Official Fly Wing 450 Size UH-1 Huey GPS Stabilized Helicopter RTF Thread
    • 8231
    This innovative aircraft combines the sport capabilities of a 450 size helicopter with the rock-solid stability of a GPS-stabilized flight control system. Similar to high-end drones, this system links with GPS satellites in orbit to maintain positional awareness at all times. Sold as an RTF ("Ready To Fly") package, this Fly Wing UH-1 Huey includes almost everything you need to fly except the four AA transmitter batteries. All radio programming is completed at the factory for you and Motion RC carries a full range of spare parts at an affordable price.
    Featuring a carbon fiber frame, dual brushless motors, a high precision flybarless flight controller, and Omni H1 GPS technology, and a long flight duration of 8-13 minutes on an economical 4S LiPo battery, the UH-1 Huey is the perfect helicopter for intermediate pilots looking for a casual trainer that can also push the envelope toward sportier flying.
    NOTE: the one-click reverse feature is turned off by default, as it may damage the body. This can be turned on by linking with a PC.
    Effortless Wind Resistance
    Thanks to the GPS-stabilized flight control system, the UH-1 Huey can negotiate the flight environment with ease. The rock-solid stability of the flight control system links with GPS satellites in orbit to maintain positional awareness at all times.
    Brushless Tail Motor
    The UH-1 tail adopts a high-speed brushless motor for a long service life, fast response and easy maintenance. The silent blade design reduces sound and increases efficiency.
    Scale Details
    The Huey offers scale features such as the exhaust and other elements of the hollow mesh design that help bring the historic helicopter's storied history back to life.
    Reliable Radio Control
    Featuring a modern 2.4GHz 10 channel radio transmitter, the Huey can be operated near other RC vehicles without risk of losing signal. Conveniently, all of the basic flight mixes and functions are pre-programmed at the factory for you.
    Return To Home Feature
    With the Return To Home feature, the UH-1 will always make a safe journey home in the event of a low battery or signal loss for that extra bit of confidence and insurance.
    Stability At Any Altitude
    With GPS Mode the UH-1 resists any variance in altitude or direction when the stick is released. The stability is rock-solid which provides that extra level of protection when engaging in your flight sequence.
    Features:
    • User friendly GPS-assisted flight modes including One-Touch Takeoff and Automatic Landing via included pre-programmed radio transmitter
    • RTF ("Ready To Fly") convenience with simple computer calibration and one minute physical assembly
    • Dual Brushless Direct Drive Motor design eliminates 90% of moving parts for less vibration, less setup, and longer lifespan
    • GPS automatic stabilization and 3D manual modes
    • One-touch return to home
    • Low power and signal loss automatic return to home
    • Hands-free figure 8's
    Includes:
    • Fly Wing UH-1 Huey 450 Size GPS Stabilized Helicopter - RTF
    • 2.4GHz radio and receiver
    • 4S Charger
    • 4S 14.8V 3000mAh Lipo Battery with XT60 connector
    AGE LEVEL :14 and up
    SKILL LEVEL :Intermediate
    BUILD TIME :10 Minutes
    Class / Size 450 Size
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Plastic
    Overall Size (L x W x H) 750mm (29.5") X 155mm (6.1") X 220mm (8.7")
    Weight (without battery) 836g (29.5 oz)
    Main Rotor Diameter 810mm / 31.8"
    Main Rotor Blade Length N/A
    Tail Rotor Diameter N/A
    Tail Rotor Blade Length N/A
    Tail Drive Type Brushless Motor
    Cyclic Servos H041 13g Metal Gear Servo - RSH1005-112
    Tail Servo N/A
    Power System 3508 Brushless Motor
    Electronic Speed Control 60A
    Recommended Battery Admiral 4S 3000mAh with XT60 connector
    Required Radio 2.4GHz Radio (Included)
    Skill Level Intermediate
    Build Time 10 minutes
  • SilentTiger
    • Nov 2019
    • 10
    Have one on the way.😎. Been looking to ad a Huey to my collection. And hopefully with this one I can get my 10 year old flying
    • SilentTiger
      • Nov 2019
      • 10
      Arrived today. Well packaged. Rest assured they took care this would fair well in shipping. Will dig into it this weekend but so far I like what I see.
      • Madorin1979
        • Sep 2020
        What radio setting for mb500 type swashplate?
        • SilentTiger
          • Nov 2019
          • 10
          First impression, in gps mode pretty darn stable for a heli. Slight drift specially when you rotate. But to be honest all I did was charge pack, bolt on main blades and throw the lipo in. The v3 version will calibrate in a few minutes all on its own. Nice feature by the way. No drone dance required. More to come once we have better weather and I get out to the field. Still need to figure out how to post video here Click image for larger version
          • Marck_c
            • Jul 2023
            What scale do these 450s approximate to? 1:12, 1:18? It would be nice to add some more scale details to these Flyhigh fuselages
            • SilentTiger
              • Nov 2019
              • 10
              I would say close to 1/18 in scale. Being the real Huey is just under 58 ft in length with rotor and this one is 36 and a 1/2 inches in length.
