Originally posted by Highfly!
View Post
Official RotorScale B222 Shadow Black 450 Size Helicopter Discussion Thread
With the stock setup, it should be somewhere around 3300. I have mine cranked down as low as I can get it without the ESC overheating, sticking around 70% or so.Originally posted by Tron View Post
I found specs on the Gartt HF450L-1800 motor as 9N6P (9 stator magnets, 6 rotor poles)
What headspeed should we be targeting for these 2 bladed stock heads?
Any idea what headspeed you get at 70%? Are you using the stock Hobbywing 40A ESC? Governor mode enabled (Governor High)?Originally posted by F106DeltaDart View Post
On the Airwolf, I just did a quick and dirty setup and did a throttle curve, no governer enabled. I need to go back and actually set it up soon. Here’s the throttle curve as it sits now.Originally posted by Tron View Post
Any idea what headspeed you get at 70%? Are you using the stock Hobbywing 40A ESC? Governor mode enabled (Governor High)?1 Photo
I'm posting several photos of this project to provide you with a closer look inside the Shadow 450 heli. I hope they are helpful.In an earlier post someone asked about the motor so I've also included a photo of the Gartt motor for your reference.
I highly recommend that every pilot take the mechanicals out of the fuselage and give everything a good "once over" before flying these helis. There are four screws on the bottom of the fuselage and you'll need to remove the tail assembly including the tail rotor. Not a big deal but this gave me the first indication that I needed to apply loctite on the fittings. I found a couple of issues that, had I not removed the mechanicals first, would have led to serious problems later. First, as with any RTF or used heli you buy, you need to make sure that all of the appropriate screws and fittings have loctite on them. I did not find any evidence of loctite being used on my heli. If you don't do this you can have screws or link balls back out in flight and then you have a serious problem. After removing the frame from the fuselage I went through and loctited and greased all relevant fittings, bearings, etc. Second, I found that when I powered on the heli the tail rotor pegged all the way against the tail section. The servo arm was centered correctly but the entire servo had moved forward towards the frame, pulling the rotor inward towards the tail section. This may have happened when the factory was installing the frame into the fuselage and it pushed the servo and mount. I moved the servo and mount farther backwards toward the tail until the tail slider was centered correctly. Then I applied loctite to the servo mount screws and cinched it down.
Since I had the frame out of the fuselage this gave me the ability to place the 7 channel receiver and FBL controller in the best locations. The receiver went under the battery tray and the gyro on the left side of the fuselage with the servo plugs facing forward. This allowed me to connect everything including the retract servo. Once everything was connected I was able to program the gyro and get my main rotor head set up to the correct angles. I spun it up on the bench without blades (but with the tail assembly installed) to make sure everything was moving correctly before putting it all back into the fuselage.
Before doing that though, there are two small plywood pads that sit between the frame and the inside of the fuselage. The four mounting screws go through the fuselage, through the plywood pads and then screw into the frame. These plywood pads are not secured to the inside of the fuselage so I decided to epoxy them into place. Once it was all dry I inserted the frame and mechanicals (with the tail assembly removed once again) into the fuselage, lined up the mounting screws and then secured the frame to the fuselage. It was very easy to do. After that I reattached the tail assembly and affixed the tail cone.
I connected the retract servo lead to Aux 2 on my receiver and tested it. Being new it was a little sticky but after a few opens/closes it all worked pretty well. I did go into the Servo Speed function and adjust the open and close time to 4 seconds each so the wheels would drop in a smooth scale-like manner. It looks pretty cool.
I was planning on using some 6S 1350mAH LiPO batteries I had for another heli in the Shadow but they proved to be too heavy in the nose. I have ordered a couple of the Admiral 1100mAH batteries from Motion RC which are recommended and they should come sometime later this next week. Until then I've still got some additional work to do to complete this build.6 Photos
There was no grease on the thrust bearings nor any loctite on the bolts holding the blade grips to the feathering shaft.
I almost always disassemble the heli the heli all the way down unless I know who I am buying the heli from and their build ethic. I also like building because it gives me a good working knowledge of the heli and reassurance that it’s built to my standards.
- Likes 2
The fuselage is actually 3 pieces: the body, the canopy and the tail cone. The fiberglass body is high quality and the paint is really very nice. It's a gloss black and a white white and the separation lines between them are very clean. The body isn't flimsy at all. The canopy is made from the same quality fiberglass with smoke colored windows and windshield. the windshield is held on by four small screws. The tailcone is also fiberglass and is affixed to the end of the fuselage tail with 3 small screws. The canopy has a couple of small alignment pins and magnets to hold it securely to the body. The fit between the two is good and I don't see anything to cause the canopy to come off during flight. Likewise the fit for the tailcone is good also.
