T34/85 smoker doesn't fit back
  • Kendusan28
    • Aug 2023
    • 27
    Recently I opened my Heng Long T34/85 because of some turret problems. While opening the tank I had to disconnect the smoker from the ports. After fixing the issue I couldn't fit the smoker back in. I tried to find videos of T34/85 tear downs but found nothing about reconnecting the smoker or the smoker not fitting. I got the tank from Amewi, and it was also missing one tube connection to the exhaust pipe.
    Thanks for your time,
    Kendusan28
  • HDMM
    • Feb 2020
    • 77
    • Florida
    Probably going to need some pics of whats going on inside there. The smoker is a tight fit in the T34
    • Kendusan28
      • Aug 2023
      • 27
      Thanks a lot for replying HDMM. I have 2 pictures, one of the tank opened, and one of where I think the smoker goes, I have bought new smoke pipes.
      If you need anymore photos you can ask.
      Thanks a lot again,
      Kendusan28
      • HDMM
        • Feb 2020
        • 77
        • Florida
        OK, I see now you’re trying to fit the smoker in the lower hull, I think It actually mounts to the upper half of the hull so that it can can to the elbows. Yes it’s a little weird but that’s how mine was that I has a few years ago. Although I think that was before they came out with the fan smoke unit. If it won’t screw into that spot between the gearbox I think maybe the tubes just kinda keep it in place. Sorry I’m not much help. I don’t think I have an opened up a henglong T 34 with a fan smoker in probably two years the last time I worked on one for somebody.
        • Kendusan28
          • Aug 2023
          • 27
          Thanks for the tip HDMM, I'll try it out and report the results
          • Jarlath
            • Jul 2023
            • 62
            • Ontario, Canada
            Smoker in the T34 mounts on the upper hull but is not secured by anything.. (Just the tube connections, IIRC).
            • Kendusan28
              • Aug 2023
              • 27
              When I try to place it in it fits, but once I try to fit back the upper hull it gets stuck, I believe its obstructed by the motors. Another question, would it be worth trying out the metal small smoker from Heng Long?
              • SoCalBobS
                • 2736
                • Southern California
                I just opened mine to check.
                Jarlath is right, it is not mounted to the lower hull.
                You'll need to put the upper hull on by starting it back a little then moving it forward to match up with the lower, so that the smoker motor which is on the upper hull slides under the motors.
                • Kendusan28
                  • Aug 2023
                  • 27
                  Thanks for the tip, it works!
                  • HDMM
                    • Feb 2020
                    • 77
                    • Florida
                    That's what I though as well, been awhile since I've had a HL T34, but even my Taigen one was mounted up top, just held in place by the tubes.
                    • Sappo
                      • Feb 2020
                      • 346
                      What I did was to move the smoker to the front of the hull ,connected the exhausts with a T joint from a aquarium pump and ran a long hose back to the smoke unit. I then attached a short hose to the other outlet and fill it through the drivers hatch
                      • Kendusan28
                        • Aug 2023
                        • 27
                        Hi Sappo!
                        Could you please send a picture, the mod sounds very interesting. Im considering doing it my self.
                        • Sappo
                          • Feb 2020
                          • 346
                          Sorry it took so long to get back with the pictures of the t34 smoker,,as you can see there is a T joint at the back connecting the twin exhausts with a long hose coming forward to connect with the unit. Very easy to do. Excuse the Q tip plug in the filler hose, was all I had at the time and have never changed it
                          • Kendusan28
                            • Aug 2023
                            • 27
                            Thanks for the picture! What is that smoker? Is it the metal one?
                            • Sappo
                              • Feb 2020
                              • 346
                              Yeah, it's a after market one. Unfortunately I can't remember where I got it, I think it was Ali Express
                              • Sappo
                                • Feb 2020
                                • 346
                                Looked up my purchase records, look for the store, Tank Zang on Ali Express
