Official Kyosho KB10L 2021 Toyota Tacoma TRD Pro 1/10 Scale 4WD Truck Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Version Info: This truck is delivered as "RTR", however does require 4x AA batteries for the transmitter, a 7.4V 5000mAh LiPo battery and a battery charger, purchased separately (see Requires below for details).
    With rugged tires and undercarriage to handle rough terrain and a large rear cargo bed, pickup trucks are in high demand throughout North America, Southeast Asia, Africa, and Australia and many popular pickup trucks have been recreated as R/C models. Toyota developed the Tacoma mainly for the North American market and it has continued to sell well since its release in 1995. This model is based on the 3rd generation Tacoma which first appeared to much acclaim in 2016 due to its aggressive styling and practicality. The top of the range Tacoma TRD Pro has been recreated by Kyosho with a tough 1/10 scale chassis in a Readyset package.
    Kyosho’s molding craftmanship immaculately reproduces the TRD Pro body in lightweight but rigid polycarbonate resin with the strength for hard off-road driving. Based on the off-road KB10 chassis, the long wheelbase and short tread of the KB10L chassis matches the body perfectly. The shaft-driven 4WD system reliably transfers the brute power of the TORX10L brushless motor to reach top speeds of about 75km/h under the management of the ESC (Electronic Speed Control) and a compatible 3S (11.1V) lipo battery. This convenient Readyset package contains the fun of an ultra-scale pickup truck on a dynamic off-road chassis with a finish similar in quality to premium display-only models and it is backed by Motion RC's world-renowned customer service and technical support. Drive on!.
    High Rigidity Chassis
    Based on the 1/10 scale Mad Wagon bush-basher off-road chassis, the KB10L has an extended wheelbase and shortened suspension arms with the stability of the shaft-type 4WD.
    Scale Body
    The low & wide shape of the polycarbonate body has been immaculately recreated with the unique TRD Pro front grill and light buckets to enhance the 3-dimensional effect. Durable 1.5mm PC body.
    TORX 10L Brushless Motor
    Includes a powerful TORX 10L brushless motor. With 38mm diameter and long 68mm specifications, the motor produces 2850Kv (rotations per volt) and efficiently converts power from the 3S LiPo battery into speed and torque.
    BRAINZ 10+ waterproof ESC
    Equipped with a BRAINZ 10+ waterproof ESC (speed controller) that boasts 80A capacity. Top mounted cooling fan manages heat generation to reduce power loss even with extended running times.
    • Readyset includes pre-assembled chassis, painted body, and RC system with pistol grip Syncro KT-231P + transmitter
    • Includes powerful TORX 10L brushless motor and waterproof BRAINZ 10 + brushless ESC
    • Pre-painted and assembled "Toyota Tacoma TRD Pro" ultra-scale body fully captures the form of the original truck
    • Newly designed body mounts conceal body pins from the outside to realize a higher sense of scale
    • Full-time 4WD KB10L chassis can handle rough roads as well as on-road and flat dirt
    • The battery holder is compatible with 3S size batteries and comes with a belt, making it easy to change
    • Three differential designs for enhanced running stability. #10000 oil is pre-filled in the center diff and A little help From My Friends! oil in the front and rear diffs
    • Full ball bearings (22) equipped for optimal drive efficiency and durability
    • The receiver is enclosed in a sealed box to prevent compromise from sand and dirt while driving
    • Kyosho KB10L Green 2021 Toyota Tacoma TRD Pro 1/10 Scale 4WD Truck - RTR
    • Factory assembled chassis
    • Pre-cut and painted body complete with decals applied
    • 2.4GHz Syncro KT-231P+ transmitter
    • 1.5mm/2.0mm/2.5mm L shaped hex wrench
    • Cross wrench
    • 4/5/5.5/7/10mm integrated spanner
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Model Scale 1/10
    Length 572mm / 22.5in
    Width 274mm / 10.8in
    Height 214mm / 8.4in
    Weight (No Battery) 3410g / 120.3oz
    Wheelbase 340mm / 13.4in
    Ground Clearance N/A
    Body Polycarbonate
    Chassis KB10L
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 110mm x 47mm
    Wheel Hex Size N/A
    Tire Tread 224mm
    Bushing Material N/A
    Suspension N/A
    Shock Type Oil-filled
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 10.41:1
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings Full
    Brakes N/A
    Electronic Speed Control Waterproof BRAINZ 10+ brushless ESC
    Motor TORX10L brushless motor 2850Kv
    Battery 7.4v 2S or 11.1v 3S LiPo (required)
    Max Battery Dimensions (L x W x H) 143x47x30mm
    Servos N/A
    Radio 2.4GHz Syncro KT-231P+ transmitter
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
