Introducing the CenterBurner Simulated Afterburner Light System
    Originally posted by air-jon
    I believe the Flex jet uses the Taft 90mm outrunner fan. If you can send me some detailed pics and dimensions of the EDF housing, I can make an adapter to fit this and give it to the Geek to offer....
    email me airscaperc@gmail.com
    Copy that, I'll see what I can do, I been away camping without use of cellphones. I have a video of some beach flying I did on my trip. Never miss an opportunity to fly :D
  • Evoman
    Good to know but I am sure those safety codes are in place just for general protection and liability.
    If I were to try this out on my own I would not even think of trying out at an AMA filed. Just like the USAF would test fly their experimental projects at a test site so would something like this.
    There are a lot of products made for trucks and sports cars such as nitros kits labeled for off road use only so an eventual working EDF blow torch could be labeled the same.
    "For off sanctioned field use only" LOL
  • fhhuber
    Not sure about the newly revised AMA safety code... but the old safety code definitively banned afterburners.
    Either way, its a generally unsafe idea to be operating a flying blowtorch.
  • Evoman
    I second that, my jaw just about hit the ground and Nefi 2017 when Steve flew the Mig!
    The most authentic looking afterburner light I've seen so far, now if it would just add a little more thrust, no wait, that would make it the real thing!!
    The only other EDF afterburner I have seen that is a bit more authentic is the experimental setup that Flitetest did using butane. The cool thing about was that it not only produced a flame coming out the exhaust but it also sounded like an actual afterburner. It would be great to have this done again on a bigger jet with space for more fuel. A butane canister or two could be disguised as a drop tank.
    Although this design seamed to produce little additional thrust I am sure it could produce more with an improved design.
  • Petronio
    You can always build the Windestahl Afterburner xdd
    Good to hear from you Jon and welcome to HobbySquawk. Your center-burner is still working great on my Mig. Really adds to the bling! :)
  • air-jon
    Quick question, will this work for the flexjet as well?
  • Jhnybgd
    No - the lights sit in the center of the motor and it doesn't impede the air flow - there's no negative affect.
    Thanks Mudduck,putting it on my to do list!
  • themudduck
  • Jhnybgd
    Hi all,has any one whom has flown thier F4 before the afterburner noticed any thrust loss since installation?
    RCGeek, Great tip. USPS delivered my LED 90mm AB unit for my Phreewing PH Phour today and it is gorgeous. Thank you. I am faster now. Sierra Hotel. Best, LB:)
  • The RC Geek
    Originally posted by dahawk
    Hey guys,
    Is there a product out there for weathering the rear fuse from the nozzles back to resemble black soot ? The early B&C F4's were huge black smoke producers. Probably would want the interior of the nozzles to be sooty looking. And then whisked up the tail section . Now that I have my Sundowners built it looks like it just rolled out of the MD Lambert Field facility.
    I like to use a combination of acrylic washes (oils work too) in different colors and airbrush shading. If you use a flat black airbrush shading back there following all final clear coat, etc., it should look like soot, but the key is to not apply too much. The washes are to bring out all of the uneven details that are back there.
  • The RC Geek
    Thanks Chris! Received my 90mm inrunner. Install was simple and it works great ! Have it in the FW Phantom F4B. Love it!
    Awesome, thanks man!
  • dahawk
    Thanks Elbee,
    Probably should posted on the F4 thread. Sorry guys. Will get some rub n buff today.
    Hawk
    Hey guys,
    dahawk, Ebony Rub and Buff and/or plain old charcoal thinned with mineral spirits, pretty messy stuff though but just rub on and wipe off gently, let dry then shoot clear acrylic flat to keep it from getting on your white chokers. Best, LB
  • C17loadmaster
    Originally posted by The RC Geek
    Good question! I have the design ready at 29mm ID, just need to print them up, get some pics and then get them posted.
    Awesome! Can’t wait to add them to my SU-35. They look awesome in my F-14
  • dahawk
    Hey guys,
    Hey guys,
    I have these back in stock now. Had a short little lull, but all good now and should be for a while!
    Chris
    Yep, Was checkin' out your website, placed my FW F-4 burner in the cart and shazam, you mailed it. Thanks. Best, LB
