Official Kyosho Mini-Z Land Rover Defender 90 MX-01 1/27 Scale AWD Truck Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Click image for larger version  Name:	mastera_fabf4943-ead7-4651-8c47-c907ce3e35b9.jpg Views:	0 Size:	95.0 KB ID:	367335
    Click image for larger version  Name:	kyosho-mini-z-green-white-land-rover-defender-90-mx-01-1-27-scale-awd-truck-rtr-motion-rc-34332967829689.jpg Views:	0 Size:	89.5 KB ID:	367334
    Version Info: This truck is delivered as "RTR", however does require 4x AAA batteries for the transmitter, and 4x AAA for the chassis purchased separately (see Requires below for details).
    The combination of the highly-detailed body and a completely new 4x4 chassis design opens up new levels of performance, well beyond anything RC enthusiasts have ever seen from a mini crawler.
    In 2019 the world's most popular mini RC series, known as the Kyosho MINI-Z, celebrated more than 20 years of unmatched performance and scale realism in the hobby-grade RC category. The continuous pursuit of performance and evolution has led to the creation of a completely-new ‘MINI-Z 4x4’ design that delivers an all-new driving experience for RC fans of all stripes, with superior overall design, driving performance and high-quality injection-molded scale body construction. A significant feature of the MINI-Z 4x4 series is the greater emphasis of body detail and quality of finish that even surpasses existing benchmarks set by the MINI-Z. The body is also molded with thicker material to better resist crash damage from operation in rough terrain. Incorporating the same ladder-style frame of real 4WD vehicles, the MINI-Z 4x4 boasts a 3-link rigid axle suspension combining what would normally be two upper links into a single upper A-arm to deliver maximum suspension movement. A specially designed high-torque steering servo enables this machine to throw its elbows around in the hard terrain for excellent performance in the toughest rock-crawler conditions. The high-torque 130-size motor brings out the beast in the MINI-Z 4x4, specially geared to run well in the low to medium speed ranges common in crawling.
    Designed to balance exquisite style, scale detail and superior driving performance, all the MINI-Z 4x4 needs is 8 x AAA alkaline batteries (sold separately). Enjoy driving under any conditions, from normal driving to rock crawling while appreciating the stunning visual appearance. The Kyosho Mini-Z 4x4 is the only mini crawler that delivers a full range of crawling performance in a smaller package.
    Your Kyosho truck is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Painted Body
    Fully pre-painted body looks like a luxury diecast car replica. The thicker body material also provides superior durability.
    Ladder Frame
    The ladder frame design delivers a balance of flex and rigidity for superior performance and durability.
    130 Class Motor
    The Mini-Z 4x4 features a specially-designed high-torque motor that is unique in the Mini-Z World. It's optimized for maximum torque, and it develops more power at lower speeds.
    Scale Tires
    The Land Rover Defender sports scale reproduction Nitto Ridge Grappler tires from Toyo Tires.
    Coil Over Shock Absorbers
    The newly designed shock absorbers feature 360-degree spring retainers. This ensures that the spring retainers cannot come lose on the trail and will more easily reseat after hard impacts.
    Full Ball Bearings
    18 ball bearings are factory installed to ensure the smoothest operation right out of the box.
    • Fully pre-painted body looks like a luxury diecast car replica
    • Scale reproduction of Toyo Tire's Nitto Ridge Grappler tires
    • Newly designed coil over shock absorbers with 360-degree spring retainers
    • The KT-531P transmitter operates on FHSS 2.4GHz and features steering/throttle trim in addition to dual-rate adjustment of steering angle and LED control functions
    • Kyosho Mini-Z Grey/Black Land Rover Defender 90 MX-01 1/27 Scale AWD Truck - RTR
    • Complete chassis with built-in electronics
    • Factory-painted body complete with many fine details
    • KT-531P 2.4GHz transmitter
    • Pinion gear set(10T, 12T, 14T, 16T, 18T, 20T)
    • 3 types of pinion gear spacers
    Requires:
    • 8x AAA batteries for transmitter and chassis
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Model Scale 1/27
    Length 186mm / 7.3in
    Width 83mm / 3.3in
    Height 104mm / 4.1in
    Weight (No Battery) 248.6g / 8.77oz
    Wheelbase 110mm / 4.3in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis MX-01
    Drivetrain AWD
    Wheel Size (Diameter x Width) 42mm x 14.3mm
    Wheel Hex Size N/A
    Tire Tread 72.7mm
    Bushing Material N/A
    Suspension N/A
    Shock Type Coil Over
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 55.44:1 / 46.20:1 / 39.60:1 / 34.65:1 / 30.80:1 / 27.72:1
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings Full
    Brakes N/A
    Electronic Speed Control N/A
    Motor 130 Class
    Battery 8x AAA batteries (required)
    Servos N/A
    Lights Yes
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
    Recommended Environment Offroad
