M60 working search light.
  • EARRNHARDT3
    • Aug 2024
    I recently bought one of the after market search lights for the M60 tank. I heard some people are converting them into working light.
    what are guys using as a light /LED ? Where are they getting the power from? Is it able to be turned off with the remote ?
    thanks for any help
  • SoCalBobS
    • 2754
    • Southern California
    Get some 6V LED's, 6mm, from Evan Designs online. If you change the MFU to a Heng Long, connect it to either the WiFi circuit (switchable on/off) or if you don't use smoke, the smoke motor circuit, also switchable. If you use the Tongde MFU, check and try whatever equivalent circuit they have. Some in their manual are listed but not actually live.
    In the case below, the searchlight is on the smoke circuit and the beacon is on the wifi circuit.
    Click image for larger version  Name:	M60A3 10.jpg Views:	0 Size:	198.0 KB ID:	408496
    • william9293
      • Apr 2025
      The M60 Working Search Light is a powerful, versatile lighting solution designed for both industrial and emergency applications. Known for its rugged durability and exceptional brightness, the M60 is commonly used in search and https://smartledinc.com/product/1-si...mm-resolution/ rescue operations, military settings, and large-scale industrial tasks that require a focused beam of light in dark or difficult-to-reach areas.
