From Pershing to Patton in Three Not So Easy Steps
  • AFT-CAP21
    • Feb 2024
    • 24
    • Tennessee-North Carolina Border
    For a long time, I’ve been waiting for one of the RC Tank Manufacturers to offer one of the early Pattons like the M46 or M47. I finally got tired of waiting and decided to build my own, selecting an M46 for the project. The M26 Pershing and M46 Patton are very similar, sharing the same turret and front-half of the hull. The US Army’s first M46 Pattons were actually converted from Pershings. So, I purchased a Heng Long M26 Pershing from MRC and got to work. Below are photos of the M26 as it originally appeared:
ID:	454193 ​ Click image for larger version
    To make the conversion, there are essentially three things I have to accomplish:
    • Move the Drive Sprocket up higher even with the Return Rollers
    • Re-Work the Engine Deck and Exhausts
    • Re-Work the Main Gun by re-locating the Gun-Mount, replacing the Muzzle Brake and adding a Bore Evacuator.
    I hoped that all the parts I would need could be designed in TinkerCad and produced with my Anycubic X6Ks 3D Printer. I knew the most challenging thing would be the new louvered engine-deck-panels. They're very complex on the M46, and getting them to fit onto the existing hull was not going to be easy.
    I decided that the first order of business should be to relocate the Drive Sprockets upward and slightly to the rear. After a bit of measuring, I determined that the Sprockets should be moved up to a new center-line located 27mm above the bottom of the hull to put the Sprocket in-line with the Return Rollers.
    After removing the original Drive Box, I cut a slot in the hull to allow the drive-sprocket to be moved upward, then sealed the original hole with a patch made from EVERGREEN plastic sheeting, and tidied it up with BONDO GLAZING AND SPOT PUTTY.​
    It was necessary to replace the original drive unit with a new Heng Long Middle/Low-Long Shaft Steel Gear Drive Box (HL G6020-008) to allow the Drive Box to be raised without it striking the underside of the engine-deck. I 3-D Printed two Wedges that supported the rear of the Drive Box at the correct height, leaving the front of the box still resting on the hull floor so it wouldn’t come in contact with the underside of the engine deck. I glued them in place and then screwed the Drive Box in on top of them. The Drive Box fit under the new Engine Deck . . . barely.​ ​
    ​With the new power-unit installed, there was no longer room for the exhaust unit to be installed behind it, so I re-located it forward and installed it in two pieces on either side of the battery box connected with a piece of brass-tubing.
ID:	454197 Click image for larger version
    From the Exhaust Smoke Box, a soft Plastic Tube carries the exhaust to a Box mounted to the underside of the Engine Deck where the exhaust is split in opposing directions and sent to the Silencers (Mufflers) on the two back fenders.
    ​After cutting off the M26 Exhaust Port, I printed a new rear panel to match the M46 and shaped it like a wedge to correct the rearward slope of the original panel, bringing the new panel to the vertical. Then it was a matter of using sheet plastic to fabricate the M46’s distinctive shape.
ID:	454199 Click image for larger version
    Shifting to the Upper Hull, I set about removing the Side-Skirts. I accomplished this using an Acrylic Sheet-Cutter and a Utility Knife. Although the real M46s were delivered with Side-Skirts installed, the crews quickly got rid of them as they made Track and Return-Roller maintenance harder and offered little in the way of protection. Besides, the tank looks much better without them.
    Next, I removed the rear fenders. I would hang onto them for modification and re-installation later.
    And then I cut out the existing engine deck.
    The new Engine Deck was Designed in Tinkercad in three pieces due to size limitations of the build-plate on my 3D Printer.
ID:	454204 Click image for larger version
    It took a few tries, but I eventually got the panels to match up with the new rear panel with a good fit. Designing them in TinkerCad was a bit tedious, but do-able. I then added new rear-fender panels upon which to mount the distinctive exhaust mufflers, and re-attached the original rear fenders (slightly modified).
    I 3D Printed the exhausts open-topped to make it easy to route the plastic tubes carrying the exhaust. The 3D Printed Covers hid the tubing nicely.
ID:	454206 Click image for larger version
    When the tubing was all in place, I gave it a test-run. It worked, but the exhaust-smoke has a tendency to follow the curve of the fender instead of billowing like a real exhaust. Haven’t quite figured out how to correct that yet. Perhaps I can devise some kind of diffuser that I can insert into the exhaust pipes. I welcome any suggestions.
    Here's a good place to pause. I'll pick it up again in a few days with the detail-work on the hull. Then, on to the turret.
