Roban Lakota UH-72 600 Size Helicopter Scale Conversion - KIT
  • Roban Lakota UH-72 600 Size Helicopter Scale Conversion - KIT
    Back in stock last night...
    I popped on one, who got the other one?
Name:	roban-lakota-uh-72-600-size-helicopter-scale-conversion-kit-motion-rc-719850995737_1024x1024.jpg?v=1555996517.jpg
    The Lakota came today and was in perfect condition, it came double boxed both of which are extra thick cardboard. Each piece is individually bubble wrapped and the nose was in a nice foam protective holder.
      Nice George. The Lakota is a sweet helicopter!
        Love the windows on the front of the fuselage. Got pilot figures ready to go?
          I haven't started any cockpit work yet, I'm doing a "out of the box to flying" thread and video first then I plan to detail it out. All you need is a T-Rex 600E(RTF), 4 blade rotor head and blades and a few hours, all the raised-tail parts are included in the kit.
            I started working on the Lakota today, I installed the raised tail pieces that came with the kit on my T-Rex 600E with no issues at all.
            Once I setup the FBL I will remove the tail drive with tube from the elbow and then remove the elbow from the boom so I can install it in the fuselage.
            Added a R.oban 4 blade rotor head
            Next I marked and drilled the tail boom and fuselage for the fasteners.
            I drilled through the ribs as they were the thickest part of the boom.
            I used Foam-Tac for the nutserts because it doesn't get brittle like epoxy or CA
            I will use epoxy on the horizontals so I have drilled them for better adhesion.
            Scribed from point to point and drilled for the outer fins.
            Next is to put the step rail on the skids.
            Then centered the skid and drilled the fuselage.
            She looks better on her legs...
              Next step is to mount the mechanics in the fuselage, the mounts worked great in the skid mounting holes. The front mount screws into the floor but the rear mount slides under the wood catches in the rear.
              Next you need to remove the raised tail so you can install the mechanics in the fuselage, besure to loosen the screws on each end of the elbow so you can reinstall it with the fuselage boom.
              The Trex 600E I used was a model with the swash guide in the rear so I had to trim the fuselage some with a flapper wheel.
              The rear mount slides under these two stops.
              We're now ready to work on the boom.
                Remove the two mounting screws at the front of the mechanics so you can slide them to the rear of the fuselage to give you enough room to get the tail boom installed. Slide the boom over the tube but leave it turn a quarter turn to the left so you can get the elbow installed.
                Click image for larger version  Name:	20191118_220536748_iOS.jpg Views:	0 Size:	92.5 KB ID:	220601
                Click image for larger version  Name:	20191118_214522126_iOS.jpg Views:	0 Size:	75.6 KB ID:	220599
                Click image for larger version  Name:	20191118_214519235_iOS.jpg Views:	0 Size:	100.5 KB ID:	220598
                After sliding the boom on I needed to drill a hole so I could tighten the top hole on the elbow.
                Click image for larger version  Name:	20191118_221657905_iOS.jpg Views:	0 Size:	81.0 KB ID:	220602
                Then install the torque tube and control rod.
                Click image for larger version  Name:	20191118_221926257_iOS.jpg Views:	0 Size:	64.6 KB ID:	220596
                Then install the final piece of the mechanics and tighten the last two screws.
                Click image for larger version  Name:	20191118_222237148_iOS.jpg Views:	0 Size:	121.8 KB ID:	220604
                The mechanics lined up perfectly in the fuselage.
                Click image for larger version  Name:	20191118_233750165_iOS.jpg Views:	0 Size:	125.3 KB ID:	220605
                Click image for larger version  Name:	20191118_233633619_iOS.jpg Views:	0 Size:	77.2 KB ID:	220597
                  I decided against epoxying the horizontals on and decided to use a spar and make them removable. I drilled a hole in the bottom rear corner of the stab opening which will allow the spar to run under the mechanics and help support them. I use a 4mm spar in the fuse then 6mm spars in the stabs.
                  Click image for larger version  Name:	20191119_232923343_iOS.jpg Views:	0 Size:	87.4 KB ID:	220614
                  Click image for larger version  Name:	20191119_232953794_iOS.jpg Views:	0 Size:	183.9 KB ID:	220619
                  Click image for larger version  Name:	20191119_235747639_iOS.jpg Views:	0 Size:	71.2 KB ID:	220613
                  I drilled a hole through the fuselage and stab to secure each side.
