San Diego battle day June 24th
  • RichJohnson
    • 1276
    619th tank battalion will host the next San Diego rc tank battle on Saturday the 24th at 9am
    location is the usual Mission Bay site at South shores boat ramp behind sea world.
  • Rubicon99
    • 3311
    Getting in some practice time with the M60A2 before this Saturday's San Diego battle day (June 24th 2023). This will be the second official club battle day for the M60A2. It was used prior at the June 2023 LA club battle and did ok. But San Diego is were it should really shine. Huge field, long range shots, sweeping maneuvers and terrain to camouflage your firing positions.
    Click image for larger version  Name:	4552DDEB-EFD8-4A94-BACC-E76D1BAB1C89.jpg Views:	0 Size:	195.4 KB ID:	380313Click image for larger version  Name:	7A045AE8-4E03-47C7-8340-A30F724D15D8.jpg Views:	0 Size:	270.0 KB ID:	380314
    • Rubicon99
      • 3311
      Lots of shooting and driving at the June 2023 San Diego tank clubs battle day. It was almost entirely BIG tanks at this event. Shown here my M60A2 takes on a M60A3 and Abrams
      M60A2 vs M60A3
ID:	380483 M60A2 vs Abrams (top of photo tan Abrams hard to see)
      • Panzermechaniker
        • Feb 2023
        • 144
        That Abrams is well camo'd for the field
        • Rubicon99
          • 3311
          Yes it was tough to see at distance.
          • Rubicon99
            • 3311
            Here is another photo from the June 2023 event. Click image for larger version
            • ArmorBolt
              • Dec 2020
              • 72
              Yours truly😀. Thanks all, I had a lot of fun!
              • ArmorBolt
                • Dec 2020
                • 72
                • Panzermechaniker
                  • Feb 2023
                  • 144
                  What are those red plants? Some WW2 German Panzerwaffe spaghetti red bands or splotches and that tank would be an invisible killer for combat on your field
                  • ArmorBolt
                    • Dec 2020
                    • 72
                    Not sure what they are called but those beautiful red plants/flowers are native to Southern CA coastal region. They are as bad as PanzerFaust, if you run over them and get those flowers stuck in your track/sprockets, you will detrack sooner or later. 😁
                    • ArmorBolt
                      • Dec 2020
                      • 72
                      More pic..
                      • RichJohnson
                        • 1276
ID:	380637Click image for larger version
ID:	380638Click image for larger version
ID:	380639Click image for larger version
ID:	380640Click image for larger version
ID:	380641Click image for larger version
ID:	380642Click image for larger version
ID:	380643Click image for larger version
ID:	380644Click image for larger version
ID:	380645Click image for larger version
                        • SoCalBobS
                          • 2716
                          • Southern California
                          Every single one of my tanks had that stuff stuck all through the tracks and wheels! And yes, they caused detracking.
                          • MrChef
                            • Jan 2023
                            • 501
                            • New York, Not the city
                            Curious how your clubs handle de-tracking during a round? Is a tank that is de-tracked stuck in position till the round ends? Or is there a time penalty, or "time out" or pause in the round and then able to be fixed and finish the round? Or are you just able to fix the tank whenever and able continue the round?
                            • Panzermechaniker
                              • Feb 2023
                              • 144
                              In our club's battles if you lose a track you have to leave the tank out there until the battle is over. You are a sitting duck but you can still go down firing some hits😈
                              • Rubicon99
                                • 3311
                                San Diego's battle field is huge and it tends to attract a more experienced player. So keep that in mind when reading below.
                                Typically the tank is stuck in their position and has to fight from that position if there are tanks within 20ft.
                                If there are no tanks close then the operator can approach the tank and attempt to put the track on. During this time the tank is still on and able to receive hits. If it needs to be turned off to safely put the track on it is then considered "knocked out".
                                • RichJohnson
                                  • 1276
                                  The theory behind our allowing this is if the battle is raging over there and not around you, the tank crew can get out and service their tank to get it back in the action.
                                  When tanks get stuck, they battle where they are unless another tank comes up to help pull them off the obstacle if the battle is not raging around them.
                                  • ArmorBolt
                                    • Dec 2020
                                    • 72
                                    San Diego RC tank battle field terrain is quite brutal. It is an excellent testbed area. If your tank can run around here, go thru the soft wet morning sand and dirt, go thru some hard sand, climb the obstacle course, run over some plants, get stuck in some bushes... for about couple of hours without de-tracking or any issue, you got yourself a good platform.
                                    My Abrams did well for about an hour, and after that de-track.
                                    • Rubicon99
                                      • 3311
                                      Actually the San Diego field is pretty easy on tanks and the fine sandy silt is near perfect for driving tanks on. The red "ice plants" can be easily driven over as long a you do not turn abruptly while doing so. It comes down to technique and once you learn what can be done and can't the field becomes a wonderland of driving fun. My M60s just eat the field up and I had no de tracking the entire day. You will see it becomes easier and easier the more you drive there.
                                      Your issues are easily solved and here is what I recommend as it has been proven to work exceptionally well. The main problem: HL metal tracks you are running. If you upgrade to Tamiya Leopard 2 or Tamiya Abrams tracks you will see a substantial increase in running reliability on all terrain types. Both these tracks work with HL Abrams sprockets. You will need to shorten the Leopard 2 tracks by two links which is easily done. I don't know if you have installed the drive shaft support bearing but if you haven't then do so. These are very helpful especially if combined with the following paragraphs recommendations.
                                      Why Tamiya tracks? The reason is multi fold. First the Tamiya tracks are "dual pin" like the real tracks, not single pin like HL tracks. This means they are more flexible and forgiving. The second is that the Tamiya tracks have slightly taller guide teeth. These provided a bit more hold against the sprocket center retaining ring and this in turn helps them resist "over ridding" the retaining ring. Third the Tamiya tracks are lighter then all metal tracks (hybrid design of nylon pad, steel pins, steel end connectors and hard rubber pads) but just as if not stronger. Lastly the Tamiya tracks are solid and not hallowed out like the stock HL tracks. This means they do not have the "shoveling" effect that the HL do as the hallows fill with sand/dirt and carry it up and over the sprockets. Less sand/dirt flowing over the sprockets mean less opportunity for foreign matter to cause a de tracking event.
                                      The Tamiya tracks very in price and I would recommend buying the Leopard 2 tracks as these are much cheap then the Tamiya Abrams tracks. A set of Tamiya Leopard 2 tracks should run about $100 which is comparable to other aftermarket non Tamiya tracks for the Abrams.
                                      • RichJohnson
                                        • 1276
ID:	380750Click image for larger version
ID:	380749Click image for larger version
ID:	380748Click image for larger version
ID:	380747Click image for larger version
ID:	380746Click image for larger version
ID:	380745Click image for larger version
ID:	380744Click image for larger version
ID:	380743Click image for larger version
ID:	380742Click image for larger version