  • AFT-CAP21
    • Feb 2024
    • 24
    Let me show you some of the Detail-Work on the Hull. All of these were designed in Tinkercad and 3D Printed. On the left are the Sponson Box Handles with Padlocks, along with Handrails. On the right is the Pioneer Tool Kit and the Tow Cables attached to the Tow Hooks. None of the markings you see are decals. They are all painted-on. I spray-painted the locations in white, then used CHARTPAK 1/4 inch Peel-and-Stick Vinyl Letters available on Amazon to create the markings. When they were in place, I spray-painted over them with Tamiya Khaki-Drab to match the tank, then peeled the vinyl letters away to expose the white paint beneath. The Stars and Armor Triangles were done the same way with Masking Tape.
ID:	454430 Click image for larger version
    On the left is a shot of the Engine Deck showing the Louvers, Grab-Handles and Hinges, and the Exhaust Covers. On the right is a detail shot of the markings on the Exhaust Covers and the Bolts, showing the detail possible with the Anycubic X6Ks Printer. Also, the Rust-Effects. Martin Kovac (Nightshift) has a great video on YouTube of how to do rust-effects on exhaust-systems, and lots of other stuff too.
Name:	M46 Engine Deck Detail B.jpg
ID:	454434 Click image for larger version
Name:	M46 Engine Deck Detail A.jpg
    On the left is a detail of the Rear-Panel showing the Access-Covers and a new Tow-Pintle. On the right you can see the Tension-Idler hiding between the Sprocket and the #6 Roadwheel. I was not able to work in a spring to put tension on the Idler, so it free-floats. That's okay. The Compensator on the Front Idler and #1 Roadwheel works so well as to make the rear Tension-Idler un-necessary. The Army eventually came to the same conclusion, deleting it on late-production M47s.
Name:	M46 Access Panels + Tow Pintle.jpg
ID:	454436 Click image for larger version
    On the next installment, I'll move on to the Main Gun and the Turret. Later, Ya'll.
    • AFT-CAP21
      • Feb 2024
      • 24
      Moving on to the turret, the first order of business was to apply Casting-Texture. This was done with Tamiya Putty mixed with Tamiya Extra-Thin Cement to form a thin paste, which I applied using a stiff-bristle brush. After letting it set for a couple of minutes, I used the tip of the stiff-bristle brush to rough-up the texture. This produced a texture that looks very much like Cast Steel.
      Next, I set about installing a new Main Gun Tube and configuring it for Servo-Recoil. First, I sawed off the original Gun Barrel from the Mantlet.
      Next, I drilled out the hole in the Mantlet to 1/2 inch diameter with a Countersink Bit and smoothed it up with a round file.
      The new Gun Tube was designed in Tinkercad and 3D Printed on the Anycubic X6Ks. I printed it in three pieces, and then cemented them together over a piece of Brass Tubing to add strength and keep them straight. A little Bondo Glazing and Spot Putty was added to hide the joints and sanded smooth.
      The next order of business was to fix the Gun Mount. Heng Long's gun mount wasn't even close to being accurate. They put the trunnion (pivot-point)inside the turret. The trunnions on both the M26 and M46 are outside the Turret, between it and the Mantlet. I started the fix by cutting away the Heng Long gun mounts inside the turret. I then modified the Inner Mantlet by 3D Printing new Gun Mounts and cementing them to the outside. I also cut larger holes in the Inner Mantlet to accommodate the IR Engagement Emitter and a coaxial machinegun, which I would move from the hull.
      Next, I added two 3D Printed Bushings, gluing them into place perfectly aligned with the New Gun Mounts added in the previous step.
      Next, I test-fit one of Rich Johnson's excellent Servo-Driven Recoil Devices. I cut-away the gun-mounts molded onto it as well. It fit perfectly into the Outer Mantlet.
      I then fitted all three pieces into place and drilled a hole on each side from the Outer Gun Mount, thru the Bushings, and into the Recoil Device, stopping just short of the hole for the new Gun Barrel, so as not to interfere with its recoil-movement. I then used a 3mm Socket Head Cap Screw inserted from the outside on both sides to secure the parts together. This allowed the gun to pivot at the correct place. I was able to get an elevation of positive 20 degrees and depression of negative 8 degrees, which closely replicates what the real tank was capable of (+20 degrees / -10 degrees).
Name:	M46 Trunnion Assembly.jpg
      Then I installed a Hitec HS65MG Servo to operate the Recoil Device. I kept the original elevation gear, with slight modification to allow it to match up with the Recoil Device. I also installed a Flash and Smoke Unit, though I had to locate the smoke pot for it in the hull, as the turret had become a bit crowded. I put the Pot on top of the speaker and the fan just forward of the speaker under a piece of sheet plastic.
ID:	454537 Click image for larger version
      Next time I'll cover the Turret Exterior Details. See Ya'll.
