Official FMS FCX24 Chevy K5 Blazer 1/24 Scale 4WD Crawler Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Click image for larger version  Name:	fms-fcx24-chevy-k5-blazer-orange-1-24-scale-4wd-crawler-rtr-motion-rc-34592971718841.jpg Views:	0 Size:	110.5 KB ID:	377128
    Click image for larger version  Name:	fms-fcx24-chevy-k5-blazer-brown-1-24-scale-4wd-crawler-rtr-motion-rc-34592933576889.jpg Views:	0 Size:	95.3 KB ID:	377129
    Version Info: This truck is delivered as "RTR", however does require 4 x AAA batteries for the transmitter sold separately (see Requires below for details).
    The iconic Chevy K5 Blazer has been faithfully recreated in 1/24 scale by FMS! Officially licensed, this innovative masterpiece features a capable, heavy duty four-link suspension system coupled with a two-speed transmission that can be remotely shifted on the transmitter. The low speed setting is ideal for powerful climbs, while the top speed delivers a spirited driving experience. The included electronics package, rechargeable 7.4v 380mAh battery, and convenient USB charger creates a truly complete assortment.
    Enjoy an impressively realistic micro-crawling experience by combining the versatile, go-anywhere fun of FMS Crawlers with Motion RC’s parts and technical support, industry-leading customer service and product selection for a package that cannot be beat!
    Available In 3 Color Choices
    The molded hard plastic body offers three attractive color options to best express your style. Or, collect all three!
    Cap or Roll Bar
    Customize the K5 to your liking with a bed cap, or use the included roll bar for an open bed look.
    High Clearance Portal Axles
    Equipped with precision off-road portal axles, the chassis has improved the minimum ground clearance through the portal axles, so it has off-road performance far exceeding that of products of the same size.
    High-Performance Chassis Frame
    The integrally formed frame is made of high-strength nylon, allowing for a lower center of gravity, lighter weight, and higher strength than traditional models.
    Terrain-Focused Tires
    Tires and metal plating wheels come with tremendous grip and precise steering character, giving driver confidence while navigating rough off-road conditions whatever rocks, mud, and sand.
    Safer & Longer Lifespan Battery
    The 7.4 volts LiPo battery with 380mAh provides strong power for up to 30 minutes of running time. While built-in PCM (protective circuit management) can protect the battery from overcharging/over-discharging for higher safety and reliability.
    • Completely ready to run model
    • Easy on/off body mount system
    • Innovative two-speed transmission
    • Portal axle system with metal gears
    • High ground clearance chassis configuration
    • Hydraulic shock absorber system
    • High-performance climbing performance
    • Four-link suspension system
    • Simulation of the hard plastic car shell
    • Remotely controlled LED lighting system
    • High torque, metal-geared steering servo
    • High-strength integrated nylon chassis frame design
    • FMS FCX24 Chevy K5 Blazer Black 1/24 Scale 4WD Crawler - RTR
    • 2.4GHz Transmitter
    • 2-in-1 Receiver / 40A ESC (installed)
    • 130 Brushed Motor (installed)
    • 9g Plastic Digital Servo (installed)
    • 13g Metal Digital Servo (installed)
    • 7.4V 380mAh LiPo Battery
    • USB Battery Charger
    • Hex Wrench Socket
    • Product Manual
    Requires:
    • 4x AAA Alkaline batteries for transmitter
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Model Scale 1/24
    Length 253mm / 9.8in
    Width 129mm / 5.0in
    Height 128mm / 5.0in
    Weight (No Battery) 442g / 15.8oz
    Wheelbase 139mm / 5.4in
    Ground Clearance 38mm / 1.5in
    Body ABS Plastic, factory painted and decorated
    Chassis Composite
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 54.8mm x 19.5mm
    Wheel Hex Size 7mm
    Tire Tread Multi-surface
    Bushing Material Ball bearings
    Suspension 4-wheel, solid axle
    Shock Type Spring dampers
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential No
    Ball Bearings Yes
    Brakes Electronic
    Electronic Speed Control 2-in-1 RX/ESC
    Motor Mini 130 brushed
    Battery 2S 7.4V 380mAh LiPo
    Servos 3 - digital
    Radio 2 channel (included)
    Lights Yes
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time None
    Recommended Environment Indoors/Outdoors
  • superman2112ms
    • Jun 2023
    Both TX and rx are bound. I can turn the lights on. Nothing else responds. Neither steering or acceleration. Any suggestions?
    • hooked on hobbies
      • Apr 2021
      • 19
      • California
      Is the battery charged? Often the LiPo will have enough voltage to illuminate the LED's but not operate the servo or motor. Secondly, I suggest checking the servo and ESC connectors in the receiver to insure the integrity of those connections.
      • superman2112ms
        • Jun 2023
        It is charged. It was a new FMS battery to be used as a spare. When I put the original back in after charging everything works fine.
        • hooked on hobbies
          • Apr 2021
          • 19
          • California
          I see, sounds like a DOA battery. Glad it wasn't anything more serious. FMS or Motion RC customer service will most likely make it right for you. Thanks for responding!
