Official XK Innovations 1/18 Scale Brave High Speed 4WD Truck - RTR Thread
  • jbaartz
    • Sep 2020
    • 488
    Brave High Speed 1/18 Scale 4WD Truck - Black - RTR from XK Innovations - WLT-A979-BLACK
    Brave High Speed 1/18 Scale 4WD Truck - Blue - RTR from XK Innovations - WLT-A979-BLUE
    Version Info: Includes a 2S 7.4V 1100mAh LiPo battery with JST connector and a 390 brushed motor capable of speeds up to 25mph.
    The XK Innovations Brave High Speed Truck is a 1/18 scale truck that arrives to your doorstep Ready To Run, full of fun and backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Perfect First Truck
    The perfect first truck for anyone looking to get started into the exciting world of 4X4 RC.
    Easy To Maintain
    Thrilling performance is matched with an aggressive truck configuration and iconic body style. The shell is quickly removable to access internal electronics.
    Four Wheel Drive
    Accelerate with maximum traction using active four wheel drive!
    Durable Design
    The tough body materials can absorb a lot of punishment.
    Upgradeable
    Perfect out of the box for most drivers, this buggy is also easy to tinker with, upgrade, or customize for creative gearheads looking for an affordable base vehicle.
    Ready To Run (RTR)
    Everything is included in the box to get you on the road in minutes, just add AA batteries for the radio transmitter! A 2.4Ghz radio transmitter, 2s 7.4v Li-Ion battery, and convenient battery charger are included.
    FEATURES:
    • Functions: forward, backward, turn left, turn right, direction trimming
    • Big wheels and high chassis provide good climbing performance
    • Has no problem going through the sand, grass and wet mud
    • 2.4GHz technology with four-wheel-drive system to provide plenty of power
    • 4 wheel drive to ensure a stable and smooth driving experience
    INCLUDES:
    • XK Innovations Brave High Speed 1/18 Scale 4WD Truck (Black) - RTR
    • 2.4GHz Transmitter and charger
    • 2S 7.4V 1100mAh Li-Po battery with JST connector
    REQUIRES:
    • Four (4) AA size batteries for the radio transmitter
    PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : NONE
    Model Scale 1/18
    Length 253mm / 9.9in
    Width 200mm / 7.8in
    Height 115mm / 4.5in
    Weight (No Battery) 1700g / 59.96oz
    Wheelbase 165mm
    Ground Clearance N/A
    Body ABS Plastic
    Chassis N/A
    Drivetrain N/A
    Wheel Size (Diameter x Width) 61mmx28mm
    Wheel Hex Size N/A
    Tire Tread N/A
    Bushing Material N/A
    Suspension N/A
    Shock Type Oil-Filled
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control N/A
    Motor Brushed 390 Motor
    Battery 2S 7.2V 1100mAh LiPo battery w/ JST connector
    Servos 17g
    Radio N/A
    Lights No
    Sound No
    Water Resistant Yes
    Skill Level Intermediate
    Assembly Time 1+ Hours
    Recommended Environment Offroad
