This innovative aircraft combines the sport capabilities of a 450 size helicopter with the rock-solid stability of a GPS-stabilized flight control system. Similar to high-end drones, this system links with GPS satellites in orbit to maintain positional awareness at all times. Sold as an RTF ("Ready To Fly") package, this Fly Wing UH-1 Huey includes almost everything you need to fly except the four AA transmitter batteries. All radio programming is completed at the factory for you and Motion RC carries a full range of spare parts at an affordable price.
Featuring a carbon fiber frame, dual brushless motors, a high precision flybarless flight controller, and Omni H1 GPS technology, and a long flight duration of 8-13 minutes on an economical 4S LiPo battery, the UH-1 Huey is the perfect helicopter for intermediate pilots looking for a casual trainer that can also push the envelope toward sportier flying.
NOTE: the one-click reverse feature is turned off by default, as it may damage the body. This can be turned on by linking with a PC.
Effortless Wind Resistance Thanks to the GPS-stabilized flight control system, the UH-1 Huey can negotiate the flight environment with ease. The rock-solid stability of the flight control system links with GPS satellites in orbit to maintain positional awareness at all times. |
Brushless Tail Motor The UH-1 tail adopts a high-speed brushless motor for a long service life, fast response and easy maintenance. The silent blade design reduces sound and increases efficiency. |
Scale Details The Huey offers scale features such as the exhaust and other elements of the hollow mesh design that help bring the historic helicopter's storied history back to life. |
Reliable Radio Control Featuring a modern 2.4GHz 10 channel radio transmitter, the Huey can be operated near other RC vehicles without risk of losing signal. Conveniently, all of the basic flight mixes and functions are pre-programmed at the factory for you. |
Return To Home Feature With the Return To Home feature, the UH-1 will always make a safe journey home in the event of a low battery or signal loss for that extra bit of confidence and insurance. |
Stability At Any Altitude With GPS Mode the UH-1 resists any variance in altitude or direction when the stick is released. The stability is rock-solid which provides that extra level of protection when engaging in your flight sequence. |
- User friendly GPS-assisted flight modes including One-Touch Takeoff and Automatic Landing via included pre-programmed radio transmitter
- RTF ("Ready To Fly") convenience with simple computer calibration and one minute physical assembly
- Dual Brushless Direct Drive Motor design eliminates 90% of moving parts for less vibration, less setup, and longer lifespan
- GPS automatic stabilization and 3D manual modes
- One-touch return to home
- Low power and signal loss automatic return to home
- Hands-free figure 8's
- Fly Wing UH-1 Huey 450 Size GPS Stabilized Helicopter - RTF
- 2.4GHz radio and receiver
- 4S Charger
- 4S 14.8V 3000mAh Lipo Battery with XT60 connector
- Four (4) AA size batteries for the radio transmitter we recommend Admiral NiMH AA Rechargeable Batteries (4 Pack)
- Windows PC required for initial setup and calibration
- 4S 14.8V 3000 - 5000mAh LiPo battery - we recommend the Admiral 3000mAh 4S 14.8V 35C LiPo Battery with XT60 Connector
AGE LEVEL :14 and up
SKILL LEVEL :Intermediate
BUILD TIME :10 Minutes
| Class / Size | 450 Size |
| Power Type | Electric |
| Rotor Type | Collective Pitch |
| Body Material | Plastic |
| Overall Size (L x W x H) | 750mm (29.5") X 155mm (6.1") X 220mm (8.7") |
| Weight (without battery) | 836g (29.5 oz) |
| Main Rotor Diameter | 810mm / 31.8" |
| Main Rotor Blade Length | N/A |
| Tail Rotor Diameter | N/A |
| Tail Rotor Blade Length | N/A |
| Tail Drive Type | Brushless Motor |
| Cyclic Servos | H041 13g Metal Gear Servo - RSH1005-112 |
| Tail Servo | N/A |
| Power System | 3508 Brushless Motor |
| Electronic Speed Control | 60A |
| Recommended Battery | Admiral 4S 3000mAh with XT60 connector |
| Battery Compartment Size (L x W x H) | N/A |
| Required Radio | 2.4GHz Radio (Included) |
| Skill Level | Intermediate |
| Build Time | 10 minutes |
