Roban 600 Airwolf build
  • Gravythe clown
    • Mar 2019
    • 711
    • Clovis, California
    So I’ve started my build and thought I would document it (the best I document which isn’t saying much).
    the build is going to have:
    Roban 600 Airwolf kit
    T-Rex 600N pro
    trex FBL conversion kit
    new align servos DS615
    scorpion 4025 740kv motor
    4025 5mm motor shaft
    microbesst plus
    castle creations Talon HV120 esc
    FrSky 6ch rx
    CNC motor mount kit (custom)
    Old Greatplanes 5mm prop adapter.
    i just finished printing out the first mockup for the motor mount kit. I had to make some minor adjustments and plan to print the next set tonight. If all goes good the files will be sent to the CNC guy next week.
    if all goes good first spool up if converted mechanics will be in two weeks or sooner.
    my Airwolf kit arrives Monday. I will start on that while I get the mechanics all worked out.
    i will update as things happen and complete.
    Gravy
  • DCORSAIR
    • 1918
    • Selma, Ca.
    Those nitro 600 conversion to electric work great for a scale turbine spool up, can't wait to see the Airwolf with that setup in it, should work great.
    • Gravythe clown
      • Mar 2019
      • 711
      Fedex update.
      Airwolf will be here today.
      • DCORSAIR
        • 1918
        • Selma, Ca.
        Woohoo, your the scale heli pilot now, bet you wish you have never met me.
        • Gravythe clown
          • Mar 2019
          • 711
          Not so much me but wife on other hand. Let’s just say I bet your not getting Malaysian cookies for Christmas.
          gravy
          • DCORSAIR
            • 1918
            • Selma, Ca.
            gravy
            :ah-64:
            • Gravythe clown
              • Mar 2019
              • 711
              Fuse showed up. She a beauty.
              Gravy
              • sfcfury
                • Mar 2019
                • 490
                • Baton Rouge, La
                So does that gas to electric adapter almost act like a clutch? I mean I know its not a clutch... but hmmmm....
                • DCORSAIR
                  • 1918
                  • Selma, Ca.
                  I like it better than the Funkey one, that front part coming off like that is so much better than the Funkey, where just the top of the doghouse came off, I forgot the Roban one was like that.
                  • DCORSAIR
                    • 1918
                    • Selma, Ca.
                    Yes, it's the actual clutch from a Trex 600N mounted to a prop adapter, works great and the spool up is so much more scale, Gravy will explain to you.
                    • Gravythe clown
                      • Mar 2019
                      • 711
                      No but the adapter allows me to use the clutch. I'm still using the clutch, the shoe and the fan mount. The fan mount mounts to the Electric motor using a prop adapter, Then I use the new motor mount to mount it all into the frame.
                      Hope that helps
                      Gravy
                      • sfcfury
                        • Mar 2019
                        • 490
                        • Baton Rouge, La
                        Hmmm definitely would like to see a picture of all that mounted together...
                        • Gravythe clown
                          • Mar 2019
                          • 711
                          I’ll be posting pics as the build goes. Hopefully all goes well next week I’ll have the mounts.
                          Gravy
                          • Gravythe clown
                            • Mar 2019
                            • 711
                            Here is am image of the motor mount parts I going to have cnc'd.
                            Gravy
                            • Gravythe clown
                              • Mar 2019
                              • 711
                              I’ll print the right side tomorrow. But so far the left side is perfect. If the right is good then next week I’ll hopefully meet with the CNC guy and give home my STL’s. Cross fingers all will be done and ready for test flight next weekend.
                              Gravy
                              • Gravythe clown
                                • Mar 2019
                                • 711
                                Well proof prints are done and I’m 100% satisfied. Next off to get them CNCed.
                                Gravy
                                • Gravythe clown
                                  • Mar 2019
                                  • 711
                                  Started the gear assemble. The instructions are missing a few things and steps. Like the aluminum bushings that going in the winglet for the gear rods. For future builders there is a short one and a long one. They both get put in from inside the wells. So the short one goes in and towards the outside and the long one goes towards the inside.
                                  Gravy
                                  • Gravythe clown
                                    • Mar 2019
                                    • 711
                                    I’m having issues getting my parts made. I was going to have one of the machinist students make it for (pay him of corse, nothings free) but because of COVID all student found jobs until school is back to class. So I’m talking to a guy that owns his own shop. Crossing my fingers he will do it.
                                    When I get the parts I can finish setting up the mechanics and fly them.
                                    im changing up the retracts servo. I’m putting the servo where the throttle servo goes in the frame. I will then do a downward arm to a servo horn mounted on the frame which will then transfer the vertical control rod movement to a horizontal control arm, which will connect to the front retract rod horn.
                                    i also figured out how I’m going to make my battery tray which will be attached to the 600n frame.
                                    I really hope to finish this build in the next couple weeks.
                                    Gravy
                                    • Gravythe clown
                                      • Mar 2019
                                      • 711
                                      Got motor mount pieces today. Did a first test fit. Did find something I will change if I have another set made. The mount cost me $85 to have made. All three pieces are made from 6061. Also has my battery try made. That cost me a12 pack of 805.
                                      i have to pick my son up this weekend. So since he’ll be back home and back to school, my progress will get a little slower. But I hope to have this test flying in a couple weeks.
                                      Gravy
                                      • Gravythe clown
                                        • Mar 2019
                                        • 711
                                        Got a first spool up and flight on my mechanics today. Still need to tune up my helicopter a little more before she goes into the body. But she getting close.
                                        here is a video of the spool up.
                                        gravy
