And then there were 3... Heng Long M4A3 Sherman
  • And then there were 3... Heng Long M4A3 Sherman
    Went from Colorado straight into the worst winter storm we've had for awhile and yet made it Bondurant, Iowa on time, where it sat for 4 days because someone done pushed the wrong button, but now it's safe and warm Click image for larger version
Name:	M4A3 Sherman_left.jpg
    so I've got everything laid out on the bench and the first thing I discover is a white double sided foam tape for mounting some of the detail parts, has anyone actually used that stuff or how did you go about it, just does not impress me
      the tape is to mount the figure in the turret copula
        but the diagram shows the wheels, some kind of container and the track section being held on by it, there are no holes etc for them or anything else would hold them.
          Ok sorry someone else with a Sherman will help you then. All of my tanks use the tape to secure the figure only.
            Yeah don't use the tape, it collects dust and the parts will fall off. Use some superglue to hold everything where you want it (Loctite liquid bond is my preference).The manual shows where the stowage is reccomended to be placed, but you can put it anywhere you want. Shermans in WW2 sometimes looked like driving piles of stowage.
              that's an awesome photo ")
ID:	395398 Click image for larger version
ID:	395399 Click image for larger version
ID:	395400 Click image for larger version
                  How did you manage to mount the M2 50 calibre machine gun up side down? It is impossible with mine.
ID:	395411 Click image for larger version
                    Nice! If you want to make some more stowage yourself, you may be interested in using potato/onion bags and tin foil. Tin foil works great as tarp material since you can replicate wrinkles really easily, and potato and onion bags work great as camo nets! 3D printed and resin stowage is also something to look into.
                    These two tanks are fictional builds, so not accurate to WW2, but they might give you an idea of some other places and ways you can mount stowage to your Sherman.
ID:	395424Click image for larger version
                    Note the camo netting made from a potato bag on the front of my "Sherman X".
                    • #11
                      Click image for larger version  Name:	Mato-M2_on_sherman.jpg Views:	0 Size:	94.9 KB ID:	395411 Click image for larger version  Name:	m2-50-caliber-machine-gun-007.jpg Views:	0 Size:	136.9 KB ID:	395412
                      that's what I get for staying up late, good catch. I have corrected the matter
