How to remove barrel on tongde M63 update?
Barrell remove
There is no Tongde M63 tank. Is it a typo? Are you thinking about the Tongde Sherman M36?
The articifical remote control tank series is a high-end collection level. Tanks contain the material of metal, metal plus plastic, all plastic and so on, what′s more, configuration can be customized, static and movable. 1: 16 has highly-simulated, acousto-optic effect, with in-situ infinite rotation, turret rotation *, barrel lifting *, slope climbing, simulation of recoil force, simulation of smoke and other functions; With independent suspension shock absorber system; Which can launch live ammunition or infrared, support multiple aircraft combat; Strong compatibility, support DIY modification, support customization. The one-to-one exclusive customer service will bring better and more intimate user experience for tank enthusiasts.
You are in luck. The Tongde M60A3 is a well covered model on this forum. @Robinco99 has a detailed write-up on the barrel recoil update.
TD M60 A3 review. - Hobby Squawk RC Forum for Airplanes, Boats, Cars, Helicopters, Tanks, and TrucksFinally got in a metal version TD M60A3. Unfortunately things are not starting off well. It arrived with a broken main gun mount, broken rear engine exhaust panel and jammed left side gearbox. On a positive note the gears are steel and the gearboxes are all have bearings. Also the arrangement is the same as used in HL
US M60A3 Upgrade Edition 1/16 Scale Battle Tank - RTR from Tongde - TDE1001-001 (https://www.motionrc.com/products/tongde-us-m60a3-upgrade-edition-1-16-scale-battle-tank-rtr-tde1001-001) The specs and images shown are for the upgrade edition. The professional edition comes with metal upgrades and can be found here
