Torro "open box" special from Motion RC
  • Barmonkey
    • May 2021
    • 54
    • USA
    Everything seems to be working for now. I will need to put some more time on it and see if the smoker is working. I put one drop of fluid in it and there was a little smoke...briefly.
    • Barmonkey
      • May 2021
      • 54
      • USA
      Oh...it does have 360 degree turret rotation and the add-on module to make it compatible with Heng Long and Tamiya IR. I haven't tested that.
      • MrChef
        • Jan 2023
        • 510
        • New York, Not the city
        Originally posted by Barmonkey
        Sorry, no barrel smoke :frown:
        No worries. Not a deal breaker for me. I've just seen some people with Torro's reporting that they came with barrel smoke as well.
        • Tang - RC.Senshado
          SoCal RC Tank Club
          • Jul 2023
          • 130
          • Los Angeles, CA
          SCORE! You got one that was cooperative and pulled a win out of this one.
          Gathering 1-2x monthly/All Ages & Experience levels welcome
          • Barmonkey
            • May 2021
            • 54
            • USA
            Just ordered another project tank. This time the Torro Early Tiger unpainted....
            • MrChef
              • Jan 2023
              • 510
              Well I finally had time today to open the "Pandora's Open Box" special.
              Function check revealed the only things not working was most importantly the cannon elevation then the smoker. I could care less about the smoker so I dove right in using Barmonkey's notes. Sure enough the motors were all working so I dismantled the elevation/recoil box. My issue wasn't the same gear but the same issue.The Top gear in his picture with the bent metal rod that attaches to the bracket on the end of the barrel that moves it had worked it's way off.
              So carefully with his advice I opened up he gearbox and reset all the gears. I'm also amazed the gear closest to the motor isn't captured. :crazy: I do love the recoil and flash.
              I didn't have any electronic or connections issues. I had bought a daughter board from Taigen for $4.99 but didn't even need it.
              All runs as it should now. Literally about 45 minutes of my time and saved some good loot.
              The only other issues are cosmetic. About 4-5 small paint blemishes that I'll remedy.
              The box is a cool touch. It wasn't damaged but the lightweight hardware was mangled and will need to be upgraded and replaced.
              Thanks Barmonkey for sharing the fix for our open box specials 👍
