Mini-Z 4x4 Jeep Wrangler Unlimited Rubicon Bright White 1/18 Scale 4WD Truck - RTR from Kyosho - KYO32521W
Mini-Z 4x4 Jeep Wrangler Unlimited Rubicon Granite Crystal Metallic 1/18 Scale 4WD Truck - RTR from Kyosho - KYO32521GM
Version Info: This truck is delivered as "RTR", however does require 4x AAA batteries for the transmitter, and 4x AAA for the chassis purchased separately (see Requires below for details).
The combination of the highly-detailed body and a completely new 4x4 chassis design opens up new levels of performance, well beyond anything RC enthusiasts have ever seen from a mini crawler.
In the signature Jeep® Wrangler lineup, the Rubicon boasts the strongest off-road performance. With black over-fenders, front grille with dark grey accent, and the distinctive Jeep® round headlights, the formidable styling of the black hard top is immaculately reproduced in a model that rests on the palm of your hand.
Your Kyosho truck is backed by Motion RC's world-renowned customer service and technical support. Drive on!
FEATURES:
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : 1 HOUR
Painted Body Fully pre-painted body looks like a luxury diecast car replica. The thicker body material also provides superior durability. |
| Matte Black Paint Matte black coating enhances the texture of the Freedom Top® and the black overfender that wraps the trapezoidal wheel arch. The highly detailed finish is applied to mirrors, wipers, door handles, tail light protectors as well as the bonnet grille, bonnet hood catch and radio antenna. |
Body Mount A newly-designed one-touch body mounting system is used instead of the mounts commonly used on all previous Mini-Z cars and trucks. The new system uses spring-wire retainers to quickly and easily install and remove the body. |
| Chassis and Geometry Details The same ladder frame and multi-link rigid-axle suspension commonly used in popular 1:10-scale off-road models, is condensed into Mini-Z size for the most articulation and performance available in any mini RC truck. |
Driveline The gearbox features molded covers and includes 6 pinion gears that allow adjustment from ultra-low gearing for steep terrain, through to high-speed gearing for smooth running on flat roads. In addition, the need for annoying backlash adjustments has been negated with the special spacer mounted on the outside of the motor. |
| 130 Motor The Mini-Z 4x4 features a specially-designed high-torque motor that is unique in the Mini-Z World. It's optimized for maximum torque, and it develops more power at lower speeds. |
- Fully pre-painted body looks like a luxury diecast car replica
- The signature seven slot front grille of the Jeep® has been reproduced in immaculate detail, including back mesh netting
- Matte black coating enhances the texture of the Freedom
Top® and the black overfender that wraps the trapezoidal wheel arch - A newly-designed one-touch body mounting system is used instead of the mounts commonly used on all previous Mini-Z cars and trucks
- The KT-531P transmitter operates on FHSS 2.4GHz and features steering/throttle trim in addition to dual-rate adjustment of steering angle and LED control functions
- Kyosho Mini-Z 4x4 Jeep Wrangler Unlimited Rubicon Bright White 1/18 Scale 4WD Truck
- FHSS 2.4GHz KT-531P transmitter
- 8x AAA batteries for transmitter and chassis
BUILD TIME : 1 HOUR
| Model Scale | 1/18 |
| Length | 197.3mm / 7.7in |
| Width | 87.3mm / 3.4in |
| Height | 89.1mm / 3.5in |
| Weight (No Battery) | 234g / 8.25oz |
| Wheelbase | 120mm / 4.72in |
| Ground Clearance | N/A |
| Body | ABS Plastic |
| Chassis | MX-01 |
| Drivetrain | N/A |
| Wheel Size (Diameter x Width) | 42mm x 14.3mm |
| Wheel Hex Size | N/A |
| Tire Tread | 72.7mm |
| Bushing Material | N/A |
| Suspension | N/A |
| Shock Type | N/A |
| Transmission | N/A |
| Gear Pitch | N/A |
| Internal Gear Ratio | 55.44:1 |
| Final Drive Ratio | N/A |
| Pinion | N/A |
| Spur Gear | N/A |
| Differential | N/A |
| Ball Bearings | N/A |
| Brakes | N/A |
| Electronic Speed Control | N/A |
| Motor | 130 Class |
| Battery | 8x AAA batteries (required) |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | N/A |
| Radio | Syncro KT-531P transmitter |
| Lights | Yes |
| Sound | No |
| Water Resistant | N/A |
| Skill Level | Intermediate |
| Assembly Time | 1 Hour |
| Recommended Environment | Offroad |
