Version Info: This truck is delivered as "RTR", however does require 4 x AAA batteries for the transmitter sold separately (see Requires below for details).
The iconic Chevy K5 Blazer has been faithfully recreated in 1/24 scale by FMS! Officially licensed, this innovative masterpiece features a capable, heavy duty four-link suspension system coupled with a two-speed transmission that can be remotely shifted on the transmitter. The low speed setting is ideal for powerful climbs, while the top speed delivers a spirited driving experience. The included electronics package, rechargeable 7.4v 380mAh battery, and convenient USB charger creates a truly complete assortment.
Enjoy an impressively realistic micro-crawling experience by combining the versatile, go-anywhere fun of FMS Crawlers with Motion RC’s parts and technical support, industry-leading customer service and product selection for a package that cannot be beat!
Available In 3 Color Choices The molded hard plastic body offers three attractive color options to best express your style. Or, collect all three! |
Cap or Roll Bar Customize the K5 to your liking with a bed cap, or use the included roll bar for an open bed look. |
High Clearance Portal Axles Equipped with precision off-road portal axles, the chassis has improved the minimum ground clearance through the portal axles, so it has off-road performance far exceeding that of products of the same size. |
High-Performance Chassis Frame The integrally formed frame is made of high-strength nylon, allowing for a lower center of gravity, lighter weight, and higher strength than traditional models. |
Terrain-Focused Tires Tires and metal plating wheels come with tremendous grip and precise steering character, giving driver confidence while navigating rough off-road conditions whatever rocks, mud, and sand. |
Safer & Longer Lifespan Battery The 7.4 volts LiPo battery with 380mAh provides strong power for up to 30 minutes of running time. While built-in PCM (protective circuit management) can protect the battery from overcharging/over-discharging for higher safety and reliability. |
- Completely ready to run model
- Easy on/off body mount system
- Innovative two-speed transmission
- Portal axle system with metal gears
- High ground clearance chassis configuration
- Hydraulic shock absorber system
- High-performance climbing performance
- Four-link suspension system
- Simulation of the hard plastic car shell
- Remotely controlled LED lighting system
- High torque, metal-geared steering servo
- High-strength integrated nylon chassis frame design
- FMS FCX24 Chevy K5 Blazer Black 1/24 Scale 4WD Crawler - RTR
- 2.4GHz Transmitter
- 2-in-1 Receiver / 40A ESC (installed)
- 130 Brushed Motor (installed)
- 9g Plastic Digital Servo (installed)
- 13g Metal Digital Servo (installed)
- 7.4V 380mAh LiPo Battery
- USB Battery Charger
- Hex Wrench Socket
- Product Manual
- 4x AAA Alkaline batteries for transmitter
AGE LEVEL : 14 and up
SKILL LEVEL : Beginner
BUILD TIME : None
| Model Scale | 1/24 |
| Length | 253mm / 9.8in |
| Width | 129mm / 5.0in |
| Height | 128mm / 5.0in |
| Weight (No Battery) | 442g / 15.8oz |
| Wheelbase | 139mm / 5.4in |
| Ground Clearance | 38mm / 1.5in |
| Body | ABS Plastic, factory painted and decorated |
| Chassis | Composite |
| Drivetrain | 4WD |
| Wheel Size (Diameter x Width) | 54.8mm x 19.5mm |
| Wheel Hex Size | 7mm |
| Tire Tread | Multi-surface |
| Bushing Material | Ball bearings |
| Suspension | 4-wheel, solid axle |
| Shock Type | Spring dampers |
| Transmission | N/A |
| Gear Pitch | N/A |
| Internal Gear Ratio | N/A |
| Final Drive Ratio | N/A |
| Pinion | N/A |
| Spur Gear | N/A |
| Differential | No |
| Ball Bearings | Yes |
| Brakes | Electronic |
| Electronic Speed Control | 2-in-1 RX/ESC |
| Motor | Mini 130 brushed |
| Battery | 2S 7.4V 380mAh LiPo |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | 3 - digital |
| Radio | 2 channel (included) |
| Lights | Yes |
| Sound | No |
| Water Resistant | Yes |
| Skill Level | Beginner |
| Assembly Time | None |
| Recommended Environment | Indoors/Outdoors |
