Yes you can change the connectors, but there's no advantage to upgrading. 7.0 & 7.1 are the same except for the latter having servo operated elevation and recoil function, which the stock KT doesn't use.
    • clxsty
      War Thunder Addict
      • Mar 2023
      • 14
      • Washington US
      Oh ok thanks
      • clxsty
        War Thunder Addict
        • Mar 2023
        • 14
        • Washington US
        the thing is i can barely find a 7.0 that has the correct sound
        • tank_me
          • Feb 2022
          • 1197
          Getting the 7.1 will have the same issue unless the vendor tells you which sound set is loaded on them. They both have two sound sets. If you want a 7.0 with the right sound set you can always buy it from Toucan:
          Just select the Tiger 1 sounds as they are the same as the King Tiger - 7.0 is $25
          #Important Notes: The Version 7.0 mainboard and Version 7.0 remote controller are not compatible with Version 7.0S mainboards or Version 7.0S remote controllers. Please confirm your existing equipment version before purchasing. Specification:Brand: HenglongItem Condition: NewSuitable for: RC Tank Model The package opti
          7.1 is $75 and it has the same sounds as the 7.0:
          Specification: Brand: Henglong Item Condition: New Suitable for: RC Tank Model The package option is selected by yourself. If you are not sure whether it is the correct item you want, please contact us before placing an order.
          Derek
          • clxsty
            War Thunder Addict
            • Mar 2023
            • 14
            • Washington US
            thank you so much!
