Tongde M113A1 ACAV Detailing
  • tdriver113
    • Apr 2023
    • 110
    • Peoples Republik of Illinois
    I'm using the M2 gun shield from the AHHQ kit because it has the mounting bracket already and fits with a little modification.
    Click image for larger version  Name:	T1.jpg Views:	0 Size:	74.1 KB ID:	451032
    Click image for larger version  Name:	T2.jpg Views:	0 Size:	74.9 KB ID:	451033
    For the M60 side mounts I used the Tongde parts. The AHHQ kit parts are too fragile to use on a RC vehicle. I cut back the bottom corners so the shields could be angled back, instead of sitting straight up. Plastic reinforcements were added to make a more solid connection. Not to scale but I wanted something solid to hold up to handling.
    Click image for larger version  Name:	60-1.jpg Views:	0 Size:	59.9 KB ID:	451034
    Click image for larger version  Name:	60-3.jpg Views:	0 Size:	73.0 KB ID:	451035
    Click image for larger version  Name:	60-4.jpg Views:	0 Size:	98.1 KB ID:	451036
    • rb67mustang
      • May 2026
      • 290
      • People's Republic of Rhode Island
      Originally posted by tdriver113
      The original plan was to place the main board in the front above the drive motors. The speaker is mounted in the fuel tank and a new smaller battery from Motion RC fits up in the driver seat area. I removed the smoke generator and the turret traverse box. The turret on a real M113 is not motorized, and I needed the room.
      After some testing of this setup I think I am going to change it to a modular piece. When you are running this around, you don't see anything inside unless you leave the cargo hatch open. I'm going to make a second floor setup that mounts the main board, speaker, battery, and maybe the smoke generator for running and then swap in the detailed parts for display.
      That sounds like the best of both worlds!!!
      • tdriver113
        • Apr 2023
        • 110
        Next I added the MG ammunition feed tray parts and the front hinged plates. After adding those, the reinforcement pieces and the M60, the original mounting tab was overloaded. I cut the pin off, drilled out the same spot and added a M2mm screw and a nut to make a firmer mount.
        Click image for larger version  Name:	S2.jpg Views:	0 Size:	86.9 KB ID:	451042
        Click image for larger version  Name:	S4.jpg Views:	0 Size:	63.8 KB ID:	451043
        Click image for larger version  Name:	S3.jpg Views:	0 Size:	93.0 KB ID:	451044
        Now even with the M60 the shield bottom plate is straight and movable.
        Click image for larger version  Name:	S5-0.jpg Views:	0 Size:	118.4 KB ID:	451045
        • tdriver113
          • Apr 2023
          • 110
          I did a test fit of the leftover hull floor section from the AHHQ kit turned into my modular set up. Room for the board, speaker, and my blue tooth speaker so I can play " Fortunate Son " on request.🫡
          • rb67mustang
            • May 2026
            • 290
            Tdirver113, As often as I can, I like to add screws to make what was a static detail become movable details just as you have done here.
            • rb67mustang
              • May 2026
              • 290
              Tdriver113, I hope you don't mind me saying this but, I'm thinking, either you're a Vietnam Vet, or maybe your Dad, or an uncle was because of your interest in this specific war. I'm more interested in WW-II because three of my uncles served in WW-II. Another uncle served in the Korean war, my dad was in the US Army during the clod war, and my youngest uncle served in Vietnam. My youngest uncle is the only one still living today, and I've never heard him say what he did in that war. Myself, I was thinking to join the Navy after I graduated High School, but because the High School I attended had a big vocational wing, I had a great job as a Machinist upon graduation. So, I missed out on possibly becoming a Machinist Mate in the US Navy.
              • tdriver113
                • Apr 2023
                • 110
                No, I'm not a Vietnam vet, but I served with a lot of them. I enlisted after high school in 1976. Served as a Combat Engineer in an Armor unit and was a M113A1 driver for 2.5 years. Then I was a heavy equipment operator in a Heavy engineer battalion in the reserves for 6 years. In basic training all the drill sergeants were Vietnam vets and most of the senior Nco's and officers in my first unit were all Vietnam vets. Couldn't have asked for a better group of men to serve with.
                This gave me the opportunity to operate or ride in a lot of military vehicles from that era which comes in handy for modeling purposes.
                Best Job I Ever Had.
                • rb67mustang
                  • May 2026
                  • 290
                  WOW!!! Best job you ever had!!!!!!! I wish I could say the same thing. I'm a class of 78 graduate.
                  Well, at least I thought you may have been an M113 driver, per your screen name.
                  I may have a great solution for you to create possibly and Decals you need.
                  I bought a Star paint mask sheet on Ebay. The sheet consisted in three different sizes, and all had the split circles. I didn't want the circles for the 4x4, or my 1/6 M5 Stuart.
                  This seller had many masks with flames and strip patterns. Maybe this seller could make a custom mask to suit your needs???
                  I'll check my Ebay purchases, and I'll share a link with you.
                  • rb67mustang
                    • May 2026
                    • 290
                    Here's the link. SYB1000P Army Star RC Body Vinyl Paint Mask/ Stencil Kit | eBay https://share.google/zTU1Le9JoHzn05FTc
                    • rb67mustang
                      • May 2026
                      • 290
                      If this seller doesn't do custom masks, here's another possible solution.
                      Have you ever heard of the Cricut machine? I don't expect you to buy one, but here's a link so you can check it out.
