For how long can the Heng long smoke generator work after not putting smoke oil for a while?
  • ninufor
    • Aug 2023
    How long can the Heng long smoke generator work after not using the smoke generator for a while?
  • cmdrcody
    "Grumpy"
    • Dec 2022
    • 228
    • Largo, FL USA
    It won't work at all with no smoke oil. 🤣
    • Jarlath
      • Jul 2023
      • 62
      • Ontario, Canada
      One of the reasons I stopped using them. Forget to turn them off and they run dry in a 20 minute battle = melted heating element that needs to be replaced. Also sucks when you need to turn your tank upside-down and it has some fluid left in it.
      • HDMM
        • Feb 2020
        • 77
        • Florida
        When the HL fan smokers first came out one of our club members in FL got one and put it in a Tiger 1, when it ran out of smoker fluid, the darn thing melted, caught on fire and burned up the upper hull on the tank. He had to douse it with a hose, luckily he was in hos backyard with it at the time.
        • keilau
          • Mar 2021
          • 1838
          • Windy City
          I removed all the smoke generators from all my 1:16 scale RC tanks. Engine does not generate white smoke.
          • HDMM
            • Feb 2020
            • 77
            • Florida
            • tank_me
              • Feb 2022
              • 1186
              That's why I preface my tanks don't smoke statement with smoke on startup or running badly. Some will smoke at wide open throttle like the M60. That Sherman sounds like it's using the 9 cylinder radial engine. You can damage the engine from starting it without cranking it by hand to even out the oil in the cylinders as it drains to the lower jugs. The smoking also subsided a lot after it was running for a bit which probably means it was burning the oil off from sitting.
