M60 A2 "StarShip" build.
  • Rubicon99
    • 3316
    The DKLM M60 A2 "Starship" turret for the TongDe M60 arrived today. This thread will be a photo log of the building process.
    Photo of the base A2 turret fresh from the shipping box.
  • tank_me
    • Feb 2022
    • 1197
    Looks good. Hopefully mine is arriving soon.
    • SoCalBobS
      • 2754
      • Southern California
      Is it 3DP, good resin, or injection molded plastic? Will you be shooting nerf Shillelaghs?
      • Rubicon99
        • 3316
        It is 3D resin printed. Print appears to be the typical smooth finish that DKLM produces. It's an industrial resin so it should be rather strong.
        The basic test fitting of parts indicates they should all go together well. Here are a few more "just out of the box" photos.
        YES that is a rifled barrel.
        Click image for larger version  Name:	20324B63-4EFC-4D75-BCE0-43877B188BA6.jpg Views:	0 Size:	97.3 KB ID:	378214Click image for larger version  Name:	F1D8385B-EEA2-4F81-A2BF-9758F102B766.jpg Views:	0 Size:	77.9 KB ID:	378215Click image for larger version  Name:	745982DA-810B-428F-9CEC-DAF5611F2146.jpg Views:	0 Size:	139.0 KB ID:	378216Click image for larger version  Name:	1100C88E-B784-4B46-AA5B-D2D91BEB63A4.jpg Views:	0 Size:	112.0 KB ID:	378217Click image for larger version  Name:	865365C3-E54B-40E9-A199-2A79C0C32022.jpg Views:	0 Size:	79.8 KB ID:	378218
        • Rubicon99
          • 3316
          Started work on the barrel and mantle. Installed the barrel flash and an upgraded from the nylon barrel support tub to a brass support tub. Also IR bulb in the mantle. Simple enough process if one takes there time.
          Feel free to ask any questions regarding the process.
ID:	378271Click image for larger version
ID:	378273Click image for larger version
ID:	378274Click image for larger version
          • Rubicon99
            • 3316
            Tested the turret function for flash, recoil, elevation and IR firing. All functions worked. Then went on to the dreaded part of the turret build adding the mantle cover. Ended up not being overly complicated just time consuming.
            Testing flash and recoil. Video is posted on my Instagram @ fsttanks. Click image for larger version
ID:	378283Mantle cover going on.
ID:	378285Click image for larger version
ID:	378284 Finished and dry fitted on lower hull for photo op. Only took 2 1/2 hours!!
            • Rubicon99
              • 3316
              Turret storage rack installation.
              With the instillation of the racks the turret is really starting to get heavy and is taking on a nice bulky look.
ID:	378315Click image for larger version
ID:	378316Click image for larger version
ID:	378314Shown above and below "dry fitted " to the lower hull.
              Next phase is building and wiring the spotlight. With all the options this turret has stock from DKLM it will be pushing the HL 7.1 to its functional limit.
              • RichJohnson
                • 1276
                That is looking badass
                • SoCalBobS
                  • 2754
                  I use the WiFi channel (CN5, G&S buttons) for auxiliary lights, like a beacon or spotlight. I turn the taillights into brake lights so I can use the taillight slot for the LegoDEI lights. I’ve used the launch light for a laser light, pretty cool. A very versatile board.
                  I see your "backdoor" battery hatch. Great idea!
                  • Sappo
                    • Feb 2020
                    • 346
                    All I can say is wow.This view really gives you a idea of how big the TCs cupola, turret? actually was, probably not much smaller than the turret of the stuart I was riding in a few months ago
                    • Rubicon99
                      • 3316
                      I will be posting the new battery hatch mod once I get to the hull detailing part. Super easy to set up but it does require lengthening the battery and power lines to reach the opening. It's also proving a good way to ventilate the heat out.
                      Sneak peek. YES those magnets hold really well almost to well...LOL
                      Click image for larger version  Name:	0D2BDC1B-CE44-4528-88AE-97FF9BD43DD6.jpg Views:	0 Size:	88.3 KB ID:	378332
                      • Rubicon99
                        • 3316
                        Spotlight build and install.
ID:	378393Click image for larger version
ID:	378394Click image for larger version
ID:	378397Click image for larger version
ID:	378398Click image for larger version
ID:	378399Click image for larger version
ID:	378396Click image for larger version
                        • Rubicon99
                          • 3316
                          Accessories A2 lower hull details being installed.
ID:	378510Click image for larger version
ID:	378511Click image for larger version
                          • Rubicon99
                            • 3316
                            Done.
                            Shown in photos below with my other M60A3.
                            Click image for larger version  Name:	1CBBE3E5-D9E0-4DFE-9D3B-3C2E4DBD1B65.jpg Views:	3 Size:	359.6 KB ID:	378687
                            Click image for larger version  Name:	0367AD2E-DADF-4E31-8669-F4DBB983B4E2.jpg Views:	3 Size:	305.1 KB ID:	378686
                            Click image for larger version  Name:	4C13F174-804C-488C-8A74-E4EB6FB6158F.jpg Views:	3 Size:	471.5 KB ID:	378682Click image for larger version  Name:	6859461B-C774-419D-83AB-879664ED27AE.jpg Views:	3 Size:	476.4 KB ID:	378683
