Ronan 500 AH-1Wx
  • Gravythe clown
    • Mar 2019
    • 711
    • Clovis, California
    Tomorrow. Tomorrow. Your only a day away.
    Gravy
    • Gravythe clown
      • Mar 2019
      • 711
      I got my decals. So gloss coat and right side done. Tomorrow I’ll do left side. Let them sit a day or two and then mat coat. After that dries I can finish it up.
      this one is coming out great.
      Almost can’t tell it was wrecked.
      Gravy
      • DCORSAIR
        • 1918
        • Selma, Ca.
        Gravy
        Oooooh, I see you got my Cobra almost ready for me to pick up, looks awesome with the decals and new paint job.....
        • PawPaw
          • Jan 2019
          • 539
          • Baytown, Tx
          Can’t wait to see the finished mat coat. Great work!
          • Gravythe clown
            • Mar 2019
            • 711
            Got the left side done tonight. You night will be the dull coat. If all goes good she’ll be installed by end of next weekend.
            Gravy
            • DCORSAIR
              • 1918
              • Selma, Ca.
              Wow that looks good, soon to be mine one day...:hugging::stuck_out_tongue_cl
              • Gravythe clown
                • Mar 2019
                • 711
                • PawPaw
                  • Jan 2019
                  • 539
                  • Baytown, Tx
                  Find out what day Gravy plans to miracle those mechanics back in the fuse, then show up 15 min after he starts. He’ll thank you for taking it off his hands.🤔
                  • DCORSAIR
                    • 1918
                    • Selma, Ca.
                    I have been giving him a bad time about taking his Cobra (his pride and joy) off his hands ever since I seen his first flight with it, and after seeing the crash and then the rebuild, he has done a great job on the rebuild, so I have come to the conclusion that I won't be getting it anytime soon, so Gravy, you can rest now that I won't be sneaking over there and stealing your Cobra.......
                    • Gravythe clown
                      • Mar 2019
                      • 711
                      we’ll see if that’s the case this time. Iz havez an Ideaz. If all goes as I plan it should be easy peezy.
                      Gravy
                      • Gravythe clown
                        • Mar 2019
                        • 711
                        Things left to do.
                        secure front mechanics into ply bed. Secure cockpit into canopy. Wire connect lighting to rx. Trim little bit of fuse at tail control arm. Fly.
                        it did go in much easier this time. Only a few curse words used.
                        si this time I drilled and taped a screw hole in both the horizontal and vertical parts of the tail riser set. This allowed me to shave off the locking plastic nob inside that keeps it all from twisting freely so inserting the tubes would be easy.
                        by doing this I was able to slide the mechanics in without the tail riser and add it in through the back. Then to lock it in place I simple add the new locking screw. This worked out great. The same was done for the riser tube. Took all of 5 minutes, the second time.
                        the first time I found out that the new control balls I added on the triangular control rod transitioner were sticking out to far. So I had to pull the whole tail riser setup out to fix that.
                        She should be ready to fly this weekend. DCORSAIR I’m looking at you. Time to get our Apaches together for a play date, you also need to hydrate as you’ll be drooling over MY cobra. 😜
                        Gravy
                        • DCORSAIR
                          • 1918
                          • Selma, Ca.
                          Just awesome Gravy, your turning out some nice scalers....
                          • PawPaw
                            • Jan 2019
                            • 539
                            • Baytown, Tx
                            Great work, Gravy....DC’s tongue about to slap his brains out.😂
                              • 2818
                              • Arlington, TX
                              Looks excellent, nice work!
                              • DCORSAIR
                                • 1918
                                • Selma, Ca.
                                Yep, but he won't let me get to close to that Cobra, I will just have to get me one and build it myself.............
                                • Gravythe clown
                                  • Mar 2019
                                  • 711
                                  Vibrations gone, now to change to two blade tail for more scale accuracy and better control.
                                  so I also found these two gems on the AH-1W 4 bladed test bed.
                                  I think AH-1Wx sounds better.
                                  Gravy
                                  • PawPaw
                                    • Jan 2019
                                    • 539
                                    • Baytown, Tx
                                    Great news. Looks awesome too.
                                    • Gravythe clown
                                      • Mar 2019
                                      • 711
                                      Thanks, DCORSAIR helped me get it sorted today. It’s good to have a helicopter buddy to do a buddy check for you now and then. He did seam to get a little to touch feely, but I kept a close eye on him.
                                      Gravy
                                      • PawPaw
                                        • Jan 2019
                                        • 539
                                        • Baytown, Tx
                                        Oh let DC cop a feel....I’m sure he’ll respect her in the morning. 😉
                                        • Gravythe clown
                                          • Mar 2019
                                          • 711
                                          Put a bow on her gentlemen, she’s done. Got a great flight out of her today. She handlers beautifully.
                                          now to start the Blackhawk.
                                          Gravy
