Does anyone have experience with the Heng Long 1/24 tanks? I bought one on a whim and it's a fun little toy and handles great on smooth surfaces, but quickly throws the left thread (only the left) on any kind of carpet. I can't find any obvious difference between the left and right sprockets or tread tensions.
1/24 Heng Long Abrams throws treads
Tags: None
Most likely one side is slightly tighter then the other. Track tension is critical on tanks especially if you drive them on carpet. Unfortunately your 1/24 scale tank does not have track tensioners and so the problem will only remain and get worst as both tracks "stretch" (wear in).Does anyone have experience with the Heng Long 1/24 tanks? I bought one on a whim and it's a fun little toy and handles great on smooth surfaces, but quickly throws the left thread (only the left) on any kind of carpet. I can't find any obvious difference between the left and right sprockets or tread tensions.
Did you try it on a flat, but unfinished concrete surface? If it does not throw track there, it delivers what it means to do. I have several 1:24 scale Marui, VS Tank and ToyEase RTR tanks before I jumped to 1:16 scale. The smaller scale was meant for leveled surface only. Mine used to run fine on carpet.Does anyone have experience with the Heng Long 1/24 tanks? I bought one on a whim and it's a fun little toy and handles great on smooth surfaces, but quickly throws the left thread (only the left) on any kind of carpet. I can't find any obvious difference between the left and right sprockets or tread tensions.
You can prove @Rubincon99 theory by swapping the left and right track. If it throws track on the right side after swapping, you find the source of the problem. Marui made a 1:24 scale Abrams, but stopped production years ago. Their track may be higher quality if you can locate one.Comment
