Adjusting Barrel Recoil
  • Swarm-_-Intell
    • Aug 2023
    • 3
    Hi all. Does anyone know how to change the recoil timing on Heng long tanks? Specifically the t90 7.0? The timing of the recoil is Awful stock. Currently it recoils then shoots. I want to get it so it recoils as soon as the bb’s shoot or very soon after. I’m new to the whole modification side of the hobby so any info is much appreciated <3
  • Delta_19
    • Apr 2021
    • 170
    There is no way to adjust recoil timing stock. To do so you need an aftermarket board and recoil unit
    • Swarm-_-Intell
      • Aug 2023
      • 3
      I see. Do you have any recommendations for boards and units? Or even how to go about installing it in the first place? -Thanks
      • HDMM
        • Feb 2020
        • 77
        • Florida
        The recoil is like that because it's part of the BB firing system unfortunately. You can get a henglong servo recoil unit rom various places such as Forgebear Tanks, Aliexpress, Ebay, etc. You'll need to use a TK7.1 board because it has a servo recoil port. That would be the easiest and least expensive swap. Otherwise you can look at a TK26 board and transmitter from Toucan (which is much better in my opinion than the HL 7 series) or your looking at a Clarak board like a TK50 and a Flysky transmitter (the most expensive option)
        • DavidN
          • May 2021
          • 3209
          • Los Angeles, CA
          What would be the advantages of upgrading a HL TK-7.0 RC tank to the TK-7.1 MFCU system? And what would be the dis-advantages of upgrading a HL TK-7.0 RC tank to the TK-7.1 MFCU system? I know there are advancements in controlling of added electronic system parts in the TK-7.1 MFCU system, but how would it work with and advance
          Please check on post #22 and post #29
          • keilau
            • Mar 2021
            • 1849
            • Windy City
            Your current post is post #5.​ There is no post #22 and post #29.
            • HDMM
              • Feb 2020
              • 77
              • Florida
              That's because your supposed to click on the link that he imbedded which goes to another discussion thread. It shows a couple links for servo signal converters. Those can plug into the board and convert the HL signal to be compatible to operate a servo on the stock board. I didn't mention them because they are usually hard to find (both links are for germany) and for some users, it's easier to get a differnt motherboard or upgrade.
              • DavidN
                • May 2021
                • 3209
                • Los Angeles, CA
                And it only works with the 7.0 HL board. I tested it on 3 of my 6.0 HL boards and none of them worked.
                I intend to convert about 20 of my HL tanks to have their barrels recoiled. These little boards only cost me $12 each with shipping included from Germany. If I get the 7.1 boards for these 20 tanks, I am looking at $1500 instead of $240; ouch :-)
