Heng Long Sherman 3-piece differential cover conversion.
  • Rob1970
    Grumpy Old Dutchman
    • Jun 2021
    • 278
    A "little" side project I finally finished!
    3-piece differential cover for the Heng Long M4A3.
    I have a discount code for all ya'll here on the forum; HAPPY2024
    https://cults3d.com/en/3d-model/game...ong-m4-sherman
    Now back to working on the Grant...
    ttfn,
    Rob​
    Sherman M4A3 105mm Houwitser / Sherman Firefly IC *under construction* / Panzer IV *awaiting side-grade from TK7.0S to TK6.0S* / Stug III / King Tiger / KV-1 *awaiting upgrade to TK6.0S* / Tiger I / T34-85 / Leopard 2A6 *waiting upgrade to TK7.0*... No, I do not have a problem....
  • quitcherbitchen
    • 928
    • Altadena, CA
    thanks Rob for doing all the work!!
    • Rob1970
      Grumpy Old Dutchman
      • Jun 2021
      • 278
      It was my... pleasure? I think?
      Rob
      • Rob1970
        Grumpy Old Dutchman
        • Jun 2021
        • 278
        sigh...
        Already did some editing on the files after some rivetcounter on a modelling group gave me a whole sermon on how "the 3-piece was cast so the corners between the "ears" and the main part are too sharp"...
        I told him politely to use 2 grams of putty and a wet finger. Either on the part or... somewhere else ...
        ...and then edited the part and uploaded new versions...
        deep breath
        They are not worthy...​
        • SoCalBobS
          • 2774
          • Southern California
          Originally posted by Rob1970
          sigh...
          deep breath
          Did he personally check every cast housing ever made to see if none had sharp corners? C'mon man, sheesh! I have no patience for people like that.
          • Rob1970
            Grumpy Old Dutchman
            • Jun 2021
            • 278
            He sounded anal-retentive enough to have indeed checked them all. At least in his head... Rivetcounters can kiss my tiny shiny hiney...
            That said... I am my own worst critic, and will fix something if I can. So there's that...
            • Barmonkey
              • May 2021
              • 54
              • USA
              Downloaded the files but I will have to wait until tomorrow to print :disappointed:
              • Barmonkey
                • May 2021
                • 54
                • USA
                Now..if someone would come up with some 3D files for a low bustle turret or even a 75mm barrel and mantlet to fit the Heng Long turret...
                • Rob1970
                  Grumpy Old Dutchman
                  • Jun 2021
                  • 278
                  Sorry, working on a Grant and a BARV. But maybe someday... But thank you for downloading the files. Only 135 more downloads and I can afford a second printer...
                  • RichJohnson
                    • 1301
                    Rick and I are working on the low bustle 75mm and early hull as well as early a1 cast hull also, after I get the EZ8 turrets out. He has most of the drawing work done I just need to start trial and error on printing and making up kits but I cant move as fast as I would like.
                    • Tang - RC.Senshado
                      SoCal RC Tank Club
                      • Jul 2023
                      • 132
                      • Los Angeles, CA
                      Is your turret set up for servos only or can they also take a HL style elevation motor?
                      Gathering 1-2x monthly/All Ages & Experience levels welcome
                      • Rubicon99
                        • 3324
                        I have seen his turrets. They are set up for servos, but it would be easy to modify the turret to use a HL Sherman elevation system. Oh and the turrets are absolutely awesome looking. I put one on order after I handled a production one.
