I have read on these forums that the metal tracks can be problematic on these tanks and was wondering if the upgraded plastic tracked versions have the same issues?
Metal vs plastic tracks on Challenger 2
I had problems with metal tracks on my Challenger. Ultimately I found that the metal ones were 2mm wider than the plastics, and bound on the sprockets which caused detracking. After trying spacers and shims unsuccessfully, I put plastic ones on. They run flawlessly. No need to tinker anymore.The more screws it takes to reassemble a tank, the more likely it is you left something out!Comment
Heng Long have 3 versions of metal gearbox:- Zinc alloy gears. Not acceptable
- TK-BX001B Steel gears with sleeve bearing. OK but less than ideal.
- TK-BX001C Steel gears with ball bearing. Most smooth and durable among the 3.
Heng Long offers five (5) versions of each tank they produce. Motion RC stocks only the top two tiers of each model, Upgrade (metal gearbox, BB, plastic tracks) and Professional (Upgrade + metal tracks).Comment
.png)
