Official RotorScale 470 Size Airwolf Super Scale GPS Stabilized Helicopter Thread
    • 8835
    Originally posted by Jeffrey taylor
    I put a h1 flight controller in my align 600 esp and when It's spooling up I have no movement in tail rotor servo with stick movement. Is this common until it gets airborne?
    In my Flywing helis where the H1 is standard equipment, tail rotor responds to rudder stick even while sitting on the ground and also during spool up. It does it by speeding up or slowing down the tail motor. Does your 600 have an electric tail motor or does it have a push rod that changes the tail rotor pitch? I may be mistaken but I think the H1 only works on electric tail motors where the motor speed changes to counter torque by adjusting tail motor speed.
    • Marion1988
      • Aug 2025
      • 3
      I have a question. I purchased a Rotorscale 250 size Apache AH-64. On the helicopter and on the case the helicopter came in it says "YU XIANG" F11S 1:32 scale it says on the case, so who manufactured and assembled this helicopter? If it was "YU XIANG"? Then how does Rotorscale play into all of this?
        • 8835
        You should post your question in the Rotorscale 250 AH-64 thread:
        AH-64 Apache 250 Size GPS Stabilized Helicopter - RTF from Rotorscale - RSH1018-001 Unleash the thrill of flying with the RotorScale AH-64 Apache, a GPS-stabilized helicopter that combines the precision of advanced technology with the iconic look of the renowned AH-64 military gunship. Designed to be both beginner-friendly
        This thread is for the Rotorscale 470 Airwolf.
        • Rob W
          • Sep 2025
          Hi, Looking at purchasing this helicopter but seem to be a little confused as to the actual bits I need to do to get it flying.
          some things I’ve read say that is ready to fly , charge up and off you go. Other things say you have to stick the windows in and so on, what is actually needed to be done. Thanks in advance.
          Rob.
          • Rob W
            • Sep 2025
            Rob.
            • davidurban_1@msn.com
              • Jan 2026
              First flight out of the box!! Preflight check was good. Made a couple of passes. Went up like it was RTH. Lost GPS. Spun enough to eject the battery. Not happy with this product at all. Still within warranty but will Motion RC honor it??? Anybody else have issues with this platform?
              • PilotTony
                • Jun 2016
                • 18
                Originally posted by turdlauncher
                update on flight case found this 1195x400x423 mm £212.00 inc vat
                https://www.terralec.co.uk/flight_ca...m/20944_p.html Click image for larger version
                Did this case fit the heli?
                • PilotTony
                  • Jun 2016
                  • 18
                  I just purchased this heli a couple of weeks ago. First time with GPS heli and all I can say is WOW! These fly fantastic coming from a 34 yr RC airplane guy. I did have some major issues and wanted to pass along my experiences.
                  When I initially got the heli, the landing gear would not go all the way up into the wheel well. I watched the MRC video on how to adjust and ended up stripping the left side trunion. MRC was kind enough to send out hardware for the repair. This time had to take the entire "power train" out to access the area to replace the trunion and grub screw. Again another great how to video from MRC, however they didn't mention I had to cut two zip ties to loosen two servo leads. No big deal and eventually got it out. 4 screws and out she came. Right away I noticed that one of the "ears" that holds the power train to the fuselage was cleanly broken loose (aircraft right). I promptly reglued with Loctite EA1C (hysol) and got her back together. This all happened before I even had a chance to maiden her.
                  Four uneventful flights were flown and was getting used to GPS stabilized flight. Looks and works fantastic. Fifth, flight ended in near disaster. As I was hovering 10 feet off the ground, the canopy suddenly loosens and flights straight up threw the main rotor! Incredibly it floated to the ground with just had a small paint chip. The heli was still hovering and I brought it back in for a routine landing sans canopy. Back to the work bench to assess damages.
                  Clearly that same ear was broken off and dangling by the screw that attaches to the fuselage. Once again, I had to take out the power train to make the repairs. This time I found both ears broken off! What apparently happened in my opinion was that the broken ear caused a twist to the fuse which allowed the canopy to come loose and get ejected off the heli. At this point I wanted to return the heli for a replacement. Motionrc would not honor the return since I had several flights on it and they considered it a "crash". My "consolation prize" was a $150 gift certificate so I could purchase spare parts. I expect a lot more from a $1000 helicopter and Motionrc. To say I'm disappointed is a major understatement. As a seasoned builder, I could see that they ears broke off cleanly and a QC issue from Roban.
                  I am currently regluing the ears with an Aerospace grade epoxy and it should never break ever again. I hope others out there will not have the same experience. It truly is a cool nostalgia heli from my childhood and I find myself humming the Airwolf theme song while I fly it. I look forward to many uneventful flights after this repair.
                  • turdlauncher
                    • Mar 2025
                    • 6
                    hello pilot tony i did not get that case that was one i found but as far as i can remember it was a few cm short so i built my own
                    • turdlauncher
                      • Mar 2025
                      • 6
                      will not let me attach instructions and links for case
                      • PilotTony
                        • Jun 2016
                        • 18
                        I sent you a PM
                        • PilotTony
                          • Jun 2016
                          • 18
                          Has anyone tried to revert the throttle stick to a conventional ratchet type throttle as opposed to sprung to the middle? Would make it easier to fly in ATT mode without always having to hold the throttle stick up. They supply the little metal bracket in the box already and there are you tube videos on how to do this. Doesn't look to hard to do. Im a novice heli pilot and looking to eventually working my way to full conventional heli controls.
                          Regards
                          Tony
