Tongde M113A1 ACAV Detailing
  • tdriver113
    • Apr 2023
    • 107
    • Peoples Republik of Illinois
    I purchased the all metal pre painted version of this model with the idea of just running it as is without any modifications that I would do on previous RC models. I thought it would be a welcome break from all the work tearing something apart to make a more accurate model. This worked really well for a while until I came across a thread on M113 modifications on the rctankwarfare UK site. Several gentlemen there have posted their efforts at detailing various M113 RC models. And I was hooked. Again. The Tongde kit is overall a great running setup but there were several minor things about the model that were annoying. The .50 cal MG shield mount kept falling apart. The rear M60 MG shields were a little wobbly and not sitting at the right angle. The ACAV turret had some interesting features that didn't accurately resemble the real thing.
    So off I go with some detailing using the Andy's Hobby M113A1 kit for a parts donor.
  • tdriver113
    • Apr 2023
    • 107
    First thing I did was strip down the hull and remove all the speaker, main board, smoker, and related wiring. Also removed the turret mechanism and cut down all the mounting points.
    • tdriver113
      • Apr 2023
      • 107
      Next, I test fitted the various parts from the AHHQ kit. This included hull sponson top and side covers where the rear seating and other parts are attached. Also test fit the firewall between the engine and crew compartment and the hull floor access plates to see what needed to be trimmed or cut down to fit.
      Click image for larger version  Name:	2.jpg Views:	0 Size:	180.2 KB ID:	450653
      • tdriver113
        • Apr 2023
        • 107
        I cut down the kit side wall to fit between the firewall and the rear panel on the right side. This also shows the seating attachment panel on the side of the hull. And a test fit of the battery box to see how much of the rear support bracket needs to be trimmed.
        • tdriver113
          • Apr 2023
          • 107
          I cut down and fitted the side panel on the drivers side. Test fitted the seating panel on the lower hull and the fuel tank. The fuel tank was notched to retain the original rear panel support bracket. This shows the side panel extended all the way to the front, but I found it did not fit with the actual hull dimensions. I cut it back to the firewall area in anticipation of mounting the battery there instead. First plan is to put the speaker in the fuel tank. More on that later.
          • tdriver113
            • Apr 2023
            • 107
            With everything test fitted and checked for clearance I started to permanently attach the parts, starting with the firewall. I set it forward as far as I could next to the motors. It was shimmed on the bottom and braced with a piece to help support the floor panel.
            • tdriver113
              • Apr 2023
              • 107
              The AHHQ kit sides were fixed flush with the outer edge and the rear body of the Tongde hull. Then the sponson covers were fixed to the hull and aligned with notches along the bottom edge. The Tongde upper hull will fit over it. A hull within a hull.
              • tdriver113
                • Apr 2023
                • 107
                The troop seats and the floor were next. Both had to be removable to allow access to the suspension parts. The kit has 2 pieces on each side to mount the seats with. There is an upper piece that is fixed to the top and a bottom L shaped piece that the seat brackets sit on.
                This is the top piece, right side. The 4 small posts are what the seats will fasten to.
                The bottom L shaped piece.
                Test fit with the floor set in place.
                • tdriver113
                  • Apr 2023
                  • 107
                  I cut a piece of very thin plastic sheet and made it the same size as the lower hull side and temporarily set it in place. Then I lined up the 2 pieces and glued them in. Next came the seats glued to those 4 small posts and then all the legs for the seats were added. It turned out to be a strong assembly that should hold up to handling.
                  Seat assemblies mounted on the plastic sheet.
                  Click image for larger version  Name:	seat1.jpg Views:	0 Size:	105.1 KB ID:	450694
                  Here's the back side showing the plastic sheet holding it all together. One end is notched to clear the idler mounting bolt.
                  Click image for larger version  Name:	seat2.jpg Views:	0 Size:	68.6 KB ID:	450695
                  After a quick test paint.
                  Click image for larger version  Name:	seat3.jpg Views:	0 Size:	189.9 KB ID:	450696
                  • tdriver113
                    • Apr 2023
                    • 107
                    Here's what I used for my thin plastic sheet trick. It's a for sale sign from Menards. Very thin plastic that takes plastic glue very well. They are very handy for small fill in and shim use.
                    • RichJohnson
                      • 1276
                      I like what you have been doing with this detail job. I didn’t do anything with my Tongde as it was a prototype for my M901 kit, my recoilless rifle upgrade for the ACAv and the ADATS turret kits I produced. I also imported a couple dozzen of them before motion received theirs.
