600 size Roban UH-1N
  • RLZ
    • May 2018
    • 20
    • Corinth, MS
    This is my second scale project. I'm using the Chaos 600 esp air frame. With the mechanics out of the fuselage and attached to a couple pieces of wood. It flies great. Can do some sport flying with it. Once in the Fuselage I have a wobble during flight and hover. I'm using a Beastx gyro and have had good success in the past with the product. I have spent months trying to get the wobble out. Does anyone have a Beastx setup that works, I would like very much to compare.
    Several 450 pod & booms, Chaos 600, UH1N, MD500, Talon F1, Escapade MX, Avistar, Ugly Stik and Several Foam War Birds
  • JFandL
    • Jun 2013
    • 402
    Do you have any video of the flight? There is more than one thing that can make it wobble
    • eawings
      MotionRC CS Team / Pro Scale Builder
      • 113
      Your Chaos 600ESP is fine. So did you fly this frame as a pod and boom? I can help you out with your chaos. Like JFandL said theres a lot to it causing your head to wobble. Check your main shaft, your head phasing, tail boom bearings and your torque tube shaft. Let me know.
      • RLZ
        • May 2018
        • 20
        • Corinth, MS
        Sorry I have been away for so long. I did figure out what was wrong. After much expense all new shafts all new bearings and different heads and tail feathers. I changed the dampers in the head to 80. that seemed to help a little. The fix was a program change in the BeastX. Changed the Control Style from Sport to Pro. I think I'll remember that one. Hovers like a rock, flies real smooth. Way better than I ever expected. Expensive lesson. Hope this helps....
          Hi RLZ, that sounds like quite a long road to success, but I'm glad to hear you made it there!
          Are you using the USB programmer or the Bluetooth version?
          • RLZ
            • May 2018
            • 20
            • Corinth, MS
            USB, I Have tried Bluetooth but have only had reliable success with AS3X AR636 and AR7200BX
            • Gmack908
              • Jan 2021
              • 80
              • United States
              Building one now with Phoenixtech 600 esp mechanics. Did you have to dremel out some of the skinny tail fuse area to get the tail rotor mechanics to fit down there and connect to the 45* gear box? Thanks!
              • RLZ
                • May 2018
                • 20
                • Corinth, MS
                Gmack
                No I am able to slide the Tail on with the 45* gear box
                • DLHam3463
                  • Mar 2024
                  • 28
                  Hello. I am also starting in a 600 Roban UH-1. Using PhoenixTech 600 ESP.
                  just curious if you all recall how much (if any) nose weight was needed to balance CG.
                  Doing some planning and was hoping to get an idea how much weight I may need to hide.
                  many thanks!!
                  • DCORSAIR
                    • 1918
                    • Selma, Ca.
                    On my Roban Bell 212 civilian version I had no cockpit and placed my 720g 5000 60c lipo in that area, it was just very slightly tail heavy, it's the same build as the UH-1, just to give you an idea anyway.
                    • DLHam3463
                      • Mar 2024
                      • 28
                      Thanks! That’s helpful. I do have interior.
                      • DLHam3463
                        • Mar 2024
                        • 28
                        Click image for larger version  Name:	IMG_5009.jpg Views:	0 Size:	59.0 KB ID:	402950 Click image for larger version  Name:	IMG_5008.jpg Views:	0 Size:	63.9 KB ID:	402951
                        Question, the stock Roban frame width expectations are based on a 47mm width. The later Trex and PhoneixTech 600ESP are 54mm.
                        I have the spacers etc for tail rotor bearing plates, but in doing some checking with 54mm spacing the frame mount lug holes are too wide for installed T-nuts.
                        i am thinking perhaps to locate them agains the inside frame wall as they are 2mm thick so that looks like it would be enough.
                        anyone else do something different??
                        • DLHam3463
                          • Mar 2024
                          • 28
                          Slowly getting there.
ID:	403909 Click image for larger version
ID:	403910 Click image for larger version
