Official RotorScale 470 Size Airwolf Super Scale GPS Stabilized Helicopter Thread
  • Goop99
    • Apr 2025
    • 3
    • Michigan
    Hey all, I just recently received my 470 Roban Airwolf.
    Having a helluva time getting the landing gear to cooperate.
    It either doesn't want to fully retract, or after I make adjustments, it won't fully extend.
    Part of the issue is that the grub screw isn't always in the ideal position to make the adjustments that I need.
    I've watched every video I could find on this issue, but none of them help.
    Also, while facing the helo, the main left side connector rod ( the long one) really arches when I retract the wheels. I've also tried to adjust it to no avail.
    This thing is about to get introduced to a baseball bat!!
    Any ideas, suggestions? Thanks in advance.​
    • Goop99
      • Apr 2025
      • 3
      • Michigan
      Originally posted by AlreadyReadyAlready
      Does anyone know where these stickers belong?
Name:	2025-02-12 18.34.13.jpg
      They fit nicely into the nearest trash receptacle. Good luck getting them off of the paper intact! They're useless!
        I was hoping to get the stock PID numbers from the flight controller. Thanks.
        • turdlauncher
          • Mar 2025
          • 6
          for retract problems have a look a this video from motion RC https://www.youtube.com/watch?v=JN5A...st=WL&index=14
          • fossoman58
            • Jun 2025
            I am having a problem with my Rotorscale Airwolf 470. have about ten flights on this heli but now it does not want to Take off . I may have messed with the End point adjustment on the transmitter. I wait on the slow blink green light Move the throttle stick right in down hit run and no blade spin up
              • 8814
              ALL endpoints should say 100%. This is the primary reason why I don't unlock these TXs - for fear of screwing something up. Of all GPS helis I own that uses this TX, I feel they are all pre-programmed the way they were meant to be for that specific model and for most owners.
              • bitogre
                • Mar 2022
                • 2
                Is it possible to change the Radio? I prefer my Radiomaster TX16 and I think I want to use it with ELRS (may put my ELRS Gemini Rx for best link quality). Or maybe I can just bind it to the multiprotocol module? What do people think about using a different transmitter with this helicopter?
                • mbrodbeck
                  • 2
                  I changed the Radio on my Bell 206, the only receiver I got the helicopter to work with used sbus
                    Just got a new 470 airwolf today, built it, put in my crossfire radio system and flew it. I am very happy and impressed with it. Didn't realize it is closer to a 500 size helicopter than 450. Very nice!
                    • Gigg
                      • Feb 2024
                      • 18
                      Just ordered my air wolf 470 its kinda pricey but i cant wait until it gets here .Im hoping it doesent have any issues . I currently have a fly wing 450 which i love.
                        • 8814
                        I have the Roban (Rotorscale) MD 500, 470 size and a Flywing 450 V2.5, which I installed into their Airwolf fuselage. Both fly amazingly well but I find the MD500's bigger size to fly a bit more stable, so you may find this as well when you compare the 470 Rotorscale to your 450 Flywing. There is a video that MotionRC put out about the retract mechanism getting loose and how to reset and fix it. Check Motion's YouTube channel.
                        Yes, these new GPS choppers are quite pricey but these are the only ones that I can fly. The pre-GPS helis were nearly impossible for me to fly beyond a short hover. I don't do 3D with them. I fly them in circuits and as such, I'm allowed to fly them with the other airplanes at the field. I started with just one GPS heli and said that was it. They are just too expensive. I now have 4, one more coming.
ID:	429849 Click image for larger version
ID:	429850 Click image for larger version  Name:	429734e9-2fa9-4297-82fb-f05d9d6dcc9d.jpg Views:	0 Size:	66.0 KB ID:	429852 Having experience with arducopter, I was able to change the radio out for my own frsky, so I added 1 second delay timing for the retracts. They look really cool slowed down. Im slowly upping my timer for flight time, im up to 8 minutes so far.
                          • Gigg
                            • Feb 2024
                            • 18
                            Ohh bpy just got the box im so excited. im not great at putting sutff together hope i do ok ).
                            • BongRTM
                              • Feb 2020
                              • 3
                              • Colorado Springs
                              Originally posted by AlreadyReadyAlready View Post
                              Does anyone know where these stickers belong?​
                              Based on Original Aiwolf pics...see attachments below...
                              Click image for larger version  Name:	bg2.jpg Views:	0 Size:	56.2 KB ID:	430117 Click image for larger version  Name:	big8.jpg Views:	0 Size:	63.5 KB ID:	430115 Click image for larger version  Name:	big28.jpg Views:	0 Size:	57.9 KB ID:	430116 Click image for larger version  Name:	bg2.jpg Views:	0 Size:	56.2 KB ID:	430118
                              • Gigg
                                • Feb 2024
                                • 18
                                The tail support rod is splitting the tali when i try to put it in. Any suggestions do i really need that part?
                                  • 8814
                                  This has been reported earlier in this thread. Do you need it? Well, does the tail rotor hit the ground if the wire isn't there? If it doesn't, don't worry about it. If it does, you need the wire to protect the tail rotor when it's on the ground.
                                  Is the wire too fat to fit into the hole in the tail? If so, drill it out a bit so the wire doesn't split the tail. Shove the wire in and then use some CA or epoxy squeezed into the crack and tape it shut till it's cured.
                                  • Gigg
                                    • Feb 2024
                                    • 18
                                    Thanks ill try that.
                                    • Gigg
                                      • Feb 2024
                                      • 18
                                      i drilled the bar out a bit worked well. Also i drilled out the guns connectors it made them fit much better .. no such thing as rtf . Thanks guys for your help.
                                        • 8814
                                        I don't think that's what "RTF" means but that's a topic for discussion in a whole other thread.
                                        • Jeffrey taylor
                                          • Aug 2025
                                          I put a h1 flight controller in my align 600 esp and when It's spooling up I have no movement in tail rotor servo with stick movement. Is this common until it gets airborne?
