Unofficial Tongde M24 Chaffee 1/16 scale Battle Tank Discussion Thread
  • SoCalBobS
    • 2717
    • Southern California
    DKLM has posted on FB that the first batch of M24 Chaffee tanks by Tongde has been shipped out to preorder customers. One of them is for me!
    I'm posting some information that prospective buyers may find useful. I am a fan of DKLM because he is honest and responsive to emails, so I recommend dealing with him. DKLM's preorder price for the metal version was $225 + $93 shipping = $318 total. Yesterday I compared this with AliExpress's preorder cost: $245 + $171 = $318. Toucan showed $308 + whatever shipping they will charge at checkout. DKLM's price for the plastic version was $122 + ~$93? = $215. AliExpress's is $134 +$114 = $248 and Toucan's is $179 + shipping. To be fair, Banggood lists the plastic preorder cost as $214 with free shipping. I don't know how they do that! These sellers post a late November availability.
    Now obviously prices may change after stock shows up. I only point out that DKLM is comparable, even better in some cases, to other sellers; just an opinion. Once container ships with items dock, all this may change too. I wonder if future tariffs may affect this?
    When mine shows up I'll be posting more.
  • Rubicon99
    • 3311
    Good information 👍👍.
    • SoCalBobS
      • 2717
      Mine has arrived. I was most interested in the actual size compared to other 1/16 tanks. I took two photos next to a Mato Panzer III to show this. As you can see, it's a bit shorter and lower.
      I did a little drive around. On concrete it's very "skittery", likely due to its large track to ground area, metal tracks and powerful gear train, the last I'm sure is the same as their monster M109. On dirt it's still lively, but a lot tamer. There are control adjustments I'll play with in a bit.
      There is no bb function. The barrel has an orange LED flash when fired.
      The barrel elevation has been improved. It acts like it's servo operated, but it stays where it's placed. A good thing.
      I'm using their USB charger to see how long a charge takes, but I'm sure I'll be opening it up to install a stronger removable battery soon.
      Out of the box, track tension is different from side to side, so I'll be adjusting that soon too.
      Once I open it up, I'll post pictures of what I see.
      • Rubicon99
        • 3311
        Please for the love of god cut those side skirts off as soon as possible....
        In all seriousness I am happy to see you got yours in and looking forward to seeing it in person soon.
        • SoCalBobS
          • 2717
          Ok, I can never leave good enough alone! I opened it up. Here's a photo:
          Before I go on, let me say that the tank is good out of the box. The modifications I'll describe are just what I like to do.
          As you can see, space is very cramped. The battery is a half size type, tucked under the motors in front, permanently. Charging is accomplished through the balance tap. An extension cable comes from the battery to a plug mounted on the rear deck. Everything is zip tied and spiral wrapped.
          Why did I open this so soon? Because the IR flash LED wasn't tripping my IR target. It turns out the bulb had gotten loose from its mount in the mantlet and was laying loose in the hull. The LED works, it just needs to be put back (or replaced with a HP LED). A minor matter.
          Here's the big thing, though. I like to charge my Li-Ion batteries out of its vehicle - a personal preference. Also, I use batteries with more capacity, 3500mah Admirals and I like to be able to swap them out if I run them down at an event. Moving them in and out from the front wasn't possible. My photo shows an empty area at the back of the hull tray. However, the smoke unit fits in there when the hull is buttoned up. I've had to remove the unit, which is a shame because they're fun now and then. Anyway, I'll be placing my battery there.
          • RichJohnson
            • 1276
            Does it have a servo recoil and or elevation?
            which mfu does it have?
            so far my m60s have come with
            TDC-x
            TD 1.0
            TD 2.0
            • SoCalBobS
              • 2717
              TD 3.0 Receiver.
              TD 3.0 Transmitter.
              Servo recoil.
              Servo Elevation.
              Nary a moment between thought and deed:
              Side skirts removed.
              • Rubicon99
                • 3311
                TD 3.0 Receiver.
                TD 3.0 Transmitter.
                Servo recoil.
                Servo Elevation.
                So much better looking with the skirt off👍👍👍
                • RichJohnson
                  • 1276
                  Have you now tested interoperability with HL IR battle tanks?
                  • SoCalBobS
                    • 2717
                    No.
                    Update: a hopeful yes it does. I put the stock mushroom on the M24 and shot at it with a HP LED equipped tank, inside a garage. The M24 registered 6 hits and went to "died" mode. I did this a few times from a couple of angles. Also, earlier I fired the M24's IR LED and it registered on a target. What I can't say until I install a Lego DEI is at what range it will take hits, or if the LegoDEI will be compatible with the MFU. I also won't know what the TD IR LED range is. That will have to wait.
                    Also, I ran the M24 around to about 90 feet away and the radio range was working fine. I'll test it further in some open ground on sunday.
                    Update #2:
                    I hooked up a LegoDEI to the MFU and it worked fine, at least at garage ranges.
                    • SoCalBobS
                      • 2717
                      Unpainted but ready for field trials Sunday.
ID:	414637 Click image for larger version
ID:	414638 Click image for larger version
                      First to go will be those radio antennas. I already cut down the tow hooks in front. As stock, they didn't last 30 feet before breaking off - like just about every other tank I own.
                      • SoCalBobS
                        • 2717
                        Major Milestone:
                        The Tiger Face has been painted (by hand, no decals). Touchups, weathering and accessories to come.
                        Click image for larger version  Name:	TD M24 Chaffee 10.jpg Views:	0 Size:	144.2 KB ID:	415684 Click image for larger version  Name:	TD M24 Chaffee 08.jpg Views:	0 Size:	226.8 KB ID:	415683 Click image for larger version  Name:	TD M24 Chaffee 09.jpg Views:	0 Size:	222.6 KB ID:	415685 Click image for larger version
                        • DavidN
                          • May 2021
                          • 3189
                          • Los Angeles, CA
                          Amazing work!
                          • SoCalBobS
                            • 2717
                            My first day out. This is the Chaffee at the January 19, 2025 San Diego Tank Battles event driving around in the dirt. It did very well, considering all those big tank bullies picked on it!
                            • tank_me
                              • Feb 2022
                              • 1182
                              But it looks fierce...lol.
                              • rampage
                                • 45
                                Finally an M24!
                                Is it possible to raise the suspension ride height? It looks like it's sitting on its bumpstops. Otherwise it looks amazing.
                                • DavidN
                                  • May 2021
                                  • 3189
                                  • Los Angeles, CA
                                  Here is my Tongde M24. It has been raining in Southern California for 2 days. I might as well finish this tank. It is ready for IR battle now. Unlike HL, it has 2 different MGs that lid up.
ID:	419800 Click image for larger version
ID:	419801 Click image for larger version
ID:	419802 Click image for larger version
ID:	419803 Click image for larger version
                                  • DavidN
                                    • May 2021
                                    • 3189
                                    • Los Angeles, CA
                                    • Rubicon99
                                      • 3311
                                      Adding mine to this thread.
ID:	419873 Click image for larger version
ID:	419874 Click image for larger version
ID:	419875 Click image for larger version
                                      • rampage
                                        • 45
                                        These all look so good...
                                        It's been a long time since I've done anything tank-related. Are the V3.0 control boards on these good? Last I was looking into tank stuff the Open Panzer boards were all the rage - even if like half of them were defective. I had heard they were going to have them produced by someone else but I'm not sure if that ever happened. I just loved the idea of the programability of those. Dial out the neutral steer and stuff like that. Is any of that possible with these newer V3.0 boards?
