I purchased a 1/16 German Leopard RC tank 2A6 MBT from an online store (www.motionrc.com) and received it today (Dec. 17, 2024). When I opened the box to inspect the tank I noticed that a battery compartment with 2 screws are missing. The instruction manual shows battery compartment is located underside of the tank but there is no battery compartment/cover. Is the battery compartment located somewhere else on the tank?
Missing Battery Compartment??
OK, that's a little strange, I'd call MRCs tech support tomorrow, it's either a fluke or some freakish design change no one bother to tell anyone about -
MRC advertises the Leopard as having torsion bar suspension. This prohibits a bottom access battery box. Does the manual cover this new development, say with an addendum or...? For instance, the Tongde tanks that have torsion bars require opening the hull or charging in situ because of this.The more screws it takes to reassemble a tank, the more likely it is you left something out!Comment
There is a video on MRC that explains this, at about minute 6:00. Also, it's mentioned that there is an addendum with the manual explaining this. Perhaps yours didn't have it?
Buy Heng Long German Leopard 2A6 Winter Camo Upgrade Edition 1/16 Scale Battle Tank - RTR online at Motion RC. Order online with fast delivery.
By the way, I use MRC's Admiral 3500mah battery packs. They're good for at least a couple of hours of running.The more screws it takes to reassemble a tank, the more likely it is you left something out!Comment
