Sherman gun upgrade
  • TankGuyIL
    • Sep 2024
    • 4
    Sherman gun upgrade
    So I bought a US Stock 1/16 Henglong Recoil Long Barrel Flash Light of M4A3 Sherman RC Tank​ , Do I need the 7.1 board for this unit or can I put it in with the 7,0 board?
    Thanks
    Steve​
  • Rubicon99
    • 3311
    [QUOTE=TankGuyIL;n411832]So I bought a US Stock 1/16 Henglong Recoil Long Barrel Flash Light of M4A3 Sherman RC Tank​ , Do I need the 7.1 board for this unit or can I put it in with the 7,0 board?
    Thanks
    Steve​[/
    Looks like it is a BB recoil so you are fine with just the 7.0.
    • keilau
      • Mar 2021
      • 1815
      • Windy City
      Thanks
      Steve​
      It is a trigger motor metal barrel recoil upgrade kit. The TK-7.0 MFU works perfectly fine with it. Use the transmitter radio to:
      1. Turn off the track recoil.
      2. Connect the trigger motor to CN6.
      The barrel will recoil when you fire. It is NOT a servo recoil. I have trigger motor recoil on five of my HL tanks. It slaps back too fast. It is realistic enough for me.
      The Sherman came from Heng Long is equiped with the 75mm gun, correct for its version. The longer 76mm gun with the flash muzzle is for the later era Easy 8 Sherman with HVSS suspension. You will need some upgrade to your tank too. RichJohnson markets 2 Easy8 upgrade kits for the HL Sherman, HVSS suspension ($235) and turrent ($145). It is easier than scrath build.
      Click image for larger version  Name:	1600px-TankshermanM4.jpg Views:	0 Size:	252.2 KB ID:	411864
      It may be much simpler to return the muzzle flash recoil kit and get a recoil kit with the 75mm cannon which is usually cheaper.
      Click image for larger version  Name:	IMG_5182 - Copy.jpg Views:	0 Size:	74.5 KB ID:	411878 Click image for larger version  Name:	IMG_5183 - Copy.jpg Views:	0 Size:	73.4 KB ID:	411876 Click image for larger version  Name:	IMG_5179 - Copy.jpg Views:	8 Size:	79.0 KB ID:	411877
      I did the recoil upgrade the difficult way. I got a generic recoil BB shooting unit (< $10) and cut the HL OEM barrel to fit. It works very well too.
      Click image for larger version  Name:	IMG_5205 - Copy.jpg Views:	0 Size:	98.5 KB ID:	411880 Click image for larger version  Name:	IMG_5218 - Copy.jpg Views:	0 Size:	152.1 KB ID:	411875 Click image for larger version  Name:	IMG_5220.jpg Views:	0 Size:	139.1 KB ID:	411881 Click image for larger version  Name:	IMG_5210 - Copy.jpg Views:	0 Size:	106.8 KB ID:	411879
      • keilau
        • Mar 2021
        • 1815
        • Windy City
        The correct 75mm cannon metal barrel recoil upgrade BB shooting kit for Heng Long M4A3 Sherman Tank 3898:
        https://www.ebay.com/itm/32490142020...Y4T9JJH0BEZBWJ
