450 Scale UH-1C Huey Gunship build
    • 2818
    • Arlington, TX
    Originally posted by Tron
    Been a while but wanted to ask you if this starting fuselage is same as Roban one? I like what you did on the windshield. Can you elaborate on the cut amount trimmed off and what you used for the windshield?
    I don't have your super scale skills.but I'd like to eventually (after flying as it) try to correct the fun scale looks of the windshield a bit.
    When you take off the screwed-in stock windshield, there is an indentation that it fits into. Use the edge of this indentation as a guide to cut out that inner portion with a Dremel cutoff wheel. If in doubt, have a front view of the aircraft up on your phone for additional reference before you cut, and mark off your cutting lines. For the windshield, I used a sheet of clear plastic, something similar to this: https://www.hobbylobby.com/Crafts-Ho...015%22/p/97971, and glued it in from the inside of the fuselage. Make sure you have plenty of clamps to hold it down while the glue dries. Hope this helps!