              • Glam
                • Mar 2022
                • 10
                Q: what mode does the factory TX come in? 1 or 2, or selectable? :smirk:
                • Glam
                  • Mar 2022
                  • 10
                  I'll answer that myself now. Have received it. It's selectable on the provided Flysky FS-i6s transmitter.
                  Thanks to myself for being such a great help! I'm welcome.
                  • Glam
                    • Mar 2022
                    • 10
                    Allow me to share some pics of my mod to the factory model.. just way too TOY n the color's all too vivid i felt.
                    I dremel-ed the doors open, resprayed the body with Krylon's camo OD, re-stencilled the boom 'ARMY' into 'MARINES', gave it a weathering wash of dusty buff acrylic, then drew on panel lines with a sharpie marker. Followed by brown and black pastel chalk weathering to accentuate the lines, and a silver fine paint-pen to add on body scratches and some sand-blasted weathering effect on top surfaces to mimic chipped paint. Finished with an overall semi-gloss varnish to seal in the chalk and even-out the whole sheen.
                    I'm liking it a lot more now!
                    • Erk187
                      • Sep 2024
                      Got mine today, a month of waiting, promises of delivery, chasing the worst delivery company around all day yesterday when they claimed my house didn’t exist. I was forewarned of the wobble that these have and was prepared to combat it, so I measured the blades with a micrometer for length and consistency, weighed them, they were exact.. then assembled it, brought it out to our field and spooled it up, noticed a bit of shake, it was rattling on the ground, but when launched, no problem, flew like a dream. Got it on video, first flight, was great. The circling, figure 8, all worked well. Tested the landing, it was good, rattled a bit before shut down, but all good. Launched again, flew great, battery lasted well, commented to my friend “ this thing flies for ever!” Landed it, then he launched his plane and was flying round, so I spooled the heli up, preparing to launch, it was vibrating, I took a second to get to the controls and all the sudden, it drops sideways, flops around, I kill the power Immediately ( I highly suggest that anyone be very clear on how to shut it off fast) turns out that before I took off, the landing skids just collapsed from the vibration, wore themselves out and just dropped the helo to the ground. No chance of control when that happens. I was just blown away. When I looked at it, the skid just laying there, and the brand new helo.. I was like WTF? Guys. CHECK YOUR SKIDS EVERY FLIGHT before you fly for any cracks or anything. The worst part is that now I will have to wait for another month and I have to take the whole damned thing apart again all of the way, because those screws are not easy to access with human adult hands, and they are on the bottom-inside of the heli.. see my pics. Wish I could post video of the wobble on the ground…
                      But this is a potentially fatal flaw in the design of this, worse yet, the days of waiting because you can’t launch without the skids, and definitely cannot land without them, it doesn’t just shut down. I’m pissed
                      • helicrashman
                        • Sep 2024
                        • 8
                        It takes a whole 15 minutes to pull out the whole drive frame out and in. You might find that some of the landing gear screws are under the plywood floor. (some are some are not) If they are just drill a whole where the screw is and remove it. They will not take hard and i mean even semi hard landing on asphalt or rocks or concrete. There plastic is very brittle . If i find the stl file for the landing gear I have it but as usual I never renamed it landing gear. You can print it in petg
                        • FlyinHawaiian
                          • Jan 2024
                          • 19
                          Got a couple flights today. Having fun! Added some detail to mine. Tinted the two top windows green like the real ones. Painted over the medical emblem and added a couple pilots and missiles.
                          • RichJohnson
                            • 1276
ID:	425113 Hello all. Just got the flying 450 size UH1 Huey.
                            First flight.
                            I noticed this thing has insane vibration. The video I took doesn't capture it but I kinda feel like this thing will eventually disintegrate in flight. The shake and vibration is very violent. Usually only a bent main shaft causes this, but this is new and first flight.
                            I'm wondering if it's because of the scale blade links keep the blades fixed firmly where they are and they will never be balanced against each other at 180 degrees like free folding blades are.
                            No matter how much I wiggle the blades in their tight grips they will never be even and balanced.
                            Would removing the scale link and opening the blade grip up a tad so the blades free fold and then swing out on spin up solve this violent vibration and wobble?
                            • Vintage
                              • May 2025
                              • 3
                              • Vintage
                                • May 2025
                                • 3
                                I agree a little toyish I would have done the same it I chose this one but I pic the Bo-105 and iam changing the color
                                kevin
                                • mike_eee
                                  • Apr 2018
                                  Nice , How did you tint the window? what did you use?.. Also i like how stiff the stabiizer bar is on yours, Mine is like a wet noodle , did you do anything to stiff it up?
                                  Mike RC
                                  • FlyinHawaiian
                                    • Jan 2024
                                    • 19
ID:	429295 Sorry didn't reply sooner. Fishing season here so been doing more of that and not much rc stuff. I didn't do anything for the stabilizer. Just mounted it​ I used this stuff I got from Amazon for the tint. " Christmas Transparent Decorative Window Film,Green Transparent Film Window Tint Film. Cost about​ $10 bucks and you get enough to do a whole lot of windows!
                                    Aloha!
                                    Joe