                      Possibly someone on Etsy may do custom masks.
                      If you search Commietube, you'll find tons of videos of guys making custom masks so they can paint on the marking instead of using decals.
                      Have a great day, Tdriver113!!!
                      • tdriver113
                        • Apr 2023
                        • 110
                        I'm going to give this set a try. I like the idea of paint versus decal.
                        • tdriver113
                          • Apr 2023
                          • 110
                          On to the cupola armor. The Tongde pieces are pretty good, except for a tab sticking up in front of the TC's face. I couldn't find any pics of this in actual use so it will be removed. And the MG gun mount will be improved.
                          Click image for larger version  Name:	56687-0.jpg Views:	0 Size:	25.8 KB ID:	451132
                          I also added the clearance notch on the lower left part of the armor. I believe this allows the Mg to swing fully to the left.
                          Click image for larger version  Name:	TC1.jpg Views:	0 Size:	57.1 KB ID:	451133
                          The top right side correct shape .
                          Click image for larger version  Name:	TC2.jpg Views:	0 Size:	50.0 KB ID:	451134
                          • tdriver113
                            • Apr 2023
                            • 110
                            I used cut down pieces from the AHHQ kit as a template and filler.
                            Marked for the notch cutout.
                            • tdriver113
                              • Apr 2023
                              • 110
                              Notch piece installed.
                              I added the armored covers for the vision blocks from the kit.
                              • tdriver113
                                • Apr 2023
                                • 110
                                I used the kit MG instead of the Tongde one. The kit cupola assembly would have been a nice addition but there was a problem with fitting it to the existing opening. Tolerance was so close it would have required alteration of the roof opening to make it moveable, or just glue it in place. Staying with the OEM one and upgrading it made more sense and provided a more solid piece.
                                • rb67mustang
                                  • May 2026
                                  • 290
                                  I think you're going to like paint masks after you try them the first time. I used a rattle can of white primer to paint the stars on my 1/6 Stuart, and the 4x4.
                                  • rb67mustang
                                    • May 2026
                                    • 290
                                    Your detailing is coming along quite nicely!!! It looks like you're using automotive spot putty where you need it. I've used it before, but the tube hardened due to age. The small half full can of Bondo is still good, and it works just as good.
                                    • tdriver113
                                      • Apr 2023
                                      • 110
                                      A few small details.
                                      I drilled out the location for the front bilge pump outlet. The front radio antenna mount was drilled out and fitted for one of Rich Johnsons excellent scale antennas which will be added when all the other work is done. I replaced the fire extinguisher pull station with the one from the AHHQ kit.
                                      I added the cargo hatch release parts from the kit. These parts are quite fragile and broke in 2 spots removing them from the sprue. I had to shorten it to fit and used some heat shrink tubing to hold it together. The original part has a cover on it, it's just a little thicker now.
                                      For the ramp I added the tow pintle and the tow hook mounts from the AHHQ kit. Then I replaced the rear light parts with a set from Rich Johnson. I cut small clear plastic pieces from some packaging to simulate the lenses and used some white paint for the lower blackout light cats eyes and clear red on the upper stop light on the left side. The right side was all white for the cats eyes. The rear bilge pump discharge tube was added on the upper right hull. You can see the original light holes are now used for screws to hold the top in place. They attach to L shaped brackets mounted to the roof, replacing the inside mounting posts. I need to counter sink them a bit more.
                                      • tdriver113
                                        • Apr 2023
                                        • 110
                                        Worked on fitting the intake and exhaust screens from the AHHQ brass parts included in the kit. The intake screen was a direct fit. The exhaust screen would not work because it has a slight offset that matches the real screen configuration. I found a replacement piece of fine mesh screen on Amazon that worked as a replacement.
                                        Intake screen.
                                        Exhaust screen.
                                        Kit parts.
                                        Painted screens.
                                        Set in place.
                                        Here is the replacement mesh. They have several sizes to chose from.
                                        • tdriver113
                                          • Apr 2023
                                          • 110
                                          I'm using the Tongde ACAV trim vane piece and one extra flotation cell from the AHHQ kit. You can see on the bottom left edge, I had to do the mounting pin upgrade on the trim vane when the original tab broke off. For the driver side I'm using the track links from the kit. They have a better level of detail than the OEM ones.
                                          Click image for larger version  Name:	Trim vane.jpg Views:	0 Size:	88.2 KB ID:	451536
                                          The lights are a bit of a disappointment. For some reason Tongde made them angled downward instead of straight ahead. This would have required way more work to fix , so I'll leave them stock. I did add the blackout drive headlight cover and will be adding lenses to fit and match originals and add some stowage behind them to fill in the gap. I filled in the huge holes for the headlight wires with some hot glue so it is removable if needed. I will move the headlights to the correct spot and disable the turn signal function.
                                          Click image for larger version  Name:	Lights.jpg Views:	0 Size:	33.4 KB ID:	451537
                                          Actual light positions.
                                          Click image for larger version  Name:	Lights-L.jpg Views:	0 Size:	50.7 KB ID:	451538
                                          Click image for larger version  Name:	Lights-R.jpg Views:	0 Size:	59.5 KB ID:	451539
                                          And I added the belly armor from the AHHQ kit with a bit of modification trimming it down and using just the front leading edge.
                                          Click image for larger version  Name:	armor.jpg Views:	0 Size:	31.0 KB ID:	451540
