Originally posted by Alpha
View Post
The vertical mod was done with a piece of the original EPP foam tip from after I cut it off. Then used a little Spackle for filling and counter. The pod was made with balsa stick sanded to shape and then sealed with Z poxey finishing resin. I used two small carbon fiber rods through the pod and into the vertical stab for added support after gluing it on.
