Coolbank Stuarts?
  • NCO Retired
    • Jul 2026
    • 45
    • Mid-state Illinois
    Coolbank Stuarts?
    Those that have one, has anyone removed the side Armor plating? If so, how did it come out?
    Thanks..........
    Ed
  • SoCalBobS
    • 2716
    • Southern California
    Many of us have. Dremel is on the job!
Name:	M5 Stuart in Hedgerow Country.png
    • NCO Retired
      • Jul 2026
      • 45
      Of course, a Dremel, didn't click, senior moment 🙄, Exacto knife did though. Thankyou.............
      • NCO Retired
        • Jul 2026
        • 45
        Click image for larger version  Name:	M5 Stuart in Hedgerow Country.png Views:	0 Size:	2.08 MB ID:	451406
        I have been studying your work for a bit now, close up as much as I can. Hope mine turns out close to that, it's what I have in mind, I do plan not to have the hedge cutter on it. The Stuart and the Walker have always been my favorites. There is a Stuart on the grounds of the Quincy Veterans Home in Quincy Ill. I always spend a few minutes walking around the old girl when I visit.
        • SoCalBobS
          • 2716
          Thanks! I can see my flaws, though. The biggest issue is the type of plastic used for r/c tanks. It's much tougher than, say, plastic display models. Xacto blades would take forever, and Dremels can melt the plastic. Short runs with the rotary cutter, then Xacto blades can be used for fine finishing.
          The Coolbank hedgecutter is a snap on/off item. I put it on for display, but remove it for outdoor running.
          Another view of the cut line:
          • NCO Retired
            • Jul 2026
            • 45
            The old saying goes, one's worse critic is themselves. What I see is a goal for me. Thanks for the photo.
              • 7337
              Hi guys, I borrowed a partial body tanker figure from Dave Geee to see how they were to work on. 1/16th scale in a couple of hours.
              First hour:
ID:	451424 Click image for larger version
              Second hour, time for a break!
              • NCO Retired
                • Jul 2026
                • 45
                First hour:
                I see my tankers will be in good hands.....Ed
                • NCO Retired
                  • Jul 2026
                  • 45
                  Click image for larger version  Name:	IMG_1357.jpg Views:	158 Size:	158.8 KB ID:	451413
                  Hey Bob, had the Stuart for awhile now and I still haven't came up with the nerve to try and remove the side plating. Being almost 80, going on almost 100, the hand just isn't as study to trust a Dremel to go where I want it to. I'm thinking about trying this:
                  Click to see full view Ask Alexa
                  • What materials can it cut?
                  • Does it come with a carrying case?
                  • SponsoredWhy choose HOZO ultrasonic cutters?
                  • Is it rechargeable?
                  • Why you might like this
                  • Ask something else
                  NeoBlade Wireless Ultrasonic Cutter – 40kHz Vibration & 40W Auto Power Adjustment, Replaceable Battery, Turbo Cooling, 2 Cutting Modes – For 3D Printing, Woodworking, Prototyping,Model Mods & DIY
                  • NCO Retired
                    • Jul 2026
                    • 45
                    It's a bit expensive but had a lot of Amazon points that makes it almost free. I've ordered it and we'll see!!!
                    • SoCalBobS
                      • 2716
                      I've seen it, was interested, but it does cost a lot. Let us know how it works. You might still make a rough cut with the Dremel, leaving enough to trim off with the Hozo.
                      • NCO Retired
                        • Jul 2026
                        • 45
                        Will do Bob. I will do some practicing on related non-important items first to get a feel about it. It arrives tomorrow, busy though, it will be Saturday before I can get to it.
                        Ed
                        • NCO Retired
                          • Jul 2026
                          • 45
                          I'm not able to give you a review on the ultrasound cutter today as planned, it does not work. Returning it and have purchased a different brand but by sight only I can see how it could be an asset, just need to find the right one. I did receive a micro sander by the same brand, it's working just fine.
                          HOZO NeoSander Reciprocating Detail Sander, Mini Electric Pen Sander with 13000 SPM Linear Motion, Adjustable Stroke for Precision Sanding, Ideal for 3D Printing, Model Making, Crafts & DIY Projects
                          • NCO Retired
                            • Jul 2026
                            • 45
                            A less expensive way to go....add this to the above Neo-sander:
                            NeoSander Saw Blade Set, Turns NeoSander into Mini Reciprocating Saw, 8pcs 0.2mm Anti-Binding Blades, 4 Curved Blades for Straight Cuts & 4 Jigsaw Blades for Curves, for Resin, Plastic & Wood