I had no issues with chipping the paint or fiberglass when I was removing and inserting the frame and mechanicals back into the body. Chipping can be easy to do when you're trying to get past the fuselage opening with the main gear and cyclic servos.
The only thing that I think is wrong with the fuselage is that they've added some rivets around the body. If you were to scale up this fuselage to full size then each of those rivets would be about the size of a dinner biscuit. I know why the designers do things like this, and I'm probably being too picky, but you shouldn't be able to see any rivets on a scale heli this small. But again, that's me being picky. It's not a bad thing and if you're into steampunk then you'll like them.
There are also a couple of tail wings that need to be glued/epoxied to the tail. I'll be getting to that in the next couple of days.
Overall the Shadow fuselage is very nice looking and I think the entire kit is a good value. If you consider that you can buy a Tarot 450 Pro heli (kit with electronics) for about $275 (w/o shipping) versus the MotionRC Shadow at $329, the value of the fuselage itself easily makes up the $50 difference between the two.
Just received my Airwolf. I am new to the hobby and this Rotor Scale was an amazing opportunity to get a beauty like this at an affordable price. I have a DX8 transmitter, so I'm checking on what I need to get this airworthy. I need two DX satalites and I want to know if I should get an Ikon2/Brain2 flybarless controller. Or - do you think there is a better one for a beginner?
Welcome to the forum! Just a heads up, this is not a beginner heli. Have you flown any collective pitch helis before? I would recommend at least having flown a blade 230S or something similar first. For FBLs, the the ikon/brain is a great choice. Definitely one of the more intuitive units to set up. The Spirit also has some nice features for beginners and scale flying that might be worth looking into as well.Originally posted by CWSMTB View PostJust received my Airwolf. I am new to the hobby and this Rotor Scale was an amazing opportunity to get a beauty like this at an affordable price. I have a DX8 transmitter, so I'm checking on what I need to get this airworthy. I need two DX satalites and I want to know if I should get an Ikon2/Brain2 flybarless controller. Or - do you think there is a better one for a beginner?
I concur with F106 on his statement that this is not a beginners heli and want to reiterate my previous post that the mechanicals need to be removed from the fuselage and inspected before flying. It's a good first scale heli though and if you take your time at the beginning you'll have many satisfying flights.Originally posted by CWSMTB View PostJust received my Airwolf. I am new to the hobby and this Rotor Scale was an amazing opportunity to get a beauty like this at an affordable price. I have a DX8 transmitter, so I'm checking on what I need to get this airworthy. I need two DX satalites and I want to know if I should get an Ikon2/Brain2 flybarless controller. Or - do you think there is a better one for a beginner?
You'll need a separate receiver that has at least 7 channels and you'll use that extra channel for the retract servo. I am running the retracts off the Aux2 channel and switch.
I have a couple of the MSH Brain2 controllers and really like them on my 3D helis but that's not what I'm running on my Airwolf. For the Airwolf I'm using an old Robird G31 since I don't need all of the "bells and whistles" that are on the Brain.
Hi all! New member here. I've been flying rc helis off and on for 10 years, so not a newbie. I have collective pitch helis up to 700 size - mostly Blade and Align. But I've been away from the hobby for a little while, so I'll have to be retrained :). I got the RotorScale B222 a few weeks ago and will start setting it up this weekend. I read this thread and fully agree about taking the mechanics out and rebuilding. I've been bitten by that before.
I have a few questions. Thanks in advance for any help you can provide!
- Should I use governor or throttle curves? Some esc's seem to work better one way or the other. I have mostly Kontronic esc's in my Align helis, and they work great with governor. What about the Hobbywing Platinum Pro 40A?
- What programmer works well with this esc? There seem to be several Hobbywing programmers available.
- What are the best settings for the esc?
- I bought the FC that Motion has in stock and has in the link on their B222 product page - Tarot ZYXS2. Is this a good FC for the B222?
- What are the best settings for the FC?
It will be great getting back into helis. I've always been attracted to scale helis, but never took the leap. After I get this beautiful B222 flying, I'll be opening up the Roban 800 size EC-135 that also jut got delivered. Yikes!
Thanks much!
Ken
