Official Hobby Plus CR18P Terranaut 8X8 1/18 Scale AWS Truck Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Click image for larger version  Name:	694967b5_hobby-plus-cr18p-terranaut-8x8-grey-1-18-scale-aws-truck-rtr.webp Views:	0 Size:	125.8 KB ID:	441426
    Version Info: This vehicle is delivered as “RTR” but requires the additional purchase of 4 (four) AAA alkaline batteries for the transmitter, sold separately (see Requires below for details).
    The Hobby Plus CR-18P Terranaut 8×8 is a mission-ready, ultra-capable recovery and hauling platform designed for enthusiasts who demand both scale realism and genuine off-road functionality. Built on the proven CR-18P architecture, the Terranaut delivers an unprecedented combination of maneuverability, torque, and utility—right out of the box. Featuring Active All-Wheel Steering, a remote-selectable 2-speed transmission, portal axles, and a fully functional rear winch, this 1/18 powerhouse handles everything from precision crawling to heavy towing with ease.
    With its extensive list of features, the Terranaut 8x8 is the perfect companion for off-road adventures. Add this to Motion RC’s industry-leading service, selection, and product support for an unbeatable RC experience.
    Active All-Wheel Steering (Active-AWS)
    Independently control the front and rear four wheels using the included FlySky 6-channel transmitter. Execute tight U-turns, crabwalk over obstacles, or isolate front-only or rear-only steering—all with fully proportional precision.
    2-Speed Transmission
    Low Gear (124:1): Maximum torque for recoveries, steep climbs/descents, and heavy hauls. High Gear (31:1): Ideal for faster trail runs between technical sections. Switch gearing remotely without lifting a finger.
    True Working Recovery Equipment
    A remote-operated rear winch equipped with stainless steel wire and a metal hook delivers genuine utility in the field, whether you’re rescuing a stuck crawler or hauling scale cargo. A gooseneck/fifth-wheel receiver expands your towing capability even further.
    Built for Real Terrain
    Portal axles increase ground clearance while allowing fine-tuned gear ratios. Metal gears throughout, steel pivot balls, CVD axles, and an aluminum chassis ensure long-term durability. Big-bore oil-filled shocks and aggressive MT tires keep the Terranaut planted in rough terrain.
    • Active all-wheel steering for unmatched maneuverability
    • Remote-selectable 2-speed transmission
    • Big-block 280-size high-torque brushed motor
    • Portal axles for added clearance and power delivery
    • HD telescoping driveshafts with metal yokes
    • Metal-geared servos on all four axles
    • CVDs on all axles for durability and increased steering angle
    • Rear anti-roll bar for stability during hauling
    • Injection-molded hardbody with detailed interior
    • Dual spare tires, scale accessories, and functional light system
    • Rotating amber beacons with 5 selectable modes
    • Black-anodized aluminum chassis with chamfered raw edges and laser-etched details
    • Tilt-cab access for quick battery changes
    • FlySky 6-channel transmitter with proportional rear-steer lever
    • FlySky ESC/receiver combo for smooth, reliable control
    • Water-resistant electronics
    • Integrated remote-operated LED system
    • Remote-controlled operational rear winch
    • Big-bore, oil-filled coil-over shocks
    • Threaded shock bodies for easy tuning
    • Aggressive MT tires mounted on beadlock wheels
    • Hobby Plus CR18P Terranaut 8x8 Grey 1/18 Scale AWS Truck - RTR
    • FlySky FHSS 6-channel radio syste
    • 2S 7.4V 1100mAh LiPo battery (up to 1 hour of runtime)
    • USB LiPo charger
    • Pre-installed LED lighting
    • Installed rear recovery winch
    AGE LEVEL : 14 and Up
    SKILL LEVEL : Beginner
    BUILD TIME : 15 Minutes
    Model Scale 1/18
    Length 434mm / 17in
    Width 135mm / 5.3in
    Height 161mm / 6.3in
    Weight (No Battery) 1,200g / 42.8oz
    Wheelbase 416mm / 16.3in
    Ground Clearance 39mm / 1.5in max
    Body ABS plastic, factory painted and decorated
    Chassis Aluminum
    Drivetrain 8WD
    Wheel Size (Diameter x Width) 30.5 x 23mm
    Wheel Hex Size 7mm
    Tire Tread Multi-surface
    Bushing Material N/A
    Suspension 8-wheel independent
    Shock Type Oil-filled, coil over, adjustable
    Transmission 2-speed
    Gear Pitch MOD 0.4
    Internal Gear Ratio N/A
    Final Drive Ratio
    • High: 31:1
    • Low: 124:1
    Pinion 13T
    Spur Gear N/A
    Differential N/A
    Ball Bearings Complete
    Brakes Electronic
    Electronic Speed Control Waterproof
    Motor 280-size brushed
    Battery 2S 7.4v 1100mAh LiPo (included)
    Servos Waterproof, metal gear
    Radio 6-channel (included)
    Lights Yes
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time 15 Minutes