                      Just before the Tongde was announced I was building a DKlM 3d printed one that is an M220 with the tow. I detailed out the interior as best I could based on photos but didn’t finish the tow tubes rack or personnel standing platform.
                      • tdriver113
                        • Apr 2023
                        • 107
                        Thanks Rich, for your interest in my project. The body style on these with a large cargo hatch and rear ramp are just right for a detailed rear compartment and the AHHQ kit makes it a lot easier than scratch building everything. A couple of your detail parts will show up a little later in the build to replace inaccurate parts.
                        This is also a little trip down memory lane for me. I drove a standard M113A1 a very long time ago in the late 70's.
                        • tdriver113
                          • Apr 2023
                          • 107
                          Now for the floor. The AHHQ kit piece is about a 1/4 inch too long. I choose to cut it down on the ramp end to keep the commanders seat assembly mounting notch somewhat in a correct position related to the turret.
                          Here's the test fit.
                          Click image for larger version  Name:	FL1.jpg Views:	0 Size:	230.3 KB ID:	450749
                          And the trimmed piece. You loose the hold down bolt and washer detail.
                          Click image for larger version  Name:	FL2.jpg Views:	0 Size:	71.1 KB ID:	450750
                          I added the missing bolt detail back with small washers and some 1mm bolt heads left over from my gun truck project. I also added the notch on the right side for the bilge pump discharge tube and the ramp pulley assembly on the left.
                          Click image for larger version  Name:	FL5.jpg Views:	0 Size:	216.4 KB ID:	450751
                          Click image for larger version  Name:	FL6.jpg Views:	0 Size:	130.3 KB ID:	450752
                          A placement and paint test. Not to sure about the interior color.
                          Click image for larger version  Name:	RMP1.jpg Views:	0 Size:	128.1 KB ID:	450753
                          • tdriver113
                            • Apr 2023
                            • 107
                            The factory ramp magnets were removed and 15mm x 5mm x 3mm thin block magnets installed in their place. This allows the new inner ramp cover to fit flush and improves appearance.
                            New magnet.
                            • tdriver113
                              • Apr 2023
                              • 107
                              The door handle is mounted in the wrong location on the door instead of the ramp. I drilled a new hole a size smaller than the pin to give a good press fit. The handle is operational. The hole in the door was patched with a small piece of thin plastic that also adds a little pressure to help keep the door closed.
                              Click image for larger version  Name:	RH.jpg Views:	0 Size:	52.6 KB ID:	450956
                              Click image for larger version  Name:	RH2.jpg Views:	0 Size:	102.5 KB ID:	450957
                              • tdriver113
                                • Apr 2023
                                • 107
                                The small patch is similar to the actual door mount.
                                • tdriver113
                                  • Apr 2023
                                  • 107
                                  The inside ramp panel from the AHHQ kit is almost a drop in. A slight trim on the sides and bottom and it slides right in. That and the door panel were shimmed to fit flush and glued in place.
                                  Click image for larger version  Name:	R11.jpg Views:	0 Size:	127.7 KB ID:	451002
                                  Click image for larger version  Name:	R22.jpg Views:	0 Size:	105.4 KB ID:	451003
                                  Click image for larger version  Name:	R33.jpg Views:	0 Size:	96.3 KB ID:	451004
                                  Click image for larger version  Name:	R44.jpg Views:	0 Size:	97.2 KB ID:	451005
                                  • rb67mustang
                                    • May 2026
                                    • 290
                                    • People's Republic of Rhode Island
                                    You're like me, I'll use anything to scratch build with that's priced well and gets the job done!!!
                                    • rb67mustang
                                      • May 2026
                                      • 290
                                      Driver, you're doing a great job making you M113 represent the actual full scale version. If I could like your thread I certainly would if I could figure out how to do it.
                                      I hope your M113 still has the room for all the RC gear and wiring!!!
                                      • tdriver113
                                        • Apr 2023
                                        • 107
                                        The original plan was to place the main board in the front above the drive motors. The speaker is mounted in the fuel tank and a new smaller battery from Motion RC fits up in the driver seat area. I removed the smoke generator and the turret traverse box. The turret on a real M113 is not motorized, and I needed the room.
                                        After some testing of this setup I think I am going to change it to a modular piece. When you are running this around, you don't see anything inside unless you leave the cargo hatch open. I'm going to make a second floor setup that mounts the main board, speaker, battery, and maybe the smoke generator for running and then swap in the detailed parts for display.
