Official Torro German Jagdpanther 1/16 Scale Tank Destroyer Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    The Jagdpanzer was a German heavy tank destroyer produced during World War II, featuring effective armament, mobility, and armor; but its limited production numbers did not significantly impact the war. Development began in August 1942, finished in November 1943, and was showcased to Hitler in December. Mass production started in early 1944, resulting in 425 units being created.
    Built on the Panther tank chassis, the Jagdpanther featured a fully enclosed superstructure with sloped walls. It had two circular hatches on the roof, a rear door, and an ammunition loading hatch. The crew of five consisted of a commander, gunner, driver, loader, and radio operator. The primary weapon was an 88 mm anti-tank cannon. The armor ranged from 40 to 60 mm on the hull and 25 to 80 mm on the superstructure.
    Weighing over 45 tons, the Jagdpanther was powered by a 700 horsepower Maybach HL 230 engine, consuming 280 liters of gasoline per 100 km on-road and up to 700 liters in rough terrain. Despite its excellent design, fuel shortages in late 1944 and 1945 hindered its effectiveness. The weapon’s combination of mobility, firepower, and protection made it a formidable opponent against Allied and Soviet tanks.
    This Torro 1/16 scale replica will impress the most demanding scale tanks, as the realistic airbrushed finish and stunning details combine to deliver a model that is equally adept at operation or display. An included 2.4GHz radio system provides interference-free control, while the sound system and latest speaker design deliver a range of realistic engine, track, cannon, and machine gun sound effects. Due to its weight and powerful motors and metal-geared transmission, this tank delivers superior driving characteristics over a wide range of terrain. The high-quality tracks, drive wheels, and idler wheels as well as road wheels, lower hull, turret are all manufactured from metal.
    In addition to standard forward/backward/turning/spin movements, the main cannon can be raised and lowered via the servo controlled elevation/recoil mechanism. In addition, the cannon barrel recoils during firing while emitting a flash of light and smoke when fired, while the included smoke system produces a realistic plume of exhaust while driving.
    Metal tracks and Chassis
    All of Torro's "Pro-Edition" tanks feature full metal drive systems. Single track links are connected with steel pins, propelled by metal drive sprockets and riding over metal road wheels and idler. Confidently conquer terrain with these durable metal tracks!
    High Torque Motors
    Reliable metal geared gearboxes are driven by high torque motors.
    Barrel Recoil and Muzzle Flash Effect
    This model features adjustable cannon elevation, synchronized barrel recoil, and muzzle flash effect. When firing the main cannon, the barrel recoils at the same time that an LED inside the barrel flashes and a firing sound plays through the tank's internal speaker. Normally a costly aftermarket feature, this entire system is pre-installed in this Torro masterpiece.
    Includes Sturdy Wooden Crate
    Torro tanks are delivered with a sturdy, decorative, and highly functional latching wooden crate to securely store and transport your valuable model.
    IR Battle Ready
    Engage in exciting infrared (IR) battles with other tanks using Torro's exclusive IR Battle System! Exchange hits with opponents, with each impact accompanied by realistic sounds and actions. After five hits, your tank will be temporarily disabled. But don't worry—after a 10-second pause, your tank will be back in action, ready to rejoin the fight!
    Outstanding Scale Detail
    From the authentic colors to the photo-etched scale details, the Torro Jagdpanther is a model suitable for display yet fully capable of realistic RC operation.
    • 75%+ metal parts including turret, main barrel, tracks, and drive system
    • Charging via charge socket (the tank does not have to be opened for charging)
    • Servo-operated cannon elevation and barrel recoil with muzzle flash effect
    • Realistic suspension system
    • Metal lower hull, drive wheels, idler wheels, and road wheels
    • Single pad metal tracks connected with steel pins
    • Proportional acceleration, steering, turret traverse, and gun movement
    • Realistic sound system and smoke effect generator
    • Protective and realistic wooden crate packaging
    • Fires an invisible IR signal to be used as part of Torro's proprietary Infrared Battle System, which disables other tanks when hit five times during simulated combat. Up to 20 tanks at the same time can battle each other!
    • Torro German Jagdpanther 1/16 Scale Tank Destroyer - RTR
    • 7.2V NiMH battery with Tamiya connector
    • 7.2V NiMH battery charger
    • 6-Channel 2.4GHz radio transmitter
    • Infrared (IR) battle system receiver
    • Painted cosmetic accessory parts
    • Adhesive decal sheet
    • Set of small parts and accessories
    • Sturdy wooden crate for transportation or display
    • Smoke effect oil (vegetable glycerin)
    • Complete instruction manual in English and German
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : 1 Hour
    Scale 1:16
    Length 62cm / 24.2in
    Width 20.5cm / 8in
    Height 16.5cm / 6.4in
    Weight 5200g / 186oz
    Body Material Metal/Plastic
    Chassis Material Metal
    Track Material Metal
    Motors Two 380 motors
    Bearings Metal bushings
    Gearbox Gear Material Steel
    Adjustable Gear Ratio Fixed
    Differential Type Gear
    Suspension Type Torsion bar
    Sprocket Metal
    Road Wheels Metal
    Idler Wheel Metal
    Adjustable Idler No
    Turret Rotation N/A
    Lights Yes
    Sound Yes
    Exhaust Effect Yes
    IR Battle Ready Yes
    Airsoft BB Launch No
    Track Recoil Yes
    Cannon Barrel Recoil Yes
    Required Battery 7.2V (included)
    Required Radio 2.4GHz (included)
    Skill Level Beginner
    Build Time 1 Hour
  • Macjohnkayson
    • Feb 2026
    • London, UK
    This is an amazing model, definitely recommend it. I'm not getting much smoke out from the smoke unit so would welcome any thoughts on how to improve that.
    • DavidN
      • May 2021
      • 3200
      • Los Angeles, CA
      Bought this used old version for $45. After many weeks.....it is now ready to battle.
ID:	448949 Click image for larger version
ID:	448950 Click image for larger version
ID:	448951 Click image for larger version
ID:	448952 Click image for larger version
ID:	448953 Click image for larger version
      • Rob59
        • May 2026
        • 25
        • Netherlands, Europe.
        Back in 2019 I bought that JaPa too.
        Upgraded it with a 3rd stowagebox on the rear left side of the superstructure.
        I also made Zusatzpanzerung above the grills on the motordeck out of aluminum. The big one on the left is functional, can be opened/closed. Schürzen on both sides are homemade out of alu too, attached to hangers out of brass.
        Wired both sides of the superstructure to ad foliage if needed.
        Click image for larger version  Name:	43548.jpg Views:	0 Size:	305.8 KB ID:	449175
        Click image for larger version  Name:	43547.jpg Views:	0 Size:	294.8 KB ID:	449174
        • Rob59
          • May 2026
          • 25
ID:	449177 Click image for larger version
          • Rob59
            • May 2026
            • 25
            Damn, just noticed in the last two pics, I completely overlooked that the towhooks on the motordeck, are still glued in the wrong direction!
            Must take care of that asap.
            • SoCalBobS
              • 2741
              • Southern California
              Funny how photos show the discrepancies we overlook in person!