                  Click image for larger version  Name:	20191120_220645761_iOS.jpg Views:	0 Size:	46.2 KB ID:	220612
                  Click image for larger version  Name:	20191120_221332522_iOS.jpg Views:	0 Size:	48.9 KB ID:	220615
                  Installed the tail skid
                  Click image for larger version  Name:	20191120_221500970_iOS.jpg Views:	0 Size:	169.0 KB ID:	220618
                  Click image for larger version  Name:	20191120_002847171_iOS.jpg Views:	0 Size:	125.7 KB ID:	220616
                    Next we add the horizontal fins. I just scored a line between the two ends then drilled two holes using the fin as a template.
                    Click image for larger version  Name:	20191120_225854953_iOS.jpg Views:	0 Size:	215.1 KB ID:	220638
                    Click image for larger version  Name:	20191119_233316402_iOS.jpg Views:	0 Size:	138.4 KB ID:	220639
                    Click image for larger version  Name:	20191120_230037195_iOS.jpg Views:	0 Size:	135.2 KB ID:	220630
                    Click image for larger version  Name:	20191120_230652899_iOS.jpg Views:	0 Size:	173.3 KB ID:	220637
                    The model comes with windows and decals but I plan to go another way and will update the thread when I do.
                    Click image for larger version  Name:	20191120_233907875_iOS.jpg Views:	0 Size:	152.7 KB ID:	220631
                    The last pieces are the antennas and wire cutters.
                    Click image for larger version  Name:	20191120_234750662_iOS.jpg Views:	0 Size:	104.1 KB ID:	220629
                    Click image for larger version  Name:	20191120_233644410_iOS.jpg Views:	0 Size:	62.2 KB ID:	220628
                    Click image for larger version  Name:	20191120_233605324_iOS.jpg Views:	0 Size:	126.4 KB ID:	220634
                    The UH-72 Lakota is a great looking helicopter and the raised tail sure makes it look larger than a 600
                    Click image for larger version  Name:	20191120_235901968_iOS.jpg Views:	0 Size:	171.6 KB ID:	220633
                    Click image for larger version  Name:	20191120_235938634_iOS.jpg Views:	0 Size:	175.4 KB ID:	220635
                    Click image for larger version  Name:	20191121_000023966_iOS.jpg Views:	0 Size:	194.6 KB ID:	220636
                    • #11
                      Very Nice George! Hope to get to your shop in the near future.
                      Roy Mayoral
                      • #12
                        The Lakota is such a striking twin engine helicopter. In its EC145 form, it is often seen in flashy color schemes, but there is something so monolithic seeing it in all OD! I like helicopters best in OD or black.
                        What are your plans with this beautiful beast, George?
                        Heli143 George's place is RC heaven. Although you may leave with one or two less helicopters than you came with!
                        • #13
                          I plan to make a cockpit, add lighting and some 3D printed accessories then repaint it...I can't believe how big it is compared to most other 600 size scale kits
                          • #14
                            So this is like your 5th heli acquisition within the past two months
                            Haven't seen any maiden flights yet............
                            I am especially keen to see the awesome CH-34
                            Glad to see ya going full tilt boogie in this sport bro
                            • #15
                              I never have anyone to video me
                              • #16
                                Since the heli king of your neck of the woods happens to be your close bud, time to get your butt over there filming Steve
                                • #17
                                  Looking forward to seeing it detailed out!! I need to make it up to your place sometime. I love seeing so many threads on these beautiful helicopters!
                                  • #18
                                    Maybe you can come up after Darrell's event ;)
                                    • #19
                                      Hi, I’m the person who picked up the other 600 size UH 72 Lakota when it briefly came back in stock. I just got around to starting my build today and was truly disappointed to learn that instructions are in German. Hence I’m very grateful for your post with photos and notes. Thank you. Have your flown yours yet?
                                      • #20
                                        Welcome to Hobby Squawk Scale Pilot, glad you joined us here! Be sure to post up pictures of your build so we can follow along :)
                                        I haven't flown it yet, it's been raining and I've had bronchitis, coughed a rib loose so all I've been flying is a recliner :(
                                        The next time it's dry and Steve or John is here I'll get some video.
