Does a recoil bb unit exist for a H L Panzer III? If not, has anyone modified one to work on a Panzer III?
H.L. Panzer III recoil BB
Tags: None
A generic trigger motor barrel recoil is cheap and readily available. You will have to adapt your existing barrel from the Panzer III.
Buy Heng Long 1/16 Scale Tank Airsoft Shooting and Recoil Unit online at Motion RC. Order online with fast delivery.
A metal servo recoil is significantly more expensive than the trigger motor one. There are many post about their difference that you can look up.
I have the trigger motor recoil on most of my HL tanks. Good enough for me. The adaptation includes cutting the existing barrel and tap a screw hole. It is easy if you are mechanically handy. -
You can find some examples of the BB recoil adaptation in this thread. I no longer have the HL Panzer III. My work on a very old Pershing is as complicated as it can be. It should be much easier if your Penzer III is newer.
A few days ago, I posted on a Heng Long Metal Barrel Recoil BB shooting unit for 3838 Pershing upgrade kit that I purchased for my 2005 Snow Leopard. I said that over 18 years, HL changed the cannon mantle mounting plate enough that the kit does not fit my Pershing. I contact the Toucan seller (build-for-u) to request a return.Comment
.png)
