Question about 7.0 main board fried and 7.1
  • traviswestra
    • Jul 2025
    Hello,
    I was experimenting with the cannon firing function because it wasn't working properly, and I accidentally plugged it into the wrong port, which caused my main board to start smoking. I quickly removed the battery—something I should have done before tinkering with the board. Unfortunately, it’s now non-functional, so I need to get a new board. I'm considering whether to upgrade to a 7.1 board, but I have a couple of concerns. First, will it connect with my 7.0 transmitter? Second, the connection point for the wire that links to the battery looks different from my 7.0 board. Is there an adapter available, or will I need to solder?
  • cmdrcody
    "Grumpy"
    • Dec 2022
    • 228
    • Largo, FL USA
    You will need to get a 7.1 transmitter. There are adaptors for battery connections.
    • keilau
      • Mar 2021
      • 1815
      • Windy City
      Originally posted by traviswestra
      Hello,
      Can you identify the TK7.1 function you want from the upgrade? If not, stick with the TK7.0 which is cheaper and more reliable. Just remember not to connect any port incorrectly.
      Which HL RC tank do you have? If you still want to upgrade to TK7.1, you will need to also upgrade the tank canon to servo barrel recoil unit. The TK7.0 transmitter works fine with the TK7.1 MFU. You just need to bind them one more time.
      Heng Long evolved the battery connector from Tamiya plug to T-connector to XT60. Adaptors are cheap and readily available, but shipping for single item mail order is not cheap. When you order the new MFU, tell the seller what battery plug do you have and ask them to quote you the adaptor needed. If you still use the short running HL OEM battery, you may upgrade to better battery with the correct connector.
      Shop battery to ESC adapters at Motion RC. Explore BenchCraft XT60, XT90, EC3, EC5, Traxxas, Tamiya, JST and T-Connector adapter cables for RC power systems.
      • MrChef
        • Jan 2023
        • 501
        • New York, Not the city
        He doesn't "need" to get a 7.1 transmitter. The 7.0 transmitter works fine with the 7.1 MFU unless he wants to use the extra servo function beyond recoil and elevation.
        • cmdrcody
          "Grumpy"
          • Dec 2022
          • 228
          • Largo, FL USA
          You are correct. For FULL function of the 7.1 MFU you WILL need the 7.1 transmitter.
          • DavidN
            • May 2021
            • 3189
            • Los Angeles, CA
            Since we are on this subject, Can anyone share with me on what exactly does the 7.1 transmitter can do? I have been using the 7.0 transmitter on my 7.1 boards. So I wonder what is the difference between the 7.1 and 7.0 transmitter. Thank you!
            • SoCalBobS
              • 2716
              • Southern California
              7.1 transmitter has one of its trim tabs actually move, not just a molded part of the case. It’s the bottom right one. You can use it to control a function. I use mine to control a servo that traverses the commanders cupola on my M60.
              • DavidN
                • May 2021
                • 3189
                • Los Angeles, CA
                Thanks Bob! That's quite cool.
                • tank_me
                  • Feb 2022
                  • 1182
                  I use a 7.1 transmitter on my M1128 MGS wheeled vehicle. The trim acts as an actual trim on that vehicle for the wheels.
                  • MrChef
                    • Jan 2023
                    • 501
