Official Torro German Sd.Kfz. 251/1 Ausf. D 1/16 Scale Armored Halftrack Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Click image for larger version  Name:	torro-german-sd-kfz-251-1-ausf-d-camo-1-16-scale-armored-halftrack-rtr-motion-rc-1170641506.jpg Views:	0 Size:	123.0 KB ID:	426779
    The Sd.Kfz. 251/1 Ausf. D was a German half-track armored personnel carrier used extensively during World War II. It was the final and most simplified version of the Sd.Kfz. 251 series, designed to improve production efficiency and battlefield performance. Introduced in 1943, the Ausf. D featured a more streamlined hull with fewer angled plates, reducing the number of parts and making it easier to manufacture compared to earlier models.
    Powered by a Maybach HL 42 6-cylinder gasoline engine, the Sd.Kfz. 251/1 Ausf. D had a top speed of around 53 km/h (33 mph) and an operational range of approximately 300 km (186 miles). It had a crew of two and could transport up to ten infantry soldiers, providing them with mobility and protection on the battlefield. The vehicle was lightly armored, with 6–14.5 mm thick armor, offering defense against small arms fire and shrapnel.
    Armed with two MG 42 machine guns, the Sd.Kfz. 251/1 Ausf. D was primarily used to support mechanized infantry and Panzer divisions. It played a crucial role in the German Blitzkrieg tactics, allowing rapid troop deployment in combat zones. Its versatility led to the development of numerous specialized variants, including flamethrower, command, and anti-aircraft versions.
    Torro faithfully reproduced this vehicle in a 1/16 scale model featuring lights, sound, detailed interior, opening doors, realistic tracks, and more, to compliment any RC battlefield. Available in three color schemes, this halftrack will delight enthusiasts of military armor and combat vehicles. Fully complete and ready to run, the only additional items required are four (4) AA alkaline batteries for the transmitter. Grab your German armored halftrack and enjoy the unique operation that this model offers!
    Complete Package
    The Torro Sd.Kfz. 251/1 Ausf. D comes completely assembled and ready for use. Simply add four AA alkaline batteries for the transmitter (available separately), charge the battery, and the model is ready for action. Optional stickers are included to enhance the realism of the model.
    Realistic Interior
    A realistic dashboard and steering wheel bring handcrafted features to a RTR model. This halftrack is perfectly suited for the addition of 1/16 scale figures for the ultimate in realism.
    Scale Drivetrain
    Just like the full-size vehicle, this model is propelled by a combination of tracks for forward drive and front tires for agility.
    Opening Doors and Hatches
    Tiny magnetic latches secure lids, covers, and hatches when closed, keeping internal stores secured.
    Easy Battery Access
    Removing the battery for charging is as simple as opening a hatch, disconnecting the battery plug, and removing the pack.
    Ample Room for Additional Details
    This halftrack is perfectly suited for the addition of 1/16 scale figures for the ultimate in realism. Click here to view our entire selection.
    • Fully Assembled model available in three color schemes
    • Sound system can be turned on/off from transmitter
    • Reliable and comfortable 3 channel 2.4GHz pistol grip transmitter
    • Rubber tires
    • Realistic tracked drive system
    • Fully detailed dashboard and interior
    • Front and Rear LED lights
    • Proportional throttle and steering
    • Scale graphics included
    • 7.4v 1100mAh Li-ion battery pack and USB charger
    • Torro German Sd.Kfz. 251/1 Ausf. D Camo 1/16 Scale Armored Halftrack - RTR
    • 2.4GHz transmitter
    • 7.4V 1100mAh Li-ion battery pack
    • USB battery charger
    • Instruction manual
    • Sticker set
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : Less Than 1 Hour
    Model Scale 1/16
    Length 377mm / 14.8in
    Width 138mm / 5.4in
    Height 138mm / 5.4in
    Weight (No Battery) 2,000g / 71.4oz
    Wheelbase N/A
    Ground Clearance N/A
    Body ABS, factory painted and decorated
    Chassis ABS
    Drivetrain Tracked
    Wheel Hex Size N/A
    Tire Tread Multi-surface
    Bushing Material N/A
    Suspension Tracked
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes Electronic
    Electronic Speed Control 30A
    Motor Brushed
    Battery 7.4V 1100mAh Li-ion
    Servos N/A
    Radio 4 channel (included)
    Lights Yes
    Sound Yes
    Water Resistant No
    Skill Level Beginner
    Assembly Time Less than 1 hour
  • DavidN
    • May 2021
    • 3206
    • Los Angeles, CA
    Bought one! Almost done. Working on the weathering next!
    • DavidN
      • May 2021
      • 3206
      • Los Angeles, CA
ID:	426891 Click image for larger version
ID:	426892 Click image for larger version
      • SoCalBobS
        • 2765
        • Southern California
        David, now that you’ve had this for a while, how do you like it? Where are the soldiers from?
