Pacific Sherman
  • Florida Ranger
    First Sergeant
    • Jan 2023
    • 54
    • Venice Florida
    Pacific Sherman
    Hello Tankers..
    I am beginning work on a Pacific Sherman..concrete filled wood sides, lots of spare tracks. Cages over hatches.
    So my question is, “ What do I need to Swap a Torro upper hull and turret (75mm) to my existing 7.0 Heng long 105mm?
    thanks a bunch in advance!
  • MrChef
    • Jan 2023
    • 510
    • New York, Not the city
    I think Rubicon99 put one together - https://www.hobbysquawk.com/forum/rc-cars-tanks-trucks-and-more/rc-tanks/221445-post-your-pictures-rc-tank-gallery?p=367354#post367354
    • Rubicon99
      • 3316
      Originally posted by Florida Ranger
      Hello Tankers..
      It might be simpler to just convert your HL to a 75mm vs trying to swap over your Taigen/Torro upper half. They look similar but are very different and it takes a bit of work.
      The parts needed (mantle and barrel) to convert your HL turret over to a 75mm turret are available from Mato or Shapeways.
      • Florida Ranger
        First Sergeant
        • Jan 2023
        • 54
        • Venice Florida
        So can a Mato 75mm turret swap right into my HL 7.0 105mm?
        thank you!
        • Rubicon99
          • 3316
          thank you!
          No they are quite different. You can with a bit of work make one fit. Swapping over to a Mato mantle and barrel is the easiest easy to go.
          • Florida Ranger
            First Sergeant
            • Jan 2023
            • 54
            • Venice Florida
            Ok i found the barrel and mantle on mato… does that just replace the HL parts ? Or is there modification needed?
            And thanks for your time Sir!
            • Rubicon99
              • 3316
              It should be a direct replacements but can require a little fitting if memory service.
              • RichJohnson
                • 1276
                I have been told that the mato metal 75mm turret will fit on the henglong but I have not personally done it.
                I know the taigen 75mm turret will not fit on the henglong.
                you might just buy the taigen 75 mm tank if you have not bought a tank to build yet.
                A good place to go for building Shermans is the 1/16 rc Sherman tank builders group on Facebook. That all that goes on there and lots of custom builds like this.
