Official Hobby Plus Mini Crawler RTR Discussion Thread
  • jbaartz
    • Sep 2020
    • 483
    This is for all of the Hobby Plus 1/18 scale Mini Crawlers. The CR18 Harvest is used as an example, as most of the differences are cosmetic.
    CR18 Blue Harvest 1/18 Scale 4WD Mini Crawler - RTR from Hobby Plus - HBP1810107-BL
Name:	hobby-plus-cr18-blue-harvest-1-18-scale-4wd-mini-crawler-rtr-motion-rc-34481923719353.jpg
    Version Info: This vehicle is delivered as “RTR” but requires the additional purchase of 4 (four) AAA alkaline batteries for the transmitter, sold separately (see Requires below for details).
    The Hobby Plus brand of crawlers deliver all the features, performance, and handling you’ve come to expect at a budget-friendly price you won’t. Don’t let the compact size fool you, this mini crawler has features that defy its size, such as FPV-ready electronics, CMS (chassis-mounted servo system), hi-torque 3-wire micro servo, and included LiPo battery and USB charger.
    The chassis design delivers superior geometry thanks to a Panhard system that provides extraordinary amounts of articulation while avoiding unwanted bump steer. An innovative gearbox and drivetrain deliver massive torque at low RPM for a finely controlled crawling experience thanks to an optimized ring and pinion system, which does not hinder top speed like worm-gear drive arrangements used by other brands. A combination of waterproof electronics and LiPo power deliver over 30 minutes of runtime per charge, while internal beadlock wheels secure a soft-compound tire for impressive grip on a wide variety of surfaces and obstacles. The polycarbonate Harvest bodyshell delivers a nostalgic 1950’s vibe with its impressive scale appearance while still offering the potential for personalized custom touches.
    Enjoy an impressively realistic mini-crawling experience by combining the versatile, go-anywhere fun of Hobby Plus Crawlers with Motion RC’s parts and technical support, industry-leading customer service and product selection for a package that cannot be beat!
    2.4GHz Radio Reliability
    The comfortable transmitter offers all of the electronic setting options to customize the mini crawling experience to your specific requirements.
    Durable Design
    Metal chassis rails anchor a proven link-style suspension for maximum articulation and grip.
    Impressive Electronics
    The CR18 Electronic package includes a 3-wire, chassis mounted servo and reliable 2.4GHz receiver with FPV and auxiliary LED power ports.
    Ring and Pinion Drive
    The CR18 utilizes an optimized ring and pinion system for scale looks, outstanding torque, and higher top speeds than the worm-gear drives used by other brands.
    • Anodized aluminum ladder frame chassis
    • Multi-link suspension with Panhard bar
    • Chassis mounted 3-wire servo
    • Highly detailed body with included scale accessories
    • LED-ready roof light bar
    • Front and Rear LED light set included
    • High torque transmission gear box
    • 2S 7.4v 600mAh LiPo battery
    • USB charger
    • Super-soft tires
    • Internal beadlock wheels
    • Waterproof electronics
    • FPV Ready ESC
    • Additional RX power port for additional lights or FPV
    • Hobby Plus CR18 Blue Harvest 1/18 Scale 4WD Mini Crawler - RTR
    • Hobby Plus 2.4GHz transmitter
    • USB charger
    • Optional firm shock springs (4)
    • Instruction Manual
    • Tools
    Requires:
    • 4x AAA Alkaline batteries for transmitter
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Model Scale 1/18
    Length 275mm / 10.7in
    Width 113mm / 4.4in
    Height 135mm / 5.3in
    Weight (No Battery) 280g / 9.9oz
    Wheelbase 155mm / 6.0in
    Ground Clearance 34mm / 1.3in
    Body Polycarbonate, factory painted and decorated
    Chassis Composite with metal rails
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 24.5mm x N/A
    Wheel Hex Size 7mm
    Tire Tread Multi-surface
    Bushing Material Oilite bronze
    Suspension 4-wheel, solid axle
    Shock Type Spring dampers
    Transmission N/A
    Gear Pitch MOD 0.3
    Internal Gear Ratio 51.2:1
    Final Drive Ratio 104:1
    Pinion 12T
    Spur Gear 54T
    Differential No
    Ball Bearings No
    Brakes Electronic
    Electronic Speed Control Brushed 2-in-1 RX/ESC
    Motor Mini 050 brushed
    Battery 2S 7.4v 600mAh LiPo
    Servos 3-wire, 1Kg waterproof
    Radio 2 Channel (included)
    Lights Yes
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time None
    Recommended Environment Indoors/Outdoors
  • SoCalBobS
    • 2716
    • Southern California
    This appears similar to the FMS model sold by MRC until recently. I bought one and liked it until the electronics failed - the throttle channel stopped working. MRC, Any chance electronic parts for this or the FMS version will be available?
