Roban 600 Airwolf build
  • Gravythe clown
    • Mar 2019
    • 711
    • Clovis, California
    Well she’s ready to stuff the bird. Got two great flights on the mechs today. She runs smooth and will even be smoother with the extra weight.
    8s was the magic number. Motor temp was 90f after 5 minutes of flight. I’m running with 45% head room, more than I like but esc was nice and cool too.
    so now to put her in her new home.
    Gravy
    • Gravythe clown
      • Mar 2019
      • 711
      She’s done and ready to fly.
      Gravy
      • ridgerunner
        • Nov 2017
        • 275
        • Central Utah, USA
        Sweet! +1
          • 2818
          • Arlington, TX
          Gravy
          Looking good!
          • rc_heli_flier
            • Oct 2019
            • 19
            I'm working on one of these right now myself. I have a question - the windows for the doors do not fit in the window opening - they are too big. What did you do to make yours fit other than just simply trimming them to fit. All of the other windows fit in the openings ok.
            • Gravythe clown
              • Mar 2019
              • 711
              Didn’t get windows for my doors. Honestly I didn’t pay attention and just thought it didn’t come with them by design.
              now I need to decide if I want to buy the spare parts window or just leave them off.
              Gravy
              • rc_heli_flier
                • Oct 2019
                • 19
                I'll try and get a couple pictures of those windows, they don't fit into the openings, the raised window portion that should sit down into the opening is too big. If they are all like that you might want to just save your money and not buy them. I think mine were all packaged together, but if you still have you box it came in check to see if they are in there.
                I have mine ready for the first run of it with the mechanics installed. I was a great flying Trex 550 Dominator before I put it in the fuselage, so hopefully it still will be a great flying heli with just a new skin. lol
                Leon
                • Gravythe clown
                  • Mar 2019
                  • 711
                  Yeah I’m not worried about not having them. I’ll leave them out for ventilation purposes.
                  hope your maiden goes good.
                  Gravy
                  • rc_heli_flier
                    • Oct 2019
                    • 19
                    Here is what they look like. Way too big. Think I'm going to leave them out as well for airflow.
                    Did you get to maiden yours yet?
                    Leon
                    • Gravythe clown
                      • Mar 2019
                      • 711
                      No just finished it this weekend. Hope to this upcoming weekend. I’ve flown the mechanics already a bunch of times. It’s a 600n converted to electric while keeping the clutch. Has a nice start up. Like you posted, not expecting and issues, good helicopter with new skin.
                      Gravy
                      • Gravythe clown
                        • Mar 2019
                        • 711
                        She flew. Had to adjust my pitch curve a tad but that was it. However I do need to work some more in the gear. Once I get that done she spend a bunch of time in the air.
                        Gravy
                        • Gravythe clown
                          • Mar 2019
                          • 711
                          So last time I took her out to put her through the paces, the gear gave me nothing but issues. So I decided to do a whole gear overhauled. All three CF rods are changed out now with new steel rods. I still need to grind in some flats for the grub screws but on a dry test it’s now butter smooth. Second I will make the gear ridged. No more shock spring. I decided to do this as I got some major ground resonance while the aircraft was in the spring range during both take off and landing. Also she just squats down to low when the gear compresses.
                          Hopefully this takes care of my LG issues.
                          Gravy
                          • liberoreiter
                            • Nov 2020
                            • 9
                            • Greiz, Thueringen,Germany
                            Hi!
                            The landing gear maks also a lot of trouble in my 500 Airwolf. After a crash I made it a little more scale. The gear locked in both directions, so the servo is without
                            pressure. I builded in some ballrings and reinforcement for the axes.
                            Jens
                            • sfcfury
                              • Mar 2019
                              • 490
                              • Baton Rouge, La
                              Originally posted by liberoreiter
                              Hi!
                              Jens
                              Your rivets look pretty good! Did you free hand those, or perhaps used a rivet strip?
                              • liberoreiter
                                • Nov 2020
                                • 9
                                It's self-adhesive film , cutting by Laser 1,5 mm, distace 4x4 mm. I cut it in stripes how I need it.
                                • Gravythe clown
                                  • Mar 2019
                                  • 711
                                  Got her all back together and did a test hover and gear check Sunday. It could have ended very badly, but luck was smiling on my.
                                  Everything went smooth. Gut her started up and lift off nice and gently. Did a few gear up / gear down with no issues. Did some side to side and yaw left yaw right. All went smooth. About 3 minutes into this I thought about taking out for a run but finally decided on just set her down. As I was about 1” -2” off the deck, the motor just died. WTF! She set down all sweet and just finished coasting to a stop.
                                  Motor and ESC not even warm. Tried to restart it but she just stuttered. Took her back to the pit for closer inspection.
                                  one of the motor leads came out of the CC HV120.
                                  So many things went through my head at this point.
                                  so I made a lead lock. This should never happen again.
                                  Gravy
                                  • PawPaw
                                    • Jan 2019
                                    • 539
                                    • Baytown, Tx
                                    Dangit, Gravy! You are becoming my textbook reference for “Things That Can Break And Do”.
                                    • Gravythe clown
                                      • Mar 2019
                                      • 711
                                      Lmao
                                      but at-least I can fix them.
                                      cobra get primer tomorrow by the way. I’ll post in that thread an update after it dries.
                                      Gravy
                                      • Muscleflex
                                        • May 2023
                                        Are you still active Gravy? I just came across your thread and have some question on your conversion pls
                                        • Gravythe clown
                                          • Mar 2019
                                          • 711
                                          Yeah I'm still here. ask away I'll see what kind of answers I can give you. LOL
                                          Gravy
